Another Ride Report for Bjay
Discussion in 'Texas Bikers' started by Bill Walker, Jan 25, 2007.
  1. Bill Walker
    Bill Walker Guest
    Louie went for a ride, today.. Don't know where he went or when he left, but
    he's gone.. It sure was a pretty day for it, but I didn't go with him..
    Don't know when he'll be back.. cause he didn't check with me about it..
    Maybe I'll go next time.. if the temperature is a little warmer..
    Bill Walker
    Irving
  2. Bill Walker
    Brian Walker Guest
    Good ride report! Enjoyed every bit of it. It sure makes me wish Bjay
    was out there too.
    Nah, Bjay is still looking at his globe trying to figure out if a
    motorcycle can actually go beyond Bowie County and end up in some place
    like St Louis, Nashville and so on...maybe he'll figure that out right
    after he finds out how to convert a motorcycle from shaft drive to
    chain....
    Brian Walker, Jan 25, 2007
  3. Bill Walker
    BJayKana Guest
    but he's gone.. It sure was a pretty day for it, but I didn't go with
    him.. Don't know when he'll be back.. cause he didn't check with me
    about it.. Maybe I'll go next time.. if the temperature is a little
    warmer..
    Bill Walker
    Irving
    was out there too.
    chain.
    (brianwalker)
    You might have forgotten, Brian, but Miller county is not in Bowie
    county, therefore, for the record on here, I rode into Miller county
    Arkansas, twice this week.
    The next time I'm up your way, I'd like to get some tips on changing a
    smooth running crotchRocket's shaft to a chain??? You did do it
    yourself, didnt you? I thought so. Hope your ''ride'' from St. Louis is
    without mishaps. goodDay.
    B. Jay Kana--
    NETexas
    03Valk-&-98 Magna
    Have a Dandy Day--
    BJayKana, Jan 26, 2007
  4. Bill Walker
    Brian Walker Guest
    Yup, did every bit of it myself. It wasn't that difficult to do it. All
    you have to do is remove the drive from the rear end, replace the rear
    wheel, replace the spline with sprockets, weld on new hangers and a
    chain guard. Once you have that, then you just get a custom fitted
    chain and adjust it to fit. Oh yeah, I had to remove the rear fender to
    make room for the bigger rear tire.
    The real trick was how to fit the bigger gas tank. As you might know,
    the Shadow has the tank under the seat. I had to convert from that to a
    tank over the frame and sits in front. When I changed to the low bars,
    it made me sitting where I'm over the new tank...since the tank is
    mounted on top of where the old one was. I just found the big tank I
    wanted, went to the hardware store and bought some aluminum tie straps
    and sheet metal screws to fit the new tank on the old one. That's when
    I got the idea to move the pegs back so I can be more comfortable
    leaning into the forward position.
    Then I looked back at the bike and thought it'd be better to have a
    full fairing. I went back to the same place I found the tank and got a
    full coverage fairing. I used the left over screws and just screwed the
    fairing on the frame.
    This isn't to mention the changes to the engine making for WAY more
    horsepower.
    Like I said, the motorcycle doesn't look anything like it used to. It's
    amazing what someone will do with downtime during the cold weather,
    huh? I got most of these ideas from watching American Chopper on the
    Discovery Channel.
    I should be in your area this evening....maybe you can see this bike
    riding through....
    Brian Walker, Jan 26, 2007
  5. Bill Walker
    louie Guest
    I had enhancement items to check out on this ride. I bought a new GPS, but
    I'm too smart to get lost, and didn't care where I was going....so I didn't
    use it. New progressive springs in the front, couldn't tell any difference.
    New seat cushion feels great. I didn't want to buy one of those $600 seats
    just yet. For what it is, that Airhawk cushion is expensive also. I found an
    air cushion at Sports Authority for $17 and went with that. Fits the Voyager
    seat pretty good.
    I rode around to the back side of Alvarado Lake. Got some good curves around
    there, but those wild meth producing punks around there drive like wild meth
    producing/users and are somewhat of a hazard. One '78 Tempo is extremely
    wide on the corners and even with the fenders dented inward it still leaves
    little clearance.
    On down the rode I visited Itasca, Hillsboro, and Whitney. That road stuff
    the Hiway boys put out for the ice we had a few days ago has turned to white
    power which makes for slick spots. That dust also will settle around the
    dash area right behind the windshield.
    Maybe Friday another trip? Can u get out?
    ....louie
    louie, Jan 26, 2007
  6. Bill Walker
    Redshad Guest
    LMAOOOOOOO
    Redshad, Jan 26, 2007
  7. Bill Walker
    Bill Walker Guest
    Well .. yeah.. Soon as it warms up a little bit.. Gotta run by Grapevine for
    a tail
    light assembly and that's it..
