Anybody need a bike lift?
Discussion in 'UK Motorcycles' started by Timo Geusch, Mar 14, 2010.
  1. Timo Geusch
    Of the 'push under bike, then lift bike' variety, not a ramp. This one
    here, or at least an older model of it:
    http://www.machinemart.co.uk/shop/product/details/cml2-hydraulic-motorcycle-lift/path/vehicle-lifts
    Should be available around mid-April. Given what they are new, I'd like
    to see 60 quid for it[1].
    As usual, it's in Ashford, Kent.
    [1] For the usual pedantic cunts, that is "I'd like to see 60 quid for
    it in my wallet". Just waving it in front of my face is unlikely to
    have me release it to you.
  2. If it really lifts whole bikes safely[1] then I could be a customer.
    [1] I mean, is there any way of ensuring the bike doesn't topple off the
    thing? What have you lifted with it? I was just wondering about
    fully-faired things: fairings that run under the sump would have to be
    removed, I suppose.
    The Older Gentleman, Mar 14, 2010
  3. Timo Geusch
    zymurgy Guest
    That's a good price for a hydraulic lift (if that is what it is, I
    couldn't be bothered clicking the link ;)
    They're pretty stable once the bike is on it and lined up, especailly
    since the CofG is pretty low. It does have little straps for security,
    but clearly they're just for PFF's with no sense of danger.
    Dunno, probably. You can use the arms for the frame rails, as using
    the plate usually fouls the exhaust. I've had the FJ up on mine fore a
    while now,
    Paul.
    zymurgy, Mar 14, 2010
  4. Timo Geusch
    It has so far.
    Wait, what's that noise coming from the garage?
    If you get them on right, the smaller stuff will happily sit on it. For
    heavier bikes I tended to use a ratchet strap but that was more for
    piece of mind than anything else. Heck, I've had Motosports wobble on
    it without straps when I stripped them down for ebay. Mind you, the
    second one got strapped down...
    Most of the bikes in my garage. I *think* I've had the Hardley on it at
    some point as I distinctly remember buying the frame adapters for it.
    Yes. And I've always been wary of lifting bikes by the sump with it.
    Although I will have to do exactly that to get the front wheel out of
    the Laverda.
  5. It is, yes.
    Hm. Well, the Beemer wouldn't fit, I don't think. The Ducati would need
    the fairing removed. The 400 Four's exhaust would probably foul. Street
    Trip might be OK. Ditto the GN250.
    <Sucks teeth>
    Dunno, dunno.
  6. The Older Gentleman brought next idea :
    They are only really of use for an unfaired bike where the frame is the
    lowest point of contact and which has good clearance in the centre -
    better than 5".
    I bought one to lift my VFR. Even with the bottom fairing removed, I
    could only just squeeze it under, then I made a sub-frame upon which to
    actually lift it which needed even more clearance. So I had to start
    with the wheels of the bike on planks to get that extra clearance.
    It lifted it, but with a lot of faffing about. So I gave up on it, sold
    it and built one to my own design. I ended up with a single post lift
    with arms (two per wheel), on a frame and a small hand cranked 1 ton
    cable winch on top of the post. I just slide it under wheels and crank
    it up in seconds. A strap over the top keeps it firmly upright. It can
    lift with post on either side of the bike, and bracket adaptor fits
    under the main stand and allows me to lift it with either wheel
    removed.
    Harry Bloomfield, Mar 14, 2010
  7. Timo Geusch
    Salad Dodger Guest
    Not much use for any of my three - then again, the ramp is overloaded
    by 10-15kg with the wing on, and it does sway alarmingly.
    It now gets ratchet strapped to two hooks in the garage walls.
    The trouble is, the ramp takes up an awful lot of space, even if it is
    used to store a CBX.
    Salad Dodger, Mar 14, 2010
  8. Yeah, that rules out the 400 Four - the sump juts down well below the
    frame rails. Oh well.
  9. Timo Geusch
    Scraggy Guest
    You're not thinking ahead here, anything which could be used to, say,
    prop a wall or a roof even, may be damn useful. In the future.
    Scraggy, Mar 14, 2010
  10. Timo Geusch
    Simon Wilson Guest
    Simon Wilson, Mar 15, 2010
  11. Timo Geusch
    OK. Not in a massive hurry, as mentioned if you could collect by
    mid-April that'll be splendid.
    Easiest way to pick it up would be to also buy my Mercedes E280 estate
    and chuck it in the back :).
    Timo Geusch, Mar 15, 2010
  12. Timo Geusch
    Simon Wilson Guest
    Well ok.
  13. Timo Geusch
    Sorry, Elise is going to Germany by the looks of it. And there's not
    enough space in the passenger seat for the lift either.
    But I'll take 1500 for the Mercedes, thanks :).
  14. Timo Geusch
    Simon Wilson Guest
    Ah well.
    Erm, no ta.
    Can the lift be collected/UR'd -before- mid April, or do you need to
    hang onto it? I'm in no rush.
  15. Timo Geusch
    I can't understand why :).
    I'll need it one more time to drop the front wheels out of the Morini and
    Laverda to get new tyres fitted. I'm hoping that I get this done soon
    but it'll probably be the last w/e in March. Once that's done, the lift
    can be collected.
    Timo Geusch, Mar 16, 2010
