Anyone know anything about scooters?
Discussion in 'UK Motorcycles' started by Gavsta, Jul 12, 2009.
  1. Gavsta
    Gavsta Guest
    Got my Speedfight 100 back together today with a new fully charged battery.
    I have got spark, and I *think* I have compression, but with such a
    small engine its hard to tell.
    When I turn the bike over it cranks and cranks but won't fire. I have
    pulled the fuel line out and no fuel comes out when the engine turns
    over, but if I suck the vacuum tube it does.
    So for some reason it not generating enough vacuum to let the fuel flow???
    When the bike turns over and I put my hand to the exhaust I can feel the
    air coming out, but very little into the air intake itself.
    I did have the head off the bike, and didnt replace the gasket, could
    this be enough to stop the bike sucking the fuel tap open?
    Gavin.
    For the road: GSXR600K1
    For the track: <gone>
    Current project: Peugeot Speedfight 2
    For everything else: Citroën Berlingo
    MSN:
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://www.stoof.co.uk
  2. Gavsta
    boots Guest
    Who knows, chuck a gallon of petrol over it and get rid of it.
    boots, Jul 12, 2009
  3. Gavsta
    TMack Guest
    Why didn't you replace the head gasket - or do you mean that you re-used the
    old one? How long has it been since it was last used? Could be the carb
    being gummed up with old fuel if it has stood for a while. Could be a
    sticking float needle, preventing fuel getting into the carb. Does it have
    an immobiliser - if so it might have malfunctioned. Anyway - get some
    "Start Ya Bastard" or Holts "Cold Start" and spray some into the air intake
    and see if it fires with some assistance.
    TMack, Jul 12, 2009
  4. You could ask in the Spanish group. They're scooter-tolerant.
    Paul Carmichael, Jul 12, 2009
  5. Gavsta
    If it's a stroker then any suction will come from the crankcase. If
    you haven't disturbed the cylinder base gasket then all should be OK
    in the intake side. Did you remove the carb?
    Disregard above if four-stroke.
    Where on the air intake are you measuring? dorectly on the carb mouth
    or on the airbox?
    Pip Luscher, Jul 12, 2009
  6. Gavsta
    Gavsta Guest
    Re-used the original.
    It was running, but I drained all the fuel from it as soon as I started
    work on it, so its effectivly dry.
    Could be a
    Fuel isnt getting that far, as above, the vacuum bit isnt opening the
    fuel tap.
    Does it have
    It does, but I get a spark, if it was the immobiliser then surely that
    wouldnt happen?
    Anyway - get some
    Gavin.
    MSN:
  7. Gavsta
    Gavsta Guest
    It is a two stroke yes. I had the entire head off the engine down to the
    case. The heads in two parts, a lower steel bit with an alloy top that
    the spark goes into. There is a metal gasket between the two and a
    normal one between that and the engine case.
    I have a feeling that it might be that not replacing the gaskets with
    new was a fucking stupid thing to do.
    I assume that if there is any type of airleak, then it will **** up the
    suction/ compression?
    On the airbox, which is a twat to get on/ off.
    I had the carb off, but didnt dissassemble, it was just to give a clean
    and replace the hose clips that connect it.
    Gavin.
    MSN:
  8. Um, I dunno if the Speedfight has the same system, but Boxerboy of this
    parish had no end of probems with the fuel flow on his son's Malaguti
    scooter.
    There was a mechanical fuel pump, operated (believe it or not) by the
    swinging arm. The carb and pipes contained enough fuel to let it run for
    a surprising amount of time, but after that, the only way to feed fuel
    was to bounce on the seat.
    In normal operation, the constant movement of the swinging arm was
    enough to ensure permanent fuel flow.
    The Older Gentleman, Jul 12, 2009
  9. Gavsta
    Gavsta Guest
    There is a fuel tap on the bottom of the fuel tank with two hoses that
    come out of it. One supplies the fuel to the carb, one creates a vacuum
    that opens a little diaphram (I guess) in the fuel tap that lets the
    fuel flow.
    The engine isnt creating that vacuum for some reason. I know it works
    cos if you suck the vacuum tube, the fuel pours out the end of the other.
    yes, I have tried swapping them round ;)
    Gavin.
    MSN:
  10. Gavsta
    Simon Wilson Guest
    The 'lower steel bit' would be the barrel.
    Probably. Did the gaskets stay in one piece?
    I be a little surprised if it was leaking so much that it couldn't get
    enough vacuum for the fuel. If it won't fire on EZstart then I'd deffo
    get some new gaskets and get 'em in pronto.
    Simon Wilson, Jul 12, 2009
  11. Gavsta
    Simon Wilson Guest
    Good grief that would be a bugger to diagnose if you didn't know about
    it. I wonder if it applies to Moto Guzzi V11 sports?
  12. Gavsta
    Gavsta Guest
    Im no mechanic ;)
    The best I can remember is "sort of".
    Would I feel it if I put a hand round the head during cranking?
    Gavin.
    MSN:
  13. Gavsta
    Beav Guest
    Have you tried starting it at the same time as you're sucking it off?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 12, 2009
  14. Gavsta
    Derek Turner Guest
    Is it two-stroke? My exhaust got coked up and had to be opened up de-
    coked and re-welded. Same symptoms.
    Derek Turner, Jul 13, 2009
