Any one got a K1200S
Discussion in 'UK Motorcycles' started by Peter, Mar 30, 2006.
  1. Peter
    Peter Guest
    Just bought one and love it. best bike I have ridden so far. The ESA is the
    dogs.
    Anyone of you lot got one or getting one.
    Peter
    Peter, Mar 30, 2006
  2. Peter
    No and no fucking chance. They're dog slow, handle like a hippo on
    acid and look like roadkill.
    Andy Bonwick, Mar 30, 2006
  3. Peter
    .. Guest
    Should suit you sir...........
    .., Mar 30, 2006
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    True. Very true.
    What a great bike.
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
    Wicked Uncle Nigel, Mar 30, 2006
  5. Peter
    Wicked Uncle Nigel said...
    Hurrah for BMW[1]
    [1] ****, but it hurt to type that.
    Lozzo, Mar 31, 2006
  6. Peter
    Never mind. I've just realised that my Italian car has been more reliable
    than my German bike. And it's done more miles.
    platypus, Mar 31, 2006
  7. Peter
    deadmail Guest
    Well...
    My 1985 K100RT has now done 109,000 miles. I've done 52,000 of these in
    the last three years.
    In that time I've broken down twice, unfortunately once in France, due
    to a problem with the fuel pump wiring.
    I've replaced the front disks once (and I think I need to do it again)
    and the rear disk once. I've replaced the rear master cylinder.
    The starter solenoid has been replaced, as has the 'load shedding relay'
    (a normal relay 3 quid from an autoparts shop).
    It's needed the gearbox/clutch/bellhousing removed to fix a problem with
    the starter; the problem on reflection was probably caused by my using a
    too heavy oil in the winter.
    I needed to replace the coils this winter since it wasn't running right
    when cold and wet.
    Currently the temperature sensor is fucked and I've not found time to
    fix it so it's running rich (at least I assume that's why adjusting the
    mixture screw doesn't change the CO output.)
    Apart from replacing tyres and servicing I think that's it.
    All in all, not too bad for a 20 year old bike which is used in all
    weathers and only cost 1250 when I bought it.
    Unfortunately I think the K100s are drying up, there seem to be fewer
    and fewer clean low (less than 70k) mileage ones around.
    Still, I've got the K1100LT for the summer (once I've got it put back
    together) and since it's only done 40k it's barely run in.
    deadmail, Mar 31, 2006
  8. Peter
    The Fuglipla has done about 75K over the last four-ish years, had annual
    servicing and the occasional wash, and hasn't broken down at all.
  9. Peter
    deadmail Guest
    Come back when it's 18 years old and repeat that feat.
  10. Our Morris Minor is 41 years old and can repeat that feat..
    Phil
    Phil Launchbury, Mar 31, 2006
  11. Peter
    deadmail Guest
    It's not broken down or needed any significant repairs in 75k miles over
    four years?
    Blimey, better than new then.
  12. Well - maybe not 4 years - its done 75K miles in 40 years without a
    significant breakdown[1]. Mind you the engine only makes 27bhp so it's
    hardly mechanically stressed..
    Phil.
    [1] Still on original engine & suspension. Underbody chassis has been
    rebuilt at some point[2] but most of the mechanicals and bodywork are
    original[3].
    [2] They all need that Sir
    [3] Well - we did get servo brakes installed and it has a heated rear
    screen..
  13. Peter
    Good point. Maybe they're not all bad then.
    Andy Bonwick, Mar 31, 2006
  14. Peter
    I don't think so. I'm not anti BMW but that's one model I wouldn't
    even consider.
