Anyone got a bike trailer?
Discussion in 'UK Motorcycles' started by frag, Aug 7, 2005.
  1. frag
    frag Guest
    I may have need to bring a bike back to mine sometime next week.
    As my insurance don't cover me for any other bike (and I'd have
    problems riding any distance at the mo) does anyone local-ish to me
    (Milton Keynes) have a bike trailer I could borrow please?
    frag, Aug 7, 2005
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, frag
    I don't have a trailer, but I do have CIHAGM insurance, so I may be able
    to ride it back for you. Where from, and when?
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Aug 7, 2005
  3. frag
    Ovenpaa Guest
    Sometime around Sun, 07 Aug 2005 00:36:07 +0000, frag babbled on about:
    Yup, a shiny new one about 12 miles from CMK, and I even have a bucket
    load of straps as well, let me know if you need it.
    Ovenpaa, Aug 7, 2005
  4. frag
    frag Guest
    Wicked Uncle Nigel scribbled:
    Wakefield, just north of Barnsley.
    You is a man I need to see, I think, about knocking up a set of
    rearsets for the bike in question to move the pegs to a ridable
    position, if possible? <grovel grovel>
    When? Err, I will know by end of tomorrow, probably, but will let you
    know.
    It'll be good to have someone who can test ride it as well, and an
    impartial head to tell me to walk away if its a good looking lemon :)
    frag, Aug 7, 2005
  5. frag
    frag Guest
    Ovenpaa scribbled:
    Thankee very much, sire. An alternative solution has possibly been
    found but I'll definitely keep you in mind.
    Cheers :)
    frag, Aug 7, 2005
  6. frag
    tallbloke Guest
    If you want it given the once over before anyone does distance, I'm only 20
    mins drive from Waky.
    tallbloke, Aug 7, 2005
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, frag
    Bloody Hell. <Checks passport>.
    Yeah, should be do-able. Timing is, however, critical. Any idea when
    yet? I'm off to sunny Cornwall on Thursday.
    Not a problem, what bike is it?
  8. frag
    frag Guest
    tallbloke scribbled:
    Oooh, cheers.
    frag, Aug 7, 2005
  9. frag
    frag Guest
    Err, is that a long distance from you? If it is it'll prolly be easier
    to get tallbloke to give it the once over and borrow trailer to bring
    it back to mine.
    Mon/Tues/Wed. Pref the earlier of those.
    GSX1400 K3. The fat mans Bandit :)
    frag, Aug 7, 2005
  10. frag
    Monz Guest
    Just be careful with the rear shocks on those Frag, they have a tendency to
    bust the seals if you adjust them... before you buy it wind the preload up
    to full and back gently and give it 20 mins before checking for weeping
    around the top of the (adjustment collar) for want of a better description.
    I had one for 12 months and it went through three sets of shocks... they are
    prone to it. Suzuki wont admit there is a problem but they will send out
    replacement shocks forever.
    Monz, Aug 7, 2005
  11. frag
    Monz Guest
    PS I live in Barnsley if you get stuck for someone to ride it for you, but
    you would have to bring me back up here.
    Monz, Aug 7, 2005
  12. frag
    SteveH Guest
    To be fair, you are, erm, rather larger than Frag.
    SteveH, Aug 7, 2005
  13. frag
    frag Guest
    Monz scribbled:
    Interesting, thanks for the info.
    Probably worth bunging Ohlins on it at some point then.
    Was that 3 sets of shocks in one year from new? And which model was
    yours? K1/2/3?
    frag, Aug 7, 2005
  14. frag
    Monz Guest
    Did you not read the post? I said the shocks bust through adjustment and it
    is a known issue, Yes I am heavier than frag but probably only by 4 or 5
    stone... i.e. less than the weight of a pillion. You didn't think that one
    through very well did you?
    I have never met you, insulted you or even seen you though your opening
    remark to me is detremental about my weight.. you sir, are on the cunts
    list.
    Monz, Aug 7, 2005
  15. frag
    Monz Guest
    Mine was a K3 on a '53 and yes it went through 3 sets from new, the 02s were
    supposed to be the ones with the problem and they changed the shockers for
    the 03s but the problem still exists. Only manifests itself when adjusting
    the preload though. Can you believe that the head of the workshop asked me
    why I adjusted the preload if I knew it was going to make the shocks leak!
    Monz, Aug 7, 2005
  16. frag
    SteveH Guest
    I'm sure we have met.
    In any case. If that kind of flippant remark offends, have you ever
    thought UKRM isn't the place for you?
    SteveH, Aug 7, 2005
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique, frag
    I'm near Hitchin. About 20 miles south of you...
    I can do Tuesday, but I need a way to get Oop Norf. Alternatively, I'm
    in Lancashire on Wednesday on business (almost certainly by train). I
    *may* be able to figure out a way to get across to Barnsley and collect
    it if you can give me a lift home from MK to my place. If that's a goer
    I need to know tomorrow (Monday).
  18. frag
    frag Guest
    No probs. I'll know by tomorrow what's happening and let you know.
    Ta:)
    frag, Aug 8, 2005
  19. frag
    Greybeard Guest
    I might be a little late in this thread, I didn't spot it earlier. Sorry!
    I've got a bike trailer sitting here that can take 2 bikes, (3 trailies I
    think?) if it is any use.
    Saffron Walden, Essex, but I can hook it up and drag it somewhere ;o)
    Greybeard, Aug 8, 2005
