Antifreeze
Discussion in 'UK Motorcycles' started by Mark, Feb 26, 2006.
  1. Mark
    Mark Guest
    Apart from the obvious (1) is their difference between blue and green
    antifreeze?
    (1) colour
    Thanks,
    Mark
    Mark, Feb 26, 2006
  2. Mark
    Mark scribbled on the back of a napkin:
    Read the list of ingredients?
    Some of the more expensive stuff is longer-lived than the cheapo,
    change-every-year stuff.
    Green one tends to have BASF Glysantin in which I've been using for,
    oh, fifteen years at least. Works for me and is longer-lived than the
    normal carp.
    Timo Geusch, Feb 26, 2006
  3. In uk.rec.motorcycles, Mark belched forth and ejected the following:
    The taste.
    Whinging Courier, Feb 26, 2006
  4. It should tell you on the labels on the containers
    Steve Robinson, Feb 26, 2006
  5. Mark
    deadmail Guest
    Which is best to add to wine?
    deadmail, Feb 26, 2006
  6. In uk.rec.motorcycles, belched forth and ejected the following:
    Green in white.
  7. Mark
    Mark Guest
    in message
    : It should tell you on the labels on the containers
    Ok the same question worded differently...........is the blue ethylene
    glycol antifreeze with corrosion inhibitors suitable for a Honda Blackbird?
    Mark
    Mark, Feb 26, 2006
  8. Mark
    R obbo Guest
    So that's what Koi live in then is it?!?!?
    R obbo, Feb 26, 2006
  9. Mark
    Should be - you need the corrosion inhibitors and it's got to be
    suitable for use in an alloy engine.
  10. To quote Zog the Undesireable...
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
    Grimly Curmudgeon, Feb 26, 2006
  11. Yes just looked in my handbook
  12. Mark
    Stritchy Guest
    Yes it's fine.
    I always also use distilled/deionised water as well, rather than
    ordinary tap water.
    Stritchy, Feb 26, 2006
  13. Mark
    Stritchy scribbled on the back of a napkin:
    Actually that may not be such a good idea as any *decent* antifreeze
    contains additional chemicals to neutralised all the harmful crap
    that's in tap water...
  14. Mark
    Stritchy Guest
    Surely it's better not to have the harmful crap in there to start
    with?
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Stritchy
    Ah, a common misconception (oft repeated in manufacturers' guidance).
    What happens is the additional chemicals attempt to remove the harmful
    crap (hc) from the distilled/deionised water, *but there's none there*.
    This creates so called "dark" or "negative" hc (dhc, or -hc depending).
    This is seriously bad juju. Some believe it is what holds the Universe
    together. Other believe it's what blocks all the little coolant
    galleries[1]. Some believe it eats your soul. But they're just being
    silly[2].
    Whatever, one -hd or dhc has infested your engine, it's fucked.
    I'll give you a tenner for it.
    [1] Will nobody think of the coolant galleries?
    [2] You ride a Pan; you have no soul.
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
    Wicked Uncle Nigel, Feb 26, 2006
  16. Mark
    Stritchy Guest
    Being a man upon whom the God's consistently smile - I believe every
    word that you utter.
    Following your advice, in future I'll use only rainwater. I wouldn't
    want to upset the balance of the universe, it obviously took you a
    while to get it into this finely honed state.
    Will that be tenner be cash or cheque?
    The only soul I have is an arsesoul (© John Gordon Sinclair, on
    Petrolheads, to the Hamster) Made oi larf.
    Stritchy, Feb 27, 2006
  17. Mark
    I've never put antifreeze in any vehicle I've ever owned.
    Is it important?
    darsy, Feb 27, 2006
