Antifreeze Freezing Point?
Discussion in 'UK Motorcycles' started by Tosspot, Jan 14, 2009.
  1. Tosspot
    Tosspot Guest
    It hit around -20 a few days back, and to be honest, it's been far too
    cold for motorbiking since Jan. However, it has just occurred to me
    to wonder would the coolant have frozen at that temperature?
    Does anyone know the concentration of antifreeze/water that is
    commonly used, cos I guess if they use the 'ideal' proportions it's
    good down to -stupid.
    Any thoughts?
  2. Tosspot
    http://letmegooglethatforyou.com/?q=commercial+antifreeze
    wessie, Jan 14, 2009
  3. 50/50 coolant water
    steve robinson, Jan 14, 2009
  4. Tosspot
    Tosspot Guest
  5. My handbook for the car reckons 50 50 mix is good down to minus 20 C
    The blucol web site reckons 50 50 mix is good to minus 34
    they recomend you never have a concentration higher than 70% antifreeze 30
    water
  6. Tosspot
    Tosspot Guest
  7. Tosspot
    Tosspot Guest
    It was that -20 number I had in the back of my mind. Oh well,
    probably find out halfway down an autobahn :(
  8. Tosspot
    when servicing my own vehicles I used to use a large syringe to extract
    some coolant from the rad. Bung the coolant into a freezer. Leave
    overnight. If the coolant was still liquid then I assumed it would be okay
    down to whatever nature was going to throw at us. If there was any sign of
    crystal/jelly then I simply added a litre of *neat* antifreeze to the rad.
    This worked throughout the series of very cold winters we had in the early
    1980s.
  9. Tosspot
    I use a 30-50 mix depending on how much anti freeze I have to hand and
    how big the cooling system is.
    From what I remember the real killer for cooling systems is not the
    static temperature in a garage for a laid up vehicle but the just started
    up and being driven wind chill factor through the radiator before the
    thermostat has opened fully.
    IIRC, the Allegro (or some other BMC thing, the Maxi?) had a feed/bypass
    pipe running under the radiator that would freeze and split in fairly
    benign temperatures due to windchill.
    sweller, Jan 14, 2009
  10. Tosspot
    My dad had a Maxi for years. He never had a problem with it freezing. It
    got a bit hot when some idiot was driving it and didn't notice the temp
    guage in the red. That needed a new water pump. I think it was pure
    coincidence that the car needed a new engine within a few weeks.
  11. Tosspot
    What's the other 20?
    Champ, Jan 14, 2009
  12. Tosspot
    air: you don't think he has a perfectly sealed system do you?
  13. Tosspot
    I hadn't noticed my % key's indolent ways until after I'd pressed send.
    sweller, Jan 15, 2009
  14. Tosspot
    When I lived on the NE coast I had a windchill experience (well, I had
    several, but the rest aren't important right now) with my 1965 Humber
    Sceptre. The Humber had a tweaked motor from a Hunter GLS and I'd
    acquired a hyuuge radiator from somewhere, that had the most beautiful
    brass top tank (polished, natch) which had doubled the amount of
    coolant in the system and obviated the 'getting a bit warm' tendencies
    previously suffered.
    It must have been the winter of 1980/81 when it got particularly
    chilly. The coolant was 50/50 Bluecol (only the best) and water and I
    checked under the bonnet each morning as a matter of routine. This
    particular morning it had got down to something like minus ten on the
    mercury and it felt distinctly chilly. I popped the bonnet and
    squeezed the top hose: Hmm, slightly crunchy but not bad at all,
    considering.
    I got the thing ticking over while clearing enough glass to see
    through, then set off to work. It was only five miles or so, but most
    of that was along the Coast Road overlooking the sea, along the tops
    of the cliffs, in a half-a-gale. By the time I got to work, the
    needle in the temp guage was a bit higher than expected (like, not
    lying at the bottom) and there was a bit of steam from under the
    bonnet when I parked. Popped the bonnet and all looked well enough.
