Anyone who KNOWS about engine oil here?
Discussion in 'UK Motorcycles' started by Mike Barnard, Mar 31, 2005.
  1. Mike Barnard
    As Loz will shortly be along to tell you at great length, the spec to
    refer to is the one that this bloke refers to flettingly - the JASO
    standard. JASO MA compliance is what you need these days.
    Pip, Mar 31, 2005
  2. Mike Barnard
    Paul - xxx Guest
    Champ composed the following;:
    He reminds me of someone, but I can't put my finger on it ..
    ....and that music on the home page .. ;)
    Paul - xxx, Mar 31, 2005
  3. Mike Barnard
    Pip says...
    Buy JASO MA spec oil for use in bikes with wet clutches.
    You may now return to tonight's featured programme.
    That is all.
    Lozzo, Mar 31, 2005
  4. Mike Barnard
    tallbloke Guest
    May not be as small as you think. Consider how much more willingly an engine
    revs once the oil is warmed through and less viscous.
    tallbloke, Mar 31, 2005
  5. Mike Barnard
    You're not wrong there.
    I had a change on mind after hearing about a Honda technical service
    bulletin[1]. This guys opinion on oils for bikes in fact....
    http://www.math.uwaterloo.ca/~rblander/oil_opinion.html
    It's the first time I've seen a technical bulletin from a motorcycle
    manufactuer quoted.
    [1]For the FZR, Bandits and CG125s aren't very stressed.
    Muck, Mar 31, 2005
  6. Depends on the engine.
    I know that modern truck diesels have obtained a useful power increase
    through using modern synthetic thinner lubes.
    And think - even if it's only a horsepower or two, it's a damn good
    result simply for undoing a drain plug and replacing it.
    The Older Gentleman, Mar 31, 2005
  7. Mike Barnard
    <raises hand hesitantly>
    I think that that's unrelated to his point.
    In a multigrade oil designation, the cold weather bit comes /before/
    the 'W'. In his example, both the the winter and summer viscosities
    are higher in the "thicker" oil: winter 10W vs 20W; summer 40 vs 50.
    Oil friction is viscous friction, not "metal on metal" friction.
    Provided the oil film's thick enough to float the metal bits away from
    each other, a thiner oil *should" produce less drag.
    I assume he means that a thinner oil may allow more metal-to metal
    contact, but overall the lower oil viscosity will reduce friction.
    Thicker oils may take longer to circulate at startup and that's where
    supposedly most of the wear takes place.
    So, in conclusion, I have no idea what the overall effect would be.
    Pip Luscher, Mar 31, 2005
  8. Mike Barnard
    Dan L Guest
    Having perused his website I am of the opinion that the chap is a **** of
    the worst water.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    BOTAFOT #140 (KotL 2005), DIAABTCOD #26, BOMB#18 (slow)
    Dan L, Mar 31, 2005
  9. Mike Barnard
    OH- Guest
    <snip>
    If the engine manufacturer has the SAE40 oil as one of the
    recommended viscosities for the "warm weather", we can be
    reasonably sure that no more metal to metal contact will
    occur than with SAE50 oil.
    Why do all these self proclaimed oil experts think they know
    better than the people developing oils and engines?
    OH-, Mar 31, 2005
  10. Mike Barnard
    Catman Guest
    Well I never did.
    Indeed. I'm still suprised that it's that much. I would have thought that
    the Max Power crew would have jumped on the thin oil bandwagon with a
    vengance
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 155 TS
    www.cuore-sportivo.co.uk
    Catman, Mar 31, 2005
  11. Mike Barnard
    Catman Guest
    Well, with any of my injected engines, I've never noticed any difference at
    all. With the carbed engines I think the freer revving could be far more
    easily ascribed to better fuelling in a warm engine.
    Also, I *thought* one of the points of modern oils was that their viscosity
    changed rather a lot less as they heat up than in days of yore.
  12. Mike Barnard
    Mike Barnard Guest
    Thanks to all who replied. I heard lots more myth throwing [1], but
    some nicely put, valid points and Mucks link was excellent, thanks.
    If the end result had been that I could have safely used oil that only
    cost half as much it would have been worth it. But now I need to find
    an affordable supply of oil to the latest *motorcycle* spec. And Loz,
    the contact you gave me a few weeks back has given some great leads,
    thanks.
    [1] Lots of "I've always felt that..." and "It seems to me..." type
    comments, as opposed to those who KNOW because they're somewhere in
    the trade or industry.
    Regards from Mike Barnard
    '96 Yamaha YZF1000 Thunderace in red, white and grime.
    Worthing, West Sussex. UK.
    [To reply by email remove ".trousers" spamtrap from email address]
  13. Mike Barnard
    Catman Guest
    Mike Barnard wrote:
    This is UKRM, WTF did you expect?
  14. Mike Barnard
    Catman Guest
    On the phone now :)
    Catman, Apr 1, 2005
