Anti-coriolos effect device for Guzzis
Discussion in 'Australian Motorcycles' started by Theo Bekkers, Nov 21, 2005.
  1. Theo Bekkers
    Theo Bekkers Guest
    Does this mean that Guzzis will now be able to wheelies?
    "REACTIVE DRIVE SHAFT" TRANSMISSION
    Patented reliability.
    The most significant technical innovation is reactive shaft drive, patented
    by Moto Guzzi under the name 'CA.R.C.' ('Cardano Reattivo Compatto' -
    Compact Reactive Shaft Drive). The new patented drive shaft is incorporated
    inside the aluminium alloy swingarm. The pinion gear and the drive shaft are
    free to oscillate inside the swingarm and the drive shaft is equipped with
    two universal joints with built-in torsional dampers for optimum
    transmission response.
    The main benefit of this original and extremely compact drive system is the
    elimination of the counter-shaft effect typical of conventional shaft
    drives. Also, unlike alternative systems, Moto Guzzi's patented reactive
    shaft drive enables a single piece swingarm to be used.
    Theo
  2. Theo Bekkers
    Sprint Guest
    Sure - finally qualifying them for entry to your local tractor pull
    competition :)
    Sprint.
    Sprint, Nov 21, 2005
  3. Theo Bekkers
    atec Guest
    So it will wheelie ?
    atec, Nov 21, 2005
  4. Theo Bekkers
    FruitLoop Guest
    Only in first gear with a large speed hump and a huge clutchfan at redline .
    Helped further if you exceed 120kg in weight and in a drag racing position
    PS . Also loaded with a high octane mix in the tank but dont put too much in
    or the fronts tooo heavy .
    Its a fine line
    FruitLoop, Nov 21, 2005
  5. Yes, but I doubt it will countersteer.
    Zaphod Beeblebrox, Nov 21, 2005
  6. Theo Bekkers
    corks Guest
    if it breaks down, does it means - its carc'ed it ????
    corks, Nov 21, 2005
  7. Theo Bekkers
    Theo Bekkers Guest
    I was waiting for something along that line, but certainly didn't expect it
    from you Dave.
    Where did you find the comma?
    Theo
    Theo Bekkers, Nov 22, 2005
  8. Two keys to the left of the '/' key and, shock, horror, the 'Shift' key!
    Pisshead Pete, Nov 22, 2005
  9. Theo Bekkers
    corks Guest
    heheheheh, in a rare fit of lucidity, its smacked mne between the eyes and i
    hastily scrollled through the thread to see if anyone else had already done
    so
    but no ......mine......mine...alll mine .......
    wot comma
    corks, Nov 22, 2005
  10. Theo Bekkers
    And yet spelt "lucidity".
    He's a savant!
    Clem
    Knobdoodle, Nov 22, 2005
  11. Theo Bekkers
    corks Guest
    pleased to be of service
    i really must come over again .......
    corks, Nov 23, 2005
  12. Theo Bekkers
    Damn; I meant "idiot savant"!
    Knobdoodle, Nov 26, 2005
