Aprilia Falco question
Discussion in 'UK Motorcycles' started by Lozzo, Apr 30, 2005.
  1. Lozzo
    How do you remove the bar ends?
    Lozzo, Apr 30, 2005
  2. Lozzo
    sorby Guest
    If they're the same as the Mille's then....
    "Clamp existing bar end & unscrew bolts on end.
    Using Molegrips unscrew internal nut."
    sorby, Apr 30, 2005
  3. Lozzo
    simonk Guest
    Pshaw! I've had 2 milles[1]
    No idea how the bar ends come off, sadly. Eddie's had one, I think.
    [1] more on the new one at the end of the weekend, when I've had more of a
    chance to ride the thing, but in short "it's all good"
    simonk, Apr 30, 2005
  4. simonk wrote
    He still has one
    steve auvache, Apr 30, 2005
  5. Lozzo
    simonk Guest
  6. Lozzo
    simonk says...
    Lozzo, Apr 30, 2005
  7. Lozzo
    AndrewR Guest
    Not since somebody tried a U-turn in front of him, he hasn't.
    Still that was a whole year ago, so you can't be expected to remember.
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1, Fiat Coupe 20v Turbo
    The speccy Geordie twat.
    AndrewR, Apr 30, 2005
  8. AndrewR wrote
    Really? Hey ho.
    You'll be telling me Ghandi is dead next.
  9. Lozzo
    He whips them off with his bollocks. The hard bastard.
    Pip, May 1, 2005
  10. miaow
    Paul Corfield, May 1, 2005
  11. Lozzo
    Eddie Guest
    *ahem*
    I haven't read the rest of the thread yet, but if you still need to
    know, mail me: I'll have a look in the workshop manual.
    Eddie, May 1, 2005
  12. Lozzo
    Eddie Guest
    7.1.9 REMOVING THE GRIP ON THE LEFT HANDLEBAR
    Carefully read 0.4.1 (PRECAUTIONS AND GENERAL INFORMATIONS (sic)).
    o Position the vehicle on the stand.
    o Turn the ignition switch to position "[1]".
    o Use a pair of adjustable pliers, with the jaws wrapped in adhesive
    tape so as not to damage the counterweight, to hold the counterweight still.
    Counterweight screw driving torque: 10Nm (1.0 kgm).
    o Unscrew and remove the screw.
    o Remove the counterweight.
    o Slide out the pin.
    o Slide off the O-ring.
    Grip end driving torque: 35 Nm (3.5 kgm).
    o Slide off the end piece.
    o Insert the nozzle of a compressed air gun between the grip and the
    handlebar.
    o Blow air, moving the gun's nozzle with a rotary movement and, at the
    same time, seize the other grip with the other hand and slide it off.
    [1] The character for the 'off' position isn't on my keyboard.
    Eddie, May 1, 2005
  13. Lozzo
    Eddie says...
    <snip instructions>
    Thanks Eddie. I'll pass that on.
    Lozzo, May 1, 2005
  14. Lozzo
    Eddie Guest
    No probs - let me know if anything else is needed.
    Eddie, May 1, 2005
