Are Tire Repairs Recommended???
Discussion in 'Bay Area Bikers' started by Larry xlax Lovisone, Nov 18, 2004.
  1. Larry xlax Lovisone
    Odinn Guest
    Never made it to that track, most of what I did was in Mississippi and
    Alabama in late 70s. Drove a 75 Firebird 6-cyl.
    setup and actual driving style, on dirt, you can back it in and still
    keep your tires, on asphalt you would hit the wall.
    No, ROC, http://www.imp.mc/rocwebsite/index.htm, completely different
    that IROC.
    Odinn
    '03 FLHTI ........... http://www.sloanclan.org/gallery/ElectraGlide
    '97 VN1500D ......... http://www.sloanclan.org/gallery/VulcanClassic
    Atlanta Biker Net ... http://www.atlantabiker.net
    Vulcan Riders Assoc . http://www.vulcanriders.org
    Fill in the blanks to reply
    Odinn, Nov 23, 2004
    #41
  2. Not bad, there was a owner of a auto repair shop that
    dominated the Super Stock class in a 68' dodge that had a
    440 magnum stock. She didn't just have a fast car...she was
    damn good.
    I agree to a point...I've seen a car back it in on asphalt.
    Successfully. I wish I still had the skill to do pendulum
    turns, something circle track drivers never learn.
    I'll look into it...
    Nefarious Necroloigist 42nd Degree
    Some people ride, some just like to show off their butt
    jewelry once in a while.
    Dum vivimus, vivamus
    <:(3 )3~~ <:(3 )3~~ <:(3 )3~ <:(3 )3~
    Keith Schiffner, Nov 24, 2004
    #42
  3. Larry xlax Lovisone
    Odinn Guest
    A good driver with a mediocre car can typically outrun a mediocre driver
    with a fast car :)
    Yes, you can successfully back it in on asphalt a couple of times, but
    you will definitely lose positions compared to those who keep the
    backend behind them. It takes a lot more work to keep it out of the
    wall on asphalt than on dirt when the backend is trying to pass you.
    The race is Dec 4th in France. I think it's covered by SpeedVision.
    Odinn
    Odinn, Nov 24, 2004
    #43
  4. Larry xlax Lovisone
    Turby Guest
    OK, I gotta ask. From a woman's perspective, what makes a good titty
    bar?
    Turby the Turbosurfer
    Turby, Nov 24, 2004
    #44
  5. Larry xlax Lovisone
    Bownse Guest
    "X-No-archive: yes"
    Yep. $20 on the cover charge. But you save so much more with all the
    lap dances you DON'T want at the second place.
    Bownse, Nov 25, 2004
    #45
  6. Nasa's Space Shuttle... I think zero G would make a great titty bar...
    Larry L
    94 RC45 #2
    Have a wheelie NICE day...
    Lean & Mean it in every corner of your life...
    If it wasn't for us the fast lane would rust...
    V4'S are music to the seat of my pants...
    1952 De Havilland Chipmunk...
    Yank and bank your brains loose...
    http://members.ebay.com/aboutme/-xlax-/
    http://home.comcast.net/~netters2/
    http://www.fox302.com/index.pl?s=vg&user=netters2
    Larry xlax Lovisone, Nov 26, 2004
    #46
  7. For those too impatient to shell out 6 figures on Virgin Galactic, you
    can get the same effect underwater.
    It's glorious.
    Jason O'Rourke, Nov 26, 2004
    #47
  8. Larry xlax Lovisone
    Chuck Joga Guest
    Reply to message from "Larry xlax Lovisone" <>
    (Sat, 20 Nov 2004 13:29:14) about "Re: Are Tire Repairs Recommended???":
    Larry.
    I used a cheapo bullett type plug from Road Rider. It came in a kit with a
    screwdriver type applicator. The trick is to use the applicator to clean/
    ream the hole with plenty of cement first.
    The funny thing is that a friend on a BMW got a flat and the BMW flat kit
    was really not easy to use. we couldn't evin get the rubber "donut" into
    the hole. Another friend pulled out this cheap kit and it worked great. So,
    after the trip, BMW guy and I went to Road Rider :)
    The only other real revalation is that you need at least 6 cartridges of
    C02 to get any real tire pressure. The BMW Kit only provided 4 I think.
    Good thing a few of us had some.
    -Chuck
    Chuck... Did you employ a sticky rope type plug that became part of the
    tire???
    Chuck Joga, Nov 30, 2004
    #48
  9. Larry xlax Lovisone
    Brandon High Guest
    The BMW kit works, but it's tricky. I think the style of plug that's in
    the kit is potentially more secure than the bullet type. Since any sort
    of plug should be temporary at best, it's probably not an issue.
    The "mushroom" or "patch" plugs are different - They go on the inside of
    the tire and have never caused a problem for me after a few thousand
    miles.
    My bike's kit came with 2. If you manage to plug the hole without a
    total loss of pressure, and have a 160 or 170 tire, that's all you
    really need to get you home. With a larger rear tire, you might be in
    trouble.
    I got my tire patched today by Robbie (the "Super Tire Guy") at
    Subterranean Cycles. ( http://www.subcycles.com/ ). Took about 20
    minutes and $25.
    -B
    Brandon High, Nov 30, 2004
    #49
  10. The funny thing is that a friend on a BMW got a flat and the BMW flat kit
    Thanks Chuck... I employ a simple countersunk wood screw as a temporary plug
    which is easy to install and will not jettison on the way home... then I
    will employ the permanent plug...
    Larry L
    94 RC45 #2
    Larry xlax Lovisone, Nov 30, 2004
    #50
