Anyone know about plumbing?
Discussion in 'UK Motorcycles' started by Gavsta, Sep 24, 2003.
  1. Gavsta
    Gavsta Guest
    Hi,
    I have a washing machine and I have just bought a new dishwasher.
    the dishwasher connects to the cold water inlet via a cheap and cheerful Y
    connector, along with the washing machine.
    The waste water pipe for the washing machine goes into a plastic pipe about
    2" in diameter, and therefore I have no room for the waste pipe for the
    dishwasher.
    anyone have an idea of what I need to do to get them both in?
    Gavsta
    GSXR600K1
    Z750 Race bike (shared)
    R6 Race bike (also shared, and a bit bent)
    http://www.stoof.co.uk
    Big Fish Racing http://www.stoof.co.uk/bfr
  2. Gavsta
    JP Guest
    You just copied my crap ascii art didnt you?! :)
    JP, Sep 24, 2003
  3. Gavsta
    The Smiths Guest
    While you were putting the fancy wall clips on, I beat you to the send
    button!
    The Smiths, Sep 24, 2003
  4. In uk.rec.motorcycles, Gavsta said:
    Put a hole in the side of the waste pipe? Obviously the washing machine
    outlet will have to be wedged in quite far or else all the waste water
    will spout from the hole for you dishwasher outlet.
    Whinging Courier, Sep 24, 2003
  5. Gavsta
    curium Guest
    I replaced the section of pipe just above the U-bend under my kitchen sink
    with one that has 2 extra imputs.
    It looks like this -
    I then fitted the drain pipes for the dishwasher and washing machine to each
    of the additional inputs using jubilee clips.
    It's all plastic and screw fit so requires minimal plumbing skills.
    curium, Sep 24, 2003
  6. Gavsta
    Nidge Guest
    Gavsta wrote
    snip
    snip
    You can get proper 'junctions' which (after you cut into the waste pipe to
    fit them) allow you to crush fit washers outlet pipes etc.. You need one
    inlet for each appliance. A good plumbers/builders merchants (not some
    poncy showroom) should be able to show you a couple of options.
    Nidge
    ZX6R J2 Stunning in zit yellow. Bits of CB500S in Norwegian Parrot blue.
    BOTAFOT#63
    'Just because I don't care doesn't mean I don't understand'.
    (Homer Simpson).
    Nidge, Sep 24, 2003
  7. Gavsta
    Simian Guest
    Gavsta :
    What one should really do, is ask the people you buy it off, when
    you buy it. They'll then give you the correct bit of plastic for free.
    Well, that's what I did.
    <Bear>
    Dishwashers rock.
    </Bear>
    Simian, Sep 24, 2003
  8. Gavsta
    Abso Guest
    I had to solve this problem a while ago. The dishwasher sits on the
    work surface above the washing m/c and now whenever the dishwasher
    drains it fills the washing maching drum.
    Come to think of it I wouldn't ask me for advice on this.
    Abso, Sep 24, 2003
  9. Gavsta
    Platypus Guest
    DVDA
    Platypus
    VN800 Drifter, R80RT
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Sep 24, 2003
  10. Gavsta
    Catman Guest
    While most of the solutions proposed here will work, Wickes will
    actually sell you a unit (for about a tenner IIRC) that fits in place
    of your current connector. It is identical with the exceptions that
    it has two connectors for washing machines / dishwashers........
    We have one under the sink, but sadly no dishwasher :((
    Alfa 116 Giulietta 3.0l. Really, Sprint 1.7
    Ducati Monster 600 Metallic
    www.cuore-sportivo.co.uk
    Catman, Sep 24, 2003
  11. Gavsta
    Platypus Guest
    I'm, uh, just going to turn on the dishwasher. I may be some time.
    Platypus
  12. Qiute.
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Sep 24, 2003
  13. Gavsta
    Gavsta Guest
    Marvellous response.
    Thanks all, I shall ponder the suggestions and give one or maybe all of em a
    go.
    And your right, dishwashers really do rock!
    Gavsta
    GSXR600K1
    Gavsta, Sep 25, 2003
  14. Gavsta
    Gavsta Guest
    Indeed.
    Is it considered to be normal behaviour to kind of "use" the dishwasher when
    you dont *really* need to? Especially when you first get one.
    I put all me glasswear in there last night.
    Come out loverly and sparkly this morning.
    <sigh>
    Gavsta
    GSXR600K1
  15. Gavsta
    JP Guest
    Any DIY store - very cheap and easy to fit together.
    JP, Sep 25, 2003
  16. Gavsta
    Abso Guest
    Heh. I can remember running my newly delivered dishwasher completely
    empty, just to see what it sounded like.
    Now I pack it tighter than a New Dehli train, just to try and reduce
    the frequency of turning the damned thing on.
    Abso, Sep 25, 2003
  17. Gavsta
    Abso Guest
    On 28/09/2003 at 13:06:29, Mick Whittingham typed:
    Cool. I wonder what else can be prepared by dishwasher cooking.
    I don't actually have a HWMBO, must just be the way I walk that makes
    you think that.
    Abso, Sep 28, 2003
