Assembly is the reverse of disassembly...
Discussion in 'UK Motorcycles' started by Ivan D. Reid, May 4, 2011.
  1. Ivan D. Reid
    Skipweasel Guest
    I bet you say that to all the girls.
    Skipweasel, May 6, 2011
  2. Ivan D. Reid
    That's 'flashing up' not 'fishing up'
    Pip Luscher, May 6, 2011
  3. And how they love it.
    Grimly Curmudgeon, May 6, 2011
  4. Ivan D. Reid
    Mike Fleming Guest
    I'd like one (some day I'll get round to getting one) but I suspect
    I'd still use one of the digital MMs.
    Mike Fleming, May 7, 2011
  5. Ivan D. Reid
    Ron Guest
    Oh absodiddlyutely, great for checking diodes and trannysistors. I have
    a little Philips analogue meter for that porpoise - not that I do much
    silicon surgery these days.
    Ron T'Otheren
    Ron, May 7, 2011
  6. Ivan D. Reid
    Skipweasel Guest
    Would you like mine? I've not really examined it closely, but TBH I
    can't really find a lot of excuse for having it - if I need to see
    analogue signals I'll stick the scope on it.
    Skipweasel, May 7, 2011
  7. Far too fucking big and heavy.
    Whereas I think completely the opposite. An analogue meter is good enough
    for 99.9% of what you do when used in and around your vehicle and home
    environment. especially when all you need to know most of the time is
    whether a voltage is present or not and not what the value is down to the
    nearest ten thousandth of a volt.
    I am not knocking digital mms for resistance measurement they are
    unbeatable but a couple of years ago, when faced with a broken one and a
    wide choice as to it's replacement, I bought a 15 quid waving needle one
    from maplins.
    steve auvache, May 7, 2011
  8. Ivan D. Reid
    Alan Dicey Guest
    Trouble is the digital instrument is cheaper to make and much more
    robust. The mechanical movement of the analog meter is always going to
    be its weakest point.
    Presently Maplin can sell you an analog meter for £11, or a digital for
    £9, or nice little clamp meter for £10 that will also to volts and ohms.
    http://www.maplin.co.uk/tools/test-equipment/multimeters
    Alan Dicey, May 7, 2011
  9. Ivan D. Reid
    How about a hybrid design? R/C-type servo but without the gearing?
    Would need a precision feedback pot and careful closed-loop control,
    mind, to ensure rapid settling at the required reading without
    ringing.
    Robust and a high-impedance input all in one package..
    Battery use might be a bit heavier than a digital instrument, but
    that's the only drawback I can see.
    Pip Luscher, May 7, 2011
  10. Ivan D. Reid
    Bernard Peek Guest
    For quite a while there have been digital meters with a progress-bar
    type display alongside the digits.
    Even a cheap digital meter is going to be more accurate than any
    analogue display. When I jbexed for them Fluke's lowest cost machine had
    an accuracy of 0.3% which at the time was about ten times better than an
    AVO. Avo accuracy 3% of FSD, Fluke 73 0.3% of reading +1 digit.
    Bernard Peek, May 7, 2011
  11. Ivan D. Reid
    Ron Guest
    I've seen a digital meter with both a numerical display and a moving
    pointer formed by the lcd display similar to some guitar tuners
    Ron T'Otheren
    Ron, May 7, 2011
  12. Ron said:
    With a jpg of a mirror behind it ?
    Richard Robinson, May 7, 2011
  13. Ivan D. Reid
    Ron Guest
    of course
    Ron, May 7, 2011
  14. Ivan D. Reid
    Oh, sure, but for rapidly changing signals, such as audio, there's
    nothing like a waving needle to give a feel for what's going on.
    Obviously there are oscilloscopes, but a waggly needle still has its
    place for a quick check, I think.
  15. Ivan D. Reid
    "Visually averaging the excursions of the needle".
    Pip, May 7, 2011
  16. Ivan D. Reid
    Skipweasel Guest
    I'm going to have to molish a trolley for my scope and smouldering iron,
    I goove.
  17. Ivan D. Reid
    Pete Fisher Guest
    BS4142 ?
    | Pete Fisher at Home: |
    Pete Fisher, May 7, 2011
  18. Ivan D. Reid
    Rumbled ;-)
    Pip, May 7, 2011
  19. Ivan D. Reid
    Skipweasel Guest
    Fluttered?
  20. Wow!
    John Williamson, May 7, 2011
