Anybody got a clever idea?
Discussion in 'UK Motorcycles' started by Timo Geusch, Nov 25, 2003.
  1. Timo Geusch
    .... how to unbolt the clutch reservoir lid on the Pan Euro? The fluid
    level appears to be a bit low, but the screws are well tight and seem
    to be made of cheese...
    Oh, and I dropped it today in the work carpark. Now all I need to
    learn is the proper technique of picking it up again.
  2. Timo Geusch
    tallbloke Guest
    Plastic lid?
    Phone a friend.
    tallbloke, Nov 25, 2003
  3. Timo Geusch
    Look pathetic and helpless until a strapping 6ft blonde Amazon goddess takes
    pity on you?
    Hog, Nov 25, 2003
  4. Timo Geusch wrote
    Angle Grinder.
    <snigger>
    steve auvache, Nov 25, 2003
  5. Timo Geusch
    Timo Geusch said....
    It's started, hasn't it?
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    http://www.glfuk.com/ for MJK Leathers in the UK.
    Lozzo, Nov 25, 2003
  6. Timo Geusch
    Spete Guest
    Pan=helpless and pathetic, so this must be a sure bet
    <fx: fires up biketrader>
    Spete, Nov 26, 2003
  7. Timo Geusch
    the force is strong in this one
    wessie, Nov 26, 2003
  8. Timo Geusch
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Timo Geusch
    Timo, Timo, Timo...
    Listen, I've got this Dymo thingy here. Seeing as it's you, I'll do you
    a favour.
    Ride the bike over here. I've got a label printed out for you. We'll
    stick it to the screen.
    It reads:
    "No user serviceable parts inside"
    There. Feel better now?
    Nigel Eaton, Nov 26, 2003
  9. Timo Geusch
    Lozzo was seen penning the following ode to ... whatever:
    The piss-taking? Yep...
    Timo Geusch, Nov 26, 2003
  10. Timo Geusch
    tallbloke was seen penning the following ode to ... whatever:
    Metal, I think. Of course, with the usual rubber parts underneath, so
    heating it up it not an option.
    Ask a security guard worked for me...
  11. Timo Geusch
    Nigel Eaton was seen penning the following ode to ... whatever:
    Sound plan. Your workshop equipment should easily be up to the task of
    removing the two screws.
    Buggeroff.
  12. Timo Geusch
    JB Guest
    <snip>
    Try covering it with a towel and pouring **HOT** water onto it from a kettle
    for about 5mins.
    Sounds crazy but it often works.
    Then replace screws with s/s ones and use copaslip.
    hth,
    JB
    JB, Nov 26, 2003
  13. Timo Geusch
    tallbloke Guest
    Piece of wood to support the bar end. Sharp smack with impact driver. If it
    shears the screws, at least you can get the lid off and wind the broken off
    threaded sections with mole grips. If it cheeses the screw slots, drilling
    is the only way....
    tallbloke, Nov 26, 2003
  14. Timo Geusch
    Ginge Guest
    .....and so it begins.
    Ginge, Nov 26, 2003
  15. Timo Geusch
    PanMan Guest
    Yes, Get angry!
    Reg
    (actually I can tell you how to pick it up but it's long winded)
    PanMan, Nov 26, 2003
  16. Timo Geusch
    NigelAtWork Guest
    Always an option, let me know if you need it.
    NigelAtWork, Nov 26, 2003
  17. Timo Geusch
    Robbo Guest
    Drill off the heads. Tap the cover off gently, remove all the fluid with
    rags carefully, clean out the reservoir, apply a HOT soldering iron to the
    ends of the screw that are left for a few mins, use mole grips and unwind
    them.
    BTDTGTTS
    Replace A.S.A.P.
    Picking up bike best left to someone that's strong then ;-)
    Robbo
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Nov 26, 2003
  18. Timo Geusch
    Alan.T.Gower Guest
    An impact screwdriver is your friend
    Alan
    http://www.ads-training.co.uk
    "Kneesliders Sponsored by Cane"
    GSX-R1000 , Triumph Thunderbird, ZXR750L2 Racer(gone), GS500,
    GHPOTHUF#27
    TGF, UKRMFBC#7, Two#24, BOTAFOF#11, YTC#9, GYASB#1. SbS#23.
    DFWAG#2, DS#2, DIAABTCOD#20. remove "thisbit" in the reply
    http://sportsbike.org (our own endurance team) http://Team-ukrm.com
    "Nemo repente fuit turpissimus"
    Alan.T.Gower, Nov 26, 2003
  19. Timo Geusch
    I've been told that S/S screws exacerbate the dissimilar metals problem.
    Oddly.
    Personally I've not had the problem and rely on *small* amounts of copper
    grease or loctite to prevent corrosion seizures.
    sweller, Nov 26, 2003
  20. Timo Geusch
    Robbo was seen penning the following ode to ... whatever:
    Even more reason to go to the gym again...
    Timo Geusch, Nov 27, 2003
