Aprilia Falco Side Stand Problems
Discussion in 'UK Motorcycles' started by VødkäJéllÿ, May 30, 2004.
  1. Hi All
    Please could you help me out on this. The bike sits too high/upright on
    the side stand and it makes it unstable. Has anyone got any ideas or
    could maybe point me to a site that will help.
    Cheers
    Vj
  2. VødkäJéllÿ
    SP Guest
    Get the sidestand cut and welded, as follows:
    A competent welder will easily be able to do this job - just ensure
    the joint is V'd so you are able to fill the join with weld as opposed
    to a butt joint - or have the arm sleeved.
    Lesley
    CBR600 FW
    SBS#11[with oak-leaf cluster]
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    Un-cork me to reply
    SP, May 30, 2004
  3. VødkäJéllÿ
    VødkäJéllÿ wrote in
    angle grinder
    wessie, May 30, 2004
  4. It was somewhere around Barstow, on the edge of the desert, when the
    And make sure it's not cast iron.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 31, 2004
  5. VødkäJéllÿ
    SP Guest
    Damn, got me there.
    Lesley
    CBR600 FW
    BONY#54P BOB#18
    Un-cork me to reply
    SP, May 31, 2004
  6. VødkäJéllÿ
    Eddie Guest
    I never had a problem with mine, but: if you don't want to go for the
    cut 'n' weld solution, Renegade make a bracket that changes the angle of
    lean:
    http://www.renegade-products.com/renegade/messages/2/95.html?1074886906
    Alternatively, AF1 Racing can supply a billet aluminium sidestand...
    hmmm, shiny:
    http://www.af1racing.com/store/Scripts/prodList.asp?idCategory=46
    Eddie, May 31, 2004
  7. VødkäJéllÿ
    mb Guest
    Ha! You think I never noticed that.
    OK, lemme explain: I never said sidestands were cast iron. I gave cast
    iron as an example of something which is a bastard to weld, even if you
    use the correct nickel based electrode. Get it wrong and you have a
    completely useless weld, as eny fule kno.
    I have been inspecting welding (amongst other things) for the last 25
    years and know a bit about welding and the welding industry.
    Just to give you something to worry about, I am presently inspecting
    welding on bits for the new Wembley stadium. Last year it was Swiss Re,
    before that it was the London Eye, etc.
    mb, May 31, 2004
  8. Eddie wrote:
    ||| high/upright on the side stand and it makes it unstable. Has
    ||| anyone got any ideas or could maybe point me to a site that will
    ||| help.
    || angle of lean:
    || hmmm, shiny:
    || HTH
    Thanks! This is what I was looking for!
    Here's the bike btw...
    http://www.giggle.myby.co.uk/bike_heyheyyy.jpg
    Vj
    VødkäJéllÿ, May 31, 2004
  9. wessie wrote:
    || VødkäJéllÿ wrote in
    ||| Hi All
    ||| help.
    || angle grinder
    || BMW R1150GS
    Well what a top idea! dopey!
    Vj
  10. mb wrote:
    || message ||| [snip]
    || cast iron as an example of something which is a bastard to weld,
    || even if you use the correct nickel based electrode. Get it wrong and
    || you have a completely useless weld, as eny fule kno.
    || Re, before that it was the London Eye, etc.
    || Mike
    || FJ1200 (Porky Torquey)
    || GTS1000 (Two rear ends)
    I don't think welding is the option for my bike, was more looking for an
    adaptor. Thanks for your reply though!
    Vj :O)
  11. VødkäJéllÿ
    Pete M Guest
    In
    Oh, by the way... Lesley... I meant to e-mither you with this.
    Bells Welding, Back Canning Street (in between Catherine Street and Hope
    Street).
    Can't remember his phone number, but if you tell him "Fast Car Pete" from PR
    sent you..
    Pete M, May 31, 2004
  12. You said ANY ideas. Muppet.
    You need a shorter side stand.
    An angle grinder will give you a shorter sidestand.
    It may not be what you would like, but it will solve the problem.
    ColonelTupperware
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/
    UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, May 31, 2004
  13. VødkäJéllÿ
    Eddie Guest
    Eddie, May 31, 2004
  14. Colonel Tupperware wrote:
    ||||| angle grinder
    || ColonelTupperware
    lol :O) I did, you're right. Even though we know it needs the adaptor,
    we cant get hold of one, and it looks like the dreaded angle
    grinder/bend it out a bit approach is creeping nearer.
    Vj
  15. VødkäJéllÿ, May 31, 2004
  16. It was somewhere around Barstow, on the edge of the desert, when the
    Oh I know. I've tried to weld CI, sometimes it worked, mostly it didn't.
    The only time I had any real success was using a bloody great gas hearth
    to keep the temp of the piece up and let it cool slowly.
    There's nothing quite like that feeling you get when you look at the
    weld and admire your work, only to hear that devastating ping as it
    cools and cracks.
    We know who to blame, then.
    GS 850 x2 / SE 6a
  17. VødkäJéllÿ
    mb Guest
    Helps to peen the toes of the weld after every run.
    The worrying thing is that it's all welded in Holland (except for the site
    welds, obviously).
    mb, May 31, 2004
  18. VødkäJéllÿ
    Eddie Guest
    Yeah, all present and correct. And now back to their usual colour, too.
    Eddie, May 31, 2004
  19. VødkäJéllÿ
    blue-green, eh?
    Champ, Jun 1, 2004
  20. VødkäJéllÿ
    Eddie Guest
    Huh? I thought I turned that webcam off.
    Eddie, Jun 1, 2004
