Any opinions on the Yamaha TRX 850?
Discussion in 'UK Motorcycles' started by Spike@Work, May 12, 2004.
  1. Spike@Work
    Linger Guest
    Put an R1 front forks and brakes and race cans,
    and you've got a fucking good bike. IMHO
    Bit slow, but good fun round a circuit.
    Linger, May 12, 2004
  2. Spike@Work
    Eddie Guest
    Surely you'll be wearing your leathers, and have your lid tucked under
    your arm? Even if you've come on the bus?
    Eddie, May 12, 2004
  3. Spike@Work
    A.Lee Guest
    On Wed, 12 May 2004 17:13:26 +0100, SteveH wrote:
    Snip about the merits of car oil/bikes/trx850
    I was looking for one last year, then a Duke 750 came up at the same price
    as TRXs were going for - £1500ish, and I got the Duke.Thats the best
    advice - save a little more/or wait a little longer, and a good Duke will
    come along.
    Alan.
    A.Lee, May 12, 2004
  4. Spike@Work
    SteveH Guest
    Depends on the car oil - some of the more exotic cage oils will do this
    due to additives, but a bog-standard, quality, semi-synth will do the
    job just fine in most situations.
    Not really, as above, it depends on the oil.
    I've used cage oil in loads of bikes over the years (GSX250, Z400J,
    Divvy 6, CBX750, TRX850 and the VFR) without any of the clutch hassles
    others have had. I put it down to using mid-range semi-synth oils.
    (And before Dan says anything, the Divvy made it to 80k miles before I
    sold it, mainly run on Homebase semi-synth)
    SteveH, May 12, 2004
  5. Spike@Work
    SteveH Guest
    Having ridden TOG's 750SS back to back against my TRX, I'd say it's
    definitely the best thing to do. Everything about the 750SS was better -
    engine (although down on power, it was just 'better', IYSWIM), frame
    (much lighter), suspension, riding position / comfort.
    Only downside of the 750SS is the regular cambelt changes - that's what
    originally put me off them. However, I reckon that if I bought one, I'd
    do the belts myself - I mean, if I can change the belt on a FIRE engined
    Fiat Cinq (how fucking tight is the access.....), then changing them on
    a 750SS where everything is accessible and visible has to be a doddle
    (famous last words.....)
  6. Spike@Work
    A.Lee Guest
    On Wed, 12 May 2004 19:02:46 +0100, SteveH wrote:
    Snip about Duke 750ss
    They really are a piece of piss to do.I did my MazdaMX6/Ford Probe V6
    cambelts last year and that took a weekend - the Duke was done in less
    than 2 hours, and when I do it next time I think it could easily be done
    in an hour.
    Alan.
    A.Lee, May 12, 2004
  7. Spike@Work
    SteveH Guest
    Good stuff.... just got to find a way of persuading SWMBO that I need to
    buy another bike.
  8. Basis of a good bike in that the frame is OK, the engine is pretty good,
    and it looks nice.
    The brakes, suspension, seat, and just about everything else is crap.
    The Older Gentleman, May 12, 2004
  9. Spike@Work
    (The Older Gentleman) struggled
    to ejaculate:
    The gearbox can go on the crap list too, imho. The two I had test
    rides on were both bastards to get into neutral and the first to
    second change was sooo fucking sloooow.
    Pip, May 12, 2004
  10. Spike@Work
    darsy says...
    At least you had the 2.5 litre[1], not the cooking model.
    [1] Basically a 944 without the arches.
    Lozzo, May 12, 2004
  11. Spike@Work
    Linger says...
    No you're not, and anyone who says otherwise is a twat whose advice is
    to be disregarded[1]
    Bike oils are designed specifically for bikes, they do not contain the
    anti-friction additives that will cause clutch slip in a wet clutch
    bike. Car oils are full of stuff that a bike's clutch will not like.
    Some wet cutches will slip even with a specific bike oil, case in point
    being the Aprilia RSV Mille and other Aprilias that use the same engine.
    These bikes should only use 15W/50 semi-synth bike oil, not a fully
    synth.
    [1] I say this as someone who has spoken at length to development people
    from a major oil company. I was selling their products and the whole
    bike oil vs car oil subject was a matter of discussion at a sales
    meeting.
    Lozzo, May 12, 2004
  12. Yep. No disagreement here.
  13. Every 12k, although 6k to be safe....
    And the belts are 14 quid each. So 28 quid a time. And yes, it's an easy
    job, except for the tensioning which *must* be done right[1]. There's
    the Ducati special tool, or there's the Ducati Expertise[2] which says
    "That's about right".
    [1] The belts must be slightly slack when cold as the engine expands
    when hot and tightens up the belts. Get them too slack and they jump
    when cold. Get them too tight and they snap when hot.
    [2] Which, to be honest, I don't have. Yet.
  14. Spike@Work
    Salad Dodger Guest
    Every 12k, although 6k to be safe....[/QUOTE]
    Every 100k on a GL1500. :)
    | ___ Salad Dodger
    |_\_____/_| ..64741../..15361.../..3157./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:14 Pts: 270 Miles:1248
    Salad Dodger, May 12, 2004
  15. Salad Dodger said:
    <tempted>
    Every 90k on the Pan and I'm getting fed up with changing the belt every
    five minutes.
    Simon Atkinson, May 12, 2004
  16. Spike@Work
    Linger Guest
    Shocker: Linger finally shows he knows something about bikes!
  17. Spike@Work
    SteveH Guest
    There's also plenty of bike mechanics who will say otherwise, too.
    ISTR it was Tuppy who asked me (when out getting the bits to service the
    TRX) - 'Do you want your oil with a picture of a bike or a car on the
    bottle.... it's all the same, but you pay double for the picture of a
    bike'
  18. Spike@Work
    Mark Olson Guest
    What about 15W-40 commercial diesel oils like Shell Rotella, Mobil Delvac
    1300, and Chevron Delo 400? No anti-friction stuff in them AFAIK. These
    are USA market names, I don't know what they are branded as in the UK.
    Swot I use in my bikes, with no clutch slip problems (but TBH, I wouldn't
    expect any, with the limited HP on tap). A gallon of any of them costs
    about $7 (£4) at Wal-Mart.
    Mark Olson, May 12, 2004
  19. Spike@Work
    SteveH says...
    Different people, different opinions. I made my mind up on the advice of
    someone who develops oil specifically for bikes. You use wtf you like.
    Lozzo, May 12, 2004
  20. Spike@Work
    SteveH Guest
    This would be someone who had an interest in encouraging people to buy
    bike-specific oil would it not?
