Aprilia technology!
Discussion in 'Motorcycle Racing' started by Dennis, Nov 13, 2003.
  1. Dennis
    Dennis Guest
    Why is Aprilia MotoGP bike known as the cube? In Colin Edwards interview on
    www.amasuperbike.com it is mentioned that Aprilias' cube might be the most
    technically advanced bike in the field. What are some of the high tech
    pieces, technology rumored to be used on the Aprilia! Colin mentioned the
    bike wanted to "loop out" is that the same as wheelie?
    Thanks,
    Dennis
  2. Dennis
    Chris Cavin Guest
    1. Pneumatic valve return - the Cube has no conventional metal valve springs.
    Much higher revs are possible than with conventional valve springs because
    conventional valve springs can't close the valve effectively beyond a
    a certain rpm.
    2. Ride-by-wire - there is no physical connection between the throttle grip
    and the actual throttle plate. The "connection" is electronic and very
    adjustable.
    3. I think it's called the "Cube" because it has three cylinders. Nothing
    more than a clever name. RS3 leads to RS^3 leads to RS Cube...
    I'm sure there are more major differences, but I don't know what they are.
    -Dirt-
    Chris Cavin, Nov 13, 2003
