Antifreeze Freezing Point?
Discussion in 'UK Motorcycles' started by Tosspot, Jan 14, 2009.
  1. Tosspot
    crn Guest
    Common mistrake.
    Draining the radiator actually drains less than half of the total coolant,
    the rest is still in the block. Top up with 50% mix giving a total coolant
    antifreeze content of around 20%.
    Some, but not all, engines have a drain plug on the block for this reason.
    crn, Jan 15, 2009
  2. Tosspot
    crn Guest
    You are misunderstanding the meaning of windchill.
    Windchill is the effective cooling on a hot human body. It cannot make
    things colder than they already are, it just speeds up cooling.
    crn, Jan 15, 2009
  3. So why does my freezer read -20 C , wind is passed over viens to cool the
    applaince
    Similar application to a car
    steve robinson, Jan 15, 2009
  4. Tosspot
    See, now you're starting to get the hang of this Usenet thingy - first
    wait until at least half-a-dozen other people have made a point, then
    post the same thing yourself to make it look like you knew it all
    along.
    Congratulations.
    Ace, Jan 15, 2009
  5. Tosspot
    Because the air is at -20C, obviously.
    Duh.
    Ace, Jan 15, 2009
  6. Tosspot
    Eiron Guest
    Because that's not how a refrigerator works.
    Eiron, Jan 15, 2009
  7. Tosspot
    Every day's a school day. My mistake.
    sweller, Jan 15, 2009
  8. Tosspot
    Higgins Guest
    Only similar in as far as warm things are cooled down.
    Higgins, Jan 15, 2009
  9. Tosspot
    crn Guest
    Nice theory, but none of the replies were on my system at the time that
    I replied. Just a common usenet propagation issue when a whole flock of
    people reply to the same thing.
    Do I really need to explain how usenet works ?.
    crn, Jan 15, 2009
  10. Tosspot
    Why, did you invent that too ;-?
    Ace, Jan 15, 2009
  11. Tosspot
    crn Guest
    Nuffink to do wiv me guv, I was too busy inventing the wheel <B-).
    RFC 977, 2980, 3077, 4644 all make interesting bedtime reading for
    geeks though.
    crn, Jan 15, 2009
  12. Tosspot
    No. Fridges are 'heat pumps'. You'll find that the condenser (those
    external vanes) are really very warm or even hot when it's pumping;
    it's the temperature difference between them and the surrounding air
    that allows heat energy to be dumped into the environment.
    As the song goes:
    # You can't pass heat from a cooler to a hotter
    # you can try it if you like but you'd far better not-a
    Pip Luscher, Jan 15, 2009
  13. Bluecol never was as good as it claimed, that's true. I always used
    50/50, but never believed it would protect to the minus temp Bluecol
    said it would.
    Grimly Curmudgeon, Jan 16, 2009
  14. Do you really think Pip didn't know about block drains taps/plugs?
  15. Or (more accurately) doesn't perspire. Or have a moist skin for the air
    movement to induce chilling in through evaporation.
    Phil
    Phil Launchbury, Jan 16, 2009
  16. Tosspot
    crn Guest
    The symptoms indicate otherwise.
    But ICBW.
    crn, Jan 16, 2009
  17. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    Might I suggest that you change your posting name?
    Wicked Uncle Nigel, Jan 17, 2009
  18. Tosspot
    I'll repost para #9 for your benefit:
    "Having said that, when I reinstalled the radiator early the next
    morning there was a patch of blue ice on the already-iced driveway,
    culminating in a little blue twisty stalagmite pointing at the engine
    block drain tap."
    The clue is in the last four words.
    Pip, Jan 17, 2009
  19. Tosspot
    crn Guest
    OK, fair cop guv, but if you read the snipped bits I did start with
    the words "Common error" implying thaT I was addressing the general
    case rather than the specific.
    crn, Jan 17, 2009
