Anyone have a clue about the CHEAPEST, RELIABLE repair I could do to a fork leg?
Discussion in 'UK Motorcycles' started by Mike Barnard, Jan 28, 2004.
  1. Mike Barnard
    Mike Barnard Guest
    Woe, woe and more woe. This FJR of mine is costing me a fucking
    fortune! Sigh...
    OK. FJR1300, 2001, 4 months out of warranty. 17,500 miles, FSH.
    Right fork leg has been weeping for a few weeks but now it pissing
    out, soaking the brakes in the process. So, new fork seal, easy, no?
    No.
    Fork out of bike OK, but it won't strip down or rebuild without
    special tools. A damper rod holder and a seal driver. I'm sure these
    can be bodged up, but not by me with my old tool set. Examine the
    fork, because something must have caused the seal to go. There is a
    small lip, looks like a tiny hole with the chrome raised in the
    staunchion.
    Damn, a new seal will just rip again, so I need to repair this. Any
    ideas how without replacing the leg? I can get it rechromed. Long
    time to find a chromer, get the part there, pay mucho beer tokens. I
    can get a new staunchion. Only £130 + vat to you sir! What else can
    be done for a reliable repair? Any clues?
    I'm off the the shop to get a copy of MCN for the ads, but any help
    would be great.
    Regards from Mike Barnard
    Yamaha FJR 1300
    Worthing, West Sussex.
    [To reply by email remove ".trousers" spamtrap from email address]
  2. Mike Barnard
    JB Guest
    Bloody dodgy! If there is a 'lip', it normally means the fork has been bent
    then straightened sometime in the past. There is no way a 'lip' would/could
    form on a hard-chromed stanchion through wear alone.
    Speak to 'the doc' at the FJ owners club. Google for FJOC.
    He's now doing much in the way of spares/maintenance/repairs/special tool
    hire for XJRs as well as the old FJs.
    cheers,
    JB
    JB, Jan 28, 2004
  3. I have had similar probs...
    Shiney leggy bit, yep, expensive to buy new.
    Re-chroming; takes a couple of weeks, once a chromer has been,
    as you say, found. Is cheaper than new though.
    Rub down with oil stone; might work... Epoxy
    in any 'oles...
    William Grainger, Jan 28, 2004
  4. Mike Barnard
    Eddie Guest
    Mike Barnard wrote:
    Damper rod holder: I make do with using something like a hex key thingy,
    on a socket, on a 3" extension, on a 12" extension, or something like
    that. Other alternative is to get a length of threaded rod, and use 2
    nuts at each end tightened together, IYSWIM.
    As for the seal driver, ummm... can't remember what I usually use. A
    hacked-up bathroom sealant tube rings a bell...
    Eddie, Jan 28, 2004
  5. Mike Barnard
    Robbo Guest
    Choose nearest from this lot, I used the Luton one. £128 the pair, 14 days.
    http://www.kellysearch.com/gb-product-17345.html
    I use a rigid plastic tube or seal replacement.
    Use electrical cleaner after gently rubbing down the affected area carefully
    using a FINE oilstone, and after cleaning Araldite.
    Then new seal.
    Until you get a replacement fork tube that is
    Robbo
    BMW K100 RS 1984
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Jan 28, 2004
  6. Mike Barnard
    Catman Guest
    Wouldn't that be a manufacturing fault?
    Alfa 116 Giulietta 3.0l. Really, Sprint 1.7
    www.cuore-sportivo.co.uk
    Catman, Jan 28, 2004
  7. Mike Barnard
    Cane Guest
    Take it to Timo then claim on the insurance.
    Cane, Jan 28, 2004
  8. I used them to do the forks on my old GSX550ES. They did a first
    class job for not mucho moolah, as I remember.
    Darren Robinson, Jan 28, 2004
  9. Mike Barnard
    Cane was seen penning the following ode to ... whatever:
    I think I'm somewhere in the exclusion clause that says they're not
    going to pay out if the damage is due to acts of Timo or somesuch...
    Timo Geusch, Jan 28, 2004
  10. Mike Barnard
    mb Guest
    I use a length of nice grey PVC pipe (50mm?) from the DIY shoppe.
    mb, Jan 28, 2004
  11. Mike Barnard
    Mike Barnard Guest
    1 owner from new, me, no fork bending crunches so far.
    Hello Google, here I come.
    Never know. Thanks.
    Yamaha FJR 1300
  12. Mike Barnard
    Mike Barnard Guest
    Last Modified 13 Aug.00 Hmmmmmm...
    Yamaha FJR 1300
  13. Mike Barnard
    Mike Barnard Guest
    I want to do this right 1st time as it's a pain being off the road.
    Hehe, looks like a 10 mile cycle to work friday. :)
    Yamaha FJR 1300
  14. Mike Barnard
    Mike Barnard Guest
    But at the mo I can't see inside to see exactly what it attaches to.
    Ta anyway.
    This bit should be OK I suppose, I've driven seals in before in other
    bits of bike.
    Yamaha FJR 1300
  15. Mike Barnard
    Mike Barnard Guest
    Travel and / or postage will eat into a lot of time, unfortunately.
    Done this on an old 500 four in the 80's. Leaked a week after, so my
    skill set isn't top rated here! :)
    Only want to do it once so might as well get it now. But cheaper than
    £130!
    Yamaha FJR 1300
  16. Mike Barnard
    Mike Barnard Guest
    Tomorrow I'm trying to get my dealer to hit Yamaha for a goodwill
    tube. Gotta try.
    Yamaha FJR 1300
  17. Mike Barnard
    Mike Barnard Guest
    But I am so thats me fucked then. <Barman, half of shandy please, and
    easy on the beer.>
    Yamaha FJR 1300
  18. Mike Barnard
    Mike Barnard Guest
    Ins what?
    Yamaha FJR 1300
  19. Mike Barnard
    Eddie Guest
    Ah, I see. Ask your friendly local Yamaha dealer what their special
    tool[1] looks like.
    [1] Steady!
    Eddie, Jan 28, 2004
  20. Mike Barnard
    Mike Barnard said...
    I did the forks on my CB like this almost 2 years ago. They still don't
    leak and there's no sign of the filler material falling out yet.
    Lozzo, Jan 28, 2004