    It froze solid all day and there were shenanigins in the car park,
    getting people moving. Frozen-on handbrakes, that sort of thing. The
    old Humber seemed all right - coolant level good, still liquid, that
    sort of thing.
    On the way home the little red needle came up the temp guage, quivered
    about a bit, then went down again - then came right back up before
    dropping down hard. I knew what that meant - it was trying to read
    the temperature of the air in the top housing where the sensor lived.
    Bollocks.
    It was a little steamy when I got home, so I thought I'd best do
    something about it. The top hose was empty, the bottom hose frozen
    solid. The radiator was hot to the touch at the top tank (although
    bereft of coolant) and damned cold down the core.
    After dinner (it was bloody cold by then) I removed the radiator,
    noting the weight of the bloody thing, and propped it up in an old
    washing-up bowl in front of the fire in the living room. After a
    couple of hours the rad was a lot lighter and there was a lot of blue
    liquid in the bowl.
    My 50/50 Bluecol solution had given up on me. The weatherman on the
    box stated a minimum daytime of minus 13, whereas the back of the
    Bluecol bottle reckoned 50/50 was good for at least minus 25. Hmm.
    That'll be windchill, then.
    Having said that, when I reinstalled the radiator early the next
    morning there was a patch of blue ice on the already-iced driveway,
    culminating in a little blue twisty stalagmite pointing at the engine
    block drain tap.
    Seven litres of 70/30 Bluecol/water (made with hot water) seemed to
    sort it, mind. But that was *bloody* cold that Winter, and the
    half-a-gale with inbuilt snow flurries didn't help, not at all. I
    took the Old Man's advice after that and installed a radiator blind
    made from cardboard.
    On a non-numbered footnote - there's a strange thing with antifreeze,
    you know. I know it has "seeking" properties, but it has become
    painfully obvious to me that if you have a cooling system running on
    plain, 'free' tap water (as I often did on the old bangers I ran then,
    as water pumps, thermostats and head gasket changes always required
    the coolant to be dropped and thrown on the deck) there's nary a leak.
    Put expensive antifreeze in the system and the leaks started then.
    Every bloody time.
    Pip, Jan 15, 2009
  15. Tosspot
    Eiron Guest
    That'll be total bollocks, then.
    If it's -13C and a gale blows through your radiator, it will still be -13C.
    You need to find a different explanation for your problems.
    Eiron, Jan 15, 2009
  16. Tosspot
    eh?
    If the temp is, say, -15 and the speed of the vehicle is 60 mph then the
    windchill effect on the radiator is -32 Cel.
    http://en.wikipedia.org/wiki/File:Windchill_chart.GIF
    How the **** do you think car cooling systems work?
  17. Tosspot
    DozynSleepy Guest
    You learn something new every day !
    I guess it's a form of anthropomorphism.
    It appears that wind chill on inanimate objects only shortens the time
    to cool. The inanimate object will not cool below the actual air
    temperature.
    DozynSleepy, Jan 15, 2009
  18. Tosspot
    CT, Jan 15, 2009
  19. Tosspot
    Did you read the article the chart came from?
    "Wind chill is the apparent temperature felt on exposed skin"
    What that means is if it's -15, but there's a 60 mph wind, then it will
    /feel like/ -32. It doesn't mean it's /actually/ -32. See this link from
    the same page:
    http://weatherquesting.com/wind-chill.htm
    Thermal gradient. If the contents of the radiator were at the same
    temperature as the surrounding air, then no further cooling would take
    place, no matter how fast it was going.
    platypus, Jan 15, 2009
  20. Tosspot
    Eiron Guest
    See that dot in the distance? That's the point, and you completely
    missed it.
    The OP said that his radiator froze because it got below -25C when the
    ambient temperature was -13C and the wind was passing through it, which
    is incorrect. He obviously didn't have as much antifreeze as he thought
    so the radiator froze at a higher temperature than -13C.
    Eiron, Jan 15, 2009
