Arse - failed MOT
Discussion in 'UK Motorcycles' started by Grimley_Feindish, Aug 18, 2004.
  1. The XT failed on 4 loose front spokes, including the bent one I asked on
    here about a while ago. Could've sworn I checked them but it could've been
    worse, at least everything else is OK. On the downside, the bent one
    promptly snapped at the first attempt to tighten it. I had no idea it would
    be so difficult to get a single replacement spoke in Norwich or surrounding
    area, looks like I'll be cancelling the re-test on Satruday.
    Yamaha dealers want £32.00 for a complete set "don't sell them individually
    mate". I have the number of a bloke
    who may be able to make me one but no answer so far. Hopefully Google will
    be my friend again.
  2. Probably bad form answering you're own post but wtf, just found this that
    may be of use to others:
    http://www.central-wheel.co.uk/cwc/spokes.html
  3. Grimley_Feindish
    Ben Guest
    Try a decent pedal bike shop. If they're decent they'll build wheels
    and have a vast selection of spokes.
    Ben, Aug 18, 2004
  4. Grimley_Feindish
    Eddie Guest
    In sizes that would suit an XT's front wheel? Really?
    Eddie, Aug 18, 2004
  5. Grimley_Feindish
    Preston Kemp Guest
    http://www.central-wheel.co.uk/ should be able to sort you out.
    Preston Kemp, Aug 18, 2004
  6. Grimley_Feindish
    Cycle rims and hubs come in a huge variety of sizes, it's true, but I
    seriously doubt they'd have any of the right guage, even if the
    lengths were OK.
    Ace, Aug 18, 2004
  7. Grimley_Feindish
    Ben Guest
    Might find something. In my old shop we had spoke sizes to cover
    everything from 6inch up to 27 inch wheels. Dunno about diameter wise
    but it's worth a try.
    Ben, Aug 18, 2004
  8. Thanks for the info, appreciated.
    Spoke to CWC, they can do 10 for £12 including nipples (fnnarr) and postage,
    which I thought was fair. Managed to get the broken one out without removing
    the tyre (let the air out, held the tyre out of the way with a lever and
    used needle nosed pliers to remove the nipple) so hopefully the new one will
    go in the same, maybe.
  9. Grimley_Feindish
    I suggest that you take a close look at a spoked motorbike wheel. The
    spokes are about twice the thickness of any cycle spoke I've ever
    seen..
    Ace, Aug 19, 2004
  10. Grimley_Feindish
    Ben Guest
    Fair enough. Might get it through the MOT though.
    Ben, Aug 19, 2004
  11. Grimley_Feindish
    flash@work Guest
    You have to get your arse MOTed? Is it a public service one?
    flash@work, Aug 19, 2004
  12. Grimley_Feindish
    Eddie Guest
    I suspect a pushbike-sized nipple would be way too small, and just pull
    straight through the rim - possibly even damage it in the process.
    Eddie, Aug 19, 2004
  13. Grimley_Feindish
    No way. Stand out like a sore thumb, they would. And even if they're
    not a specific item to check they'd simply class it as not roadworthy.
    And they'd be right, too.
    Ace, Aug 19, 2004
  14. In your dreams ;)
    Grimley_Feindish, Aug 19, 2004
  15. Grimley_Feindish
    But the bicycle shop may know of a supplier able to get suitable a M/C
    spoke. They may even have something suitable lying about.
    sweller, Aug 23, 2004
