Any ideas
Discussion in 'UK Motorcycles' started by Paul Corfield, May 22, 2011.
  1. Paul Corfield
    prawn Guest
    Many moons ago, I was having a conversation with a partner of a law firm
    on the durability of archive media. He reckoned that ink on vellum was
    the gold standard.
    prawn, May 25, 2011
  2. Paul Corfield
    Colin Irvine Guest
    I assume you mean online somewhere.
    Colin Irvine, May 25, 2011
  3. Paul Corfield
    Naah, maan ... in da clowd, innit!
    Pip, May 25, 2011
  4. Ok storing it in da cloud until da wind comes and blows it a way
    steve robinson, May 25, 2011
  5. Paul Corfield
    Catman Guest
    This appears to be solely electronic failure. None of my systems here
    even recognise its existence.
    #www.cuore-sportivo.co.uk
    Catman, May 25, 2011
  6. Paul Corfield
    Catman Guest
    Apples and oranges, though. If you keep a computer disc in ideal
    circumstances, it'll last a long time (depending on what we mean by
    disc, natch). But, we tend to keep using them. Akin to constantly making
    prints off the negative. Which will shorten the life considerably.
    What the absolute numbers are, though, I have no idea.
  7. Paul Corfield
    Higgins Guest
    Higgins, May 25, 2011
  8. Paul Corfield
    Krusty, May 25, 2011
  9. Paul Corfield
    David Guest
    That's something I wouldn't recommend, for a couple of reasons. First,
    it's all very well having 2 HDDs in that box with copies of the data
    on, but nothing else will be able to read those drives. What happens
    when the box itself fails, and is an obsolete model so you can't just
    buy an identical one.
    Second, IME RAID is not as foolproof as it should be. I've come across
    far too many cases where for some reason or other (dodgy firmware, or
    just operator error) instead of recovering from one drive failing,
    it's just trashed the good drive. IMHO RAID is good where you have
    servers that you really don't want to go down at all, but it's not an
    alternative to backups.
    I have a similar device to the LaCie one (a DLink Sharecenter Pulse -
    half the price, but seems to do what I need) but I was careful to
    choose one that let you access the 2 drives as separate shares rather
    than using RAID or JBOD. I back up each drive to a USB drive, and I
    also have the reassurance that each drive has a standard ext3 format
    so if the NAS dies I can get at the data from a Linux PC.
    Can't argue with this (except to mention the other golden rule of
    backups: test them regularly. Are you sure that drive that's been
    carried around in a rucksack every week for 2 years is still working
    fine?)
    David
    David, May 25, 2011
  10. Very dead hard drives are usually the board and not the data platters.
    Buy the same drive on ebay and swap controller boards if getting data
    back is a priority. I've done it a few times with good results.
    Fraser
    Fraser Johnston, May 26, 2011
  11. Paul Corfield
    Ben Guest
    Yes. Not random ukrmer's garages.
    Ben, May 26, 2011
  12. Paul Corfield
    Catman Guest
    Hmm, that might well be a plan, in fact.
    Given that I can hear / feel the drive spinning up and the heads
    calibrating.
    What do you fancy Paul? No promises on timescales, though....
    Catman, May 26, 2011
  13. Paul Corfield
    Simon Wilson Guest
    I always thought that there were specific things tweaked on each board
    to match the drive heads etc. and that this wouldn't work. It certainly
    sounds like it would be worth a try though. Post the results[1].
    [1] I don't mean the pictures, obv.
    Simon Wilson, May 26, 2011
  14. Paul Corfield
    Hog. Guest
    Nothing else. Bollocks it's a linux system
    Gee I guess we are really exposed keeping terabytes of customer data on
    raid, flashed up to a backup raid on the san
    The La Cie looks lovely sitting on a shelf though. I think the OP has some
    sence of asthetics.
    I used to also put stuff on double density DVD's just in case. Then I left
    one on a window sill for a month to check the effects. Not only did the UV
    trash the disk but some sort of corrosion set in between the plasic and
    metal layers.
    Hog., May 26, 2011
  15. I don't mind you giving that a go as I assume it's a cheaper interim
    option than sending the thing away. I assume, therefore, peak hour
    collection at Epping is now postponed?
    Paul Corfield, May 26, 2011
  16. It's become trendy to refer to the cloud, donchanow?
    I was talking to a self-confessed IT numpty (as in, I don't know and I
    don't want to know, I just want it to work, numpty) and he was
    offhandedly referring to 'the cloud'. Aha, he really meant his gmail
    account.
    ffs.
    Grimly Curmudgeon, May 26, 2011
  17. Paul Corfield
    Jim Guest
    I think for a lot of people it's more like a fog.
    Jim, May 26, 2011
  18. Paul Corfield
    Catman Guest
    We can postpone. It's really likely to be some time before I make much
    progress. Next weekend at the earliest, if that's OK
  19. Paul Corfield
    David Guest
    OK, not nothing else, but you know what I'm getting at. If you're
    lucky, you might be able to get at the data with a lot of fiddling
    around with mdadm, dd, etc. If you're unlucky and the NAS maker
    decided to do things in a slightly non-standard way, you'll need to
    reverse engineer the logical volumes on the disk, or hope the NAS
    manufacturer has open-sourced their proprietary drivers.
    Or you could just keep the disk in a standard format.
    So you use RAID to ensure your servers stay online as much as
    possible, and backups for when that goes wrong? And I'd guess probably
    tape backups off the SAN to give an extra layer of protection and to
    keep something off site? If you're trying to use that as a
    counterexample to what I said, you ought to read what I said more
    carefully.
    Anyone who pays double the price just for the sake of aesthetics is,
    by definition, a Mac lover, and therefore doesn't need advice on
    backup devices because Steve Jobs will have sold them a Time Capsule.
    David
    David, May 26, 2011
  20. Paul Corfield
    David Guest
    The company I work for (not just the MD and sales people, even the
    developers who are developing it) insist on describing our next
    generation product as "cloud-based". No, it's running on one of the
    servers downstairs.
    But as long as our clients are happy to pay a premium for a less
    functional, less reliable product because the sales people throw in
    the buzzwords they want to hear, who cares?
    David, May 26, 2011
