Anti-theft device entraps brainless owner
Discussion in 'Classic Motorbikes' started by A.Clews, Apr 3, 2006.
  1. A.Clews
    A.Clews Guest
    OK, so I bought a disklock for my 900 Trident last week. Not used one
    before.
    You know what's coming.
    Yep, I forget that I've put it on, and the bike lurches to a halt as I start
    to move off from the office parking bay. OK, harmless enough, you might
    think, just remove the disklock and carry on my way. That's when I
    discover that the disklock has sliced clean through the speedo cable as it
    comes out of the hub. Bollocks. Luckily it doesn't seem to have done any
    other damage, though it did come up against the brake caliper.
    I did also discover that the rear brake is binding. The bloody disk was
    pretty much red hot when I got home, and the caliper too. Am I likely to
    have done any damage? Will the brake fluid need changing if it's been
    overheated?
    <hangs head in embarrassed shame>
  2. Yep. Anybody who's never done that simply hasn't done it yet, or a liar.
    It's fucked; I'll give you a tenner for it.
    Brake fluid is amazingly resistant to being cooked. You could change it
    if you want, but it'll probably be ok.
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
    Grimly Curmudgeon, Apr 3, 2006
  3. I've done it. The only time I ever used a disc lock. After that, I gave
    up on them.
    The Older Gentleman, Apr 3, 2006
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    I've never used a disk lock, because I *know* I'd do it.
    Wicked Uncle Nigel - To stay young requires unceasing cultivation of
    the ability to unlearn old falsehoods.
    Wicked Uncle Nigel, Apr 3, 2006
  5. A.Clews
    One just needs the long yellow plastic string that stretches up to the
    ignition lock.
    Hog, Apr 3, 2006
  6. A.Clews
    Roger Hunt Guest
    It was a chain through the rear wheel when I did it.
    Roger Hunt, Apr 3, 2006
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Hog
    And a brain. A brain would be handy.
  8. Mine was a big fuckoff chain through the front wheel. And I set off with
    a pillion on board. Came to a halt on full revolution of the wheel and
    both of us fell off to the right.
    GS850x2 XS650 SE6a
    Grimly Curmudgeon, Apr 4, 2006
  9. A.Clews
    <rummages>
    Hog, Apr 4, 2006
  10. A.Clews
    A.Clews Guest
    Thus spake Hog () unto the assembled multitudes:
    <also rummages>
    No, can't find mine either.
    So, what about my rear disc and caliper then? Will cooking them have done
    any harm? What's the likely cause of binding? Seizing piston perhaps?
    Ta.
    A.Clews, Apr 4, 2006
  11. A.Clews
    Steve Parry Guest
    It's not half as embarressing as popping a wheelie on my Z1000 MkII to an
    admiring crowd of youngsters .... then whilst aloft realising the steering
    was locked ........ bollox ....crunch ..... pain .... pride denting ...
    Steve Parry
    K100RS SE & F650
    http://www.gwynfryn.co.uk
    Steve Parry, Apr 4, 2006
  12. A.Clews
    Mike Guest
    I have been following all of the replies to this 'very honest' admission and
    can offer a suggestion for any 'out of the ordinary' situation.We are all
    creatures of habit and put our keys in the same place/pocket every time for
    example, so if you need to remember something, like take the disclock off
    first before driving away, put your keys somewhere different. Always the
    jacket pocket? Make it the trouser pocket. Dive down the jacket pocket, no
    keys, why? Ah yes. If I have to remember something before I go out I put the
    keys in an odd place. 'Remember to take a bottle of cold water with me. Keys
    in the fridge'!!!
    Works, honest, especially if you out the keys somewhere really out of the
    norm. 'In the lining of your crash hat'!! Ouch .... you will remember!!
    Mike
    ex Lambrettas and Matchless G9
    Mike, Apr 4, 2006
  13. I've not - yet - but I always keep an old plastic 35mm film cannister
    on the lock when not in use and on the ignition when it is.
    That is foolproof until some s*d nicks my film cannister...
    Chris D
    Chris N Deuchar, Apr 4, 2006
  14. Unlikely. They're designed to be able to run bloody hot, and the amount
    of heat that reaches the caliper and piston isn't as much as you would
    think, a lot of it being radiated/conducted away.
    More than likely. [1] If you have to strip it right down, you have to
    replace the seals in any case. It's fairly common for a piston to stick
    on enough to really heat the disc up and the seals will be ok, so if you
    find that just cleaning the piston up and lubing it cures your problem
    (but without removing the piston entirely), you can keep the old seals
    in place.
    [1] If it's a sliding caliper it might be sticky/worn pins/sliders.
    GS850x2 XS650 SE6a
  15. A.Clews
    A.Clews Guest
    Thus spake Champ () unto the assembled multitudes:
    That's a good thought, and ironically, I normally do park my bike 'front
    first' in my usual spot here at work. Yesterday I had to park elsewhere due
    to resurfacing work, and for some reason parked 'back first'.
  16. A.Clews
    A.Clews Guest
    Thus spake Steve Parry () unto the assembled multitudes:
    On my Trident the steering lock is part of the ignition switch, so it's
    impossible to start the bike without unlocking the steering. I remember the
    independent steering lock on my earlier bikes though.
  17. A.Clews
    A.Clews Guest
    Thus spake Grimly Curmudgeon () unto the assembled multitudes:
    I feel sure that had I been riding in the dark, my rear disk would have
    been glowing. I have a burn scar on my finger from testing it - *ouch* -
    when I got home...
    Forgot to mention also that I had a bloke frantically beeping me and
    gesticulating when he saw the severed speedo cable hanging out of the
    instrument console and behind the wheel. He presumably thought it was a
    brake hose ;-)
    Thanks for the advice. I'll check it out when I find some time.
  18. A.Clews
    Roger Hunt Guest
    ! Wonderful! :)
    Roger Hunt, Apr 4, 2006
  19. I had that on a ShiteOldTransit. When I parked up in the dark and looked
    back, the dull red glow of the disc could be clearly seen.
    Aha, always wet your fingertip first.
    GS850x2 XS650 SE6a
  20. A.Clews
    Roger Hunt Guest
    Same on a Vauxhall Nova after an MOT, where they were so enthusiastic
    with the brake test some muck inside was moved and jammed the piston.
    It took a Stilson wrench to twist it out, but apart from a huge build-up
    of muck the caliper and piston were in very good nick.
