Anyone near Wigan who could check a car?
Discussion in 'UK Motorcycles' started by Krusty, Jan 14, 2010.
  1. Krusty
    Ashton-in-Makerfield to be precise.
  2. Krusty
    Nige Guest
    What sort of car?
    Nige, Jan 14, 2010
  3. Krusty
    Grand Cherokee.
  4. Krusty
    Nige Guest
    I'm over that way now, go to my RR auction, my mobile number is on it,
    give me a call before 3pm (after that i cant answer for a few hours)
    Ta
    Nige, Jan 14, 2010
  5. Krusty
    Thanks, but it's off the list now. 2000 registered but it's the old
    pre-99 model, so not the bargain it first appeared.
  6. Krusty
    Nige Guest
    Ney bother.
    Nige, Jan 14, 2010
  7. Don't do it. Whenever I see one on the side of the road with the bonnet up I
    think "It's a Jeep thing".
    Fraser
    Fraser Johnston, Jan 15, 2010
  8. Krusty
    No, it's "a Jeep service centre" thing. I've had my current Jeep for 10
    years & 70k miles, & it's only gone wrong once, which was a direct
    result of letting a Jeep main dealer touch it (they put the front brake
    pads in the wrong sides which caused them to seize on).
    The GC does have a couple of issues - front rotors warp as the calipers
    are slightly off centre (easily sorted with new calipers - about
    $300/pair) & the electrics can go on the fritz due to the loom rubbing
    on a bolt in the engine bay near the firewall - also easily sorted once
    you know what the problem is. Compare that with the cracked engine
    blocks on Range Rovers & Nissans, or blown head gaskets, warped heads &
    rattling throttle bodies on Freelanders, & it doesn't seem too bad.
    Of course there's always a chance of getting a lemon with any car, but
    avoid the ones that have had a new owner every year & that's unlikely
    to happen.
    Krusty, Jan 15, 2010
  9. Krusty
    Nige Guest
    That cracked block issue isn't that, it slipped cylinder liners. It's
    nowhere near as prevalent as made out either.
    Nige, Jan 15, 2010
  10. Krusty
    Seems to be both. When I was Googling RRs a few days ago, there were an
    awful lot of people with cracked blocks on the 4.6.
    These things rarely are ime, with a few notable exceptions.
  11. Krusty
    simes Guest
    I've had a lot of 4.6's and never had the problem. What is common is an
    expensive misdiagnosis of a partially blocked radiator core very common.
    simes, Jan 15, 2010
  12. Krusty
    Jimac Guest
    Krusty wrote in uk.rec.motorcycles:
    God, I miss my Jeep. I had a 2006 Grand Cherokee (CRD LTD) for 3 years
    but it went back at the end of September (it was leased). I loved that
    car, but good sense dictated I should get something a little cheaper to
    run. And the problem I had with it was a mysteriously flat battery
    after not using it for a week. It was sorted by the dealer with a mod
    involving the alarm circuit (I think).
    Jimac, Jan 18, 2010
  13. Why are alarms such pains in the arse?
    The Older Gentleman, Jan 19, 2010
