Anyone got an un-loved Snottoiler
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Mar 14, 2006.
  1. <shakes tin>
    Spare a Snottoiler, guv?
    Anyone got one cluttering up a spider-infested corner of the garage?
    I think the GTS deserves one.
    Just not necessarily a new one.
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
  2. Wicked Uncle Nigel
    As it happens, I do. Can you wait until the BOSM?
    platypus, Mar 14, 2006
  3. Wicked Uncle Nigel
    'Hog Guest
    Checks the East for new stars
    'Hog, Mar 14, 2006
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    I can. Emma Chizzit?
  5. Wicked Uncle Nigel
    Couple beers. It's ex-Comfo, so you need to respect the heritage thing.
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    You are, indeed, a prince among Monotremes.
    You know that I, of all men, respect the heritage thing.
    I am obliged.
  7. Wicked Uncle Nigel
    It's among the spiders: not a proper place for it. I was thinking of
    putting it on the Z, but that might have taken years...
  8. In uk.rec.motorcycles, platypus belched forth and ejected the following:
    Whinging Courier, Mar 14, 2006
  9. Wicked Uncle Nigel
    The Distance Monster, the Kawasaki Kontinent Krusher, the mighty Z200.
    http://www.sweller.co.uk/sob/frunners.html
  10. if you could get it to Stattos by the 25th then we could bring it back
    East.
    Adie
    Triumph 955iSS / ZX9R E1 / GSF1200 bandit (for sale) / CG125
    Adrienne M Bonwick, Mar 14, 2006
  11. Wicked Uncle Nigel wrote
    Buy it a new one you pikey git.
    The one they have fitted to the Bloo GS is good. I asked for the
    touring version and they have plumbed in a tank behind the number plate
    that should keep my chain in surplus oil for years and years and years.
    Kin *HUGE* it is.
    steve auvache, Mar 14, 2006
  12. In uk.rec.motorcycles, platypus belched forth and ejected the following:
    Ah, right.
    I somehow imagined you had a big old Zed thou or one of the new ones,
    hence the question.
    Ta.
  13. Wicked Uncle Nigel
    Might have.
    Mine isn't very new. I don't see the point in them so I'd willingly
    allow it to move home assuming you came and removed it, fitted any
    blanking plugs required and threw a couple of bottles of decent beer
    in my direction.
    Andy Bonwick, Mar 14, 2006
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, Andy Bonwick
    I think I'm sorted with the monotreme, but thanks anyway.
  15. Wicked Uncle Nigel
    Some bloke made one out of an old ford fuel injector, a model aircraft
    tank and a model aircraft fuel filter.... plus a bit of small bore
    plastic pipe. Cheaper, and turns on / off with the ignition when the
    fuel injector is connected up properly.
    Plus, I found a better place to oil the chain, with less fling on the
    rear tyre. I put it dripping onto the top of the chain, just where it
    goes into the front sprocket cover. Still keeps the rollers oiled, and
    the o-rings from running dry.
    Muck, Mar 14, 2006
  16. In uk.rec.motorcycles, Muck belched forth and ejected the following:
    Or just spend 10 minutes doing the job properly with chain lube.
    I really don't know why people buy Scottoilers[1], a waste of money,
    imo.
    [1] They may be good for the terminally forgetful/lazy, but there's no
    substitute for doing it properly.
  17. Wicked Uncle Nigel
    Statto Guest
    Oi, Platy. Beers - when?
    Statto, Mar 14, 2006
  18. Whinging Courier wrote
    Yes all of that but in my case it was years of painstaking research
    reading ukrm and not finding any criticism from those that used them and
    finding plenty of praise instead. Additional anecdotal evidence about
    savings attained due to lack of chain and sprocket wear was also used
    when drawing my conclusion that simply using it for a few thousand miles
    will make a saving on the initial cost.
    But it does do it properly.
  19. In uk.rec.motorcycles, steve auvache belched forth and ejected the
    following:
    Ha! 27,000 kms later and I've NEVER adjusted the chain on my CBR[1].
    It's still got the correct tension and everything. I remember buying a
    can of Silkolene somethingorother at the same time as buying the bike -
    I lubed the chain after almost every ride/when it rained. 18 months that
    can of lube lasted me.
    [1] I've obviously had to adjust it because I've had the wheel out for
    tyre changes etc, but from an adjustment POV, I've not needed to move
    the squirelly fucker.
    It's getting close, mind.
    I don't see the point in spending 60 odd quid on something that I can do
    for free and costs me less that 5 quid a year.
  20. Whinging Courier wrote
    I do but you have to remember that I am not a big fan of chain drives
    anyway. The zero maintenance required by a shaftie is the kind of
    maintenance I approve of.
