Anyone want to by an Armstrong.
Discussion in 'UK Motorcycles' started by mark, Oct 31, 2010.
  1. mark
    mark Guest
    Joking (a bit)
    I've not had time to ride for a few weeks.
    Trumpet starts like dream on first prod.
    Armstrong? Start? You're having a fucking larf....
    I shall go back to kicking the bloody thing later; maybe even using the
    kickstart lever....
    mark, Oct 31, 2010
  2. mark
    Pete Fisher Guest
    I gave up kick starting big singles when I sold the Husky 510. Has it
    got a proper valve lifter or one of those poxy decompression valve
    things?
    I used to have the drill pretty well worked out when I had a 500
    Matchless (not Rotax but AMC 1950's]. Easy if you have a valve lifter
    and manual ignition advance retard lever. Retard the ignition, turn
    motor to just after TDC using the valve lifter. Release lifter and give
    a *long swinging kick*. Then bow three times towards [Plumstead|Hall
    Green|Small Heath|...] as appropriate to the marque being persuaded into
    life and repeat...
    | Pete Fisher at Home: |
    Pete Fisher, Oct 31, 2010
  3. mark
    mark Guest
    Not sure to be honest.....
    Deffo don't have the ignition retard unless you mean me......
    I think this may be important :)
    Heh. The bloody thing started second kick after I posted :)
    Obviously there some sort of Rotax deity that can only be appeased with
    an offering of public embarrassment.
    I shall shortly go and see how hard a 'warm' start is ;)
    mark, Oct 31, 2010
  4. mark
    mark Guest
    Obviously not enough.
    Warm start was fine. 20 minutes of riding followed by a red light at
    some road works. Filter to front and sit there on the clutch.
    Wrong.
    Clutch starts to drag like ****, refuses to go into neutral and I have
    to stall it.
    Walk it to the other side of the cones.
    Despite much sweating and kicking it will not start until it has cooled
    down a bit.
    Off we go again until the next junction I have to stop at; repeat the
    above.
    The clutch appears to be dragging when it gets hot.
    I'm not sure how adjusting it is going to help; the lever has some free
    play.
    I haven't checked the clutch end but it's fine unless pretty hot.
    Any advice welcome.
    mark, Oct 31, 2010
  5. mark
    Buzby Guest
    Its fubarred. I'll give you a fiver for it.
    Buzby, Oct 31, 2010
  6. mark
    Pete Fisher Guest
    Annoying. Will it snick in if selected while still rolling?
    Sounds like plate swell and or notched plates/hub splines or something.
    I would be looking for a throw out lever adjustment at the clutch end,
    or possibly an adjustment screw and locknut in the centre of the
    pressure plate. But I know nothing of four stroke Rotax single engines
    except that despite everyone assuming that they did, the Nordwest didn't
    use one.
  7. mark
    mark Guest
    A whole one?
    mark, Oct 31, 2010
