ape hangers on a vstar
Discussion in 'Motorbike Technical Discussion' started by rajuncajunbiker, Feb 5, 2007.
  1. Hello all,
    Can anyone tell me if it is possible to put aftermarket ape hangers
    with a diameter of 7/8 in on a 2000 vstar 650 if the stock bars on it
    now are 1in ? Or, do the aftermarket bars HAVE to be 1" also? Thank
    you much!
    -Charles
  2. rajuncajunbiker
    Think about it a little - how are the 7/8 bars being held onto the bike
    if the bike's set up for 1" bars?
    Timo Geusch, Feb 5, 2007
  3. Shims cut from beer cans?
    The Older Gentleman, Feb 5, 2007
  4. Well i knew that much...guess i didnt explain more, I meant ithere a
    posiblity of a metal shop fabricating somthing for me
  5. rajuncajunbiker
    John Johnson Guest
    If you're willing to pay someone to fab stuff, then 'is it possible'
    becomes synonymous with 'how much would it cost' and to answer that you
    simply need to ask the shop you'd be going to for the work.
    OTOH, if you're asking the slightly different question "my bike comes
    with 1" bars, are there any retail products that would change my clamps
    to take 7/8" bars?" the answer becomes essentially an exercise in
    calling/searching retailers. This site appears to have the stuff that
    you're looking for, for example:
    http://www.pacificcoaststar.com/pcs/all_handlebars.htm
    Or maybe you're asking a slightly different question?
    Later,
    John
    John Johnson, Feb 6, 2007
  6. The next one will be, "How can I fit a 1" twistgrip to 7/8" bars?"...
    Dr Ivan D. Reid, Feb 6, 2007
  7. rajuncajunbiker
    John Johnson Guest
    I do believe that falls under the 'how much will it cost' category
    myself, though perhaps I should have been more explicit in my
    explanation. But who knows; perhaps the OP had a set of ape hangers
    complete with 1" controls given as a gift, and is looking to install the
    entire package?
    In any case, more information from the OP will help us to help them. I
    do rather suspect that the simplest solution will be to purchase bars
    compatible with the OEM controls, as found on many a cruiser
    customization website.
    Later,
    John
  8. rajuncajunbiker
    James Clark Guest
    How much duct tape you got?
    James Clark, Feb 6, 2007
  9. rajuncajunbiker
    Mark Olson Guest
    Another guy who would rather watch Red Green than read ZATAMM...
    Mark Olson, Feb 6, 2007