    Since it has been too damned cold for old folks like me to be out and about,
    just thought I'd go ahead and do a ride report for you and dedicate it to
    Bjay..
    You know how those guys with Kitchen Pass problems are ? Leave it to you
    to get out by yourself and have some sort of problem with a damned Tempo..
    Sheesh.. getting to where I can't let you out in public anymore.. Regards
    Bill Walker
    Bill Walker, Jan 26, 2007
  8. Bill Walker
    BJayKana Guest
    (Redshad)
    warmer..
    Bill Walker
    Irving
    Brian says; Good ride report! Enjoyed every bit of it. It sure makes
    me wish Bjay was out there too.
    chain.
    (brianwalker)
    B. Jay Kana--
    03Valk-&-98 Magna
    shadowrider34@hotmail responds to bjay;
    Bjay,yup, did every bit of it myself. It wasn't that difficult to do it.
    All you have to do is remove the drive from the rear end, replace the
    rear wheel, replace the spline with sprockets, weld on new hangers and a
    chain guard. Once you have that, then you just get a custom fitted chain
    and adjust it to fit. Oh yeah, I had to remove the rear fender to make
    and sheet metal screws to fit the new tank on the old one. That's when I
    got the idea to move the pegs back so I can be more comfortable leaning
    Then I looked back at the bike and thought it'd be better to have a full
    fairing. I went back to the same place I found the tank and got a full
    horsepower.
    amazing what someone will do with downtime during the cold weather, huh?
    Discovery Channel.
    riding through....
    said:
    LMAOOOOOOO
    Now, now.
    Personally, I'm impressed.
    I don't know what to say, to be honest.
    B. Jay Kana--
    NETexas
    03Valk-&-98 Magna
    Have a Dandy Day--
  9. Bill Walker
    Brian Walker Guest
    I came through Bowie County last night and I didn't see you at the
    Shell station....maybe you were at the other one?
    Anyway, I have to take that modified Shadow of mine to the shop today.
    It seems during the ride one of those aluminum straps holding the
    wheel steady came loose. That thing went to wobbling all over the
    highway and I had to slow it way down. I might just have to do
    something about this chain drive. I was talking with one guy at a gas
    station and he said it might be the chain I'm using causing the
    problem. I can't figure out what he'd be talking about...I told the
    salesman at the local TrueValue I wanted the best chain link they had.
    But you're right, those chains sure do make some racket back there.
    And for some reason, that chain only hits in the teeth on the sproket
    every once in a while. Even over those loud pipes I've got, I can
    still hear that thing clattering away. It takes a whole can of WD40 to
    get that thing to quiet down for a few miles.
    Brian Walker, Jan 27, 2007
  10. Bill Walker
    Redshad Guest
    You might need to check and make sure True Value didnt sell you a chain for
    a chain saw. The brand of chain wasnt STIHL was it??
    Redshad
    Redshad, Jan 27, 2007
  11. Bill Walker
    Brian Walker Guest
    Nah, it wasn't for a chain saw...I'm not that dumb! It was the best
    chain I could find off the spools. The good thing about it, if I break
    the chain...I can use it to pull the motorcycle to another TrueValue
    to get it fixed!
    Maybe I'll put some tow hooks on the front of this motorcycle? As soon
    as I get it finished, I'm calling the Discovery Channel...
    Wanna go to Grapevine today?
  12. Bill Walker
    BJayKana Guest
    Bjay, let me tell ya' ''It takes a whole can of WD40 to get that thing
    to quiet down for a few miles.(brian)
    If you'd asked some of us, on here bfore you did all that to the
    motorBike, we'd told ja' that a chain requires maintenence.
    I hope you stored the ''shaft'', after you took it off.
    Ya' might wanna weld it back on, throw dogGone ole' cheap chain in an EZ
    Mart dumpster.
    I imagine it's been a good while since you rode a motorBike with a dern
    chain.
    Oh yeah, my Magna has a chain. hmmmmmmmmm! (chuckle)
    B. Jay Kana--
    NETexas
    03Valk-&-98 Magna
    Have a Dandy Day--
    BJayKana, Jan 27, 2007
  13. Bill Walker
    BJayKana Guest
    Brian, You might need to check and make sure True Value didnt sell
    you a chain for a chain saw. The brand of chain wasnt STIHL was it??
    Redshad
    Not Brian, the boy is, smarter than that.
    What do you take him for, come on. <g>
    B. Jay Kana--
    NETexas
    03Valk-&-98 Magna
    Have a Dandy Day--
  14. Bill Walker
    BJayKana Guest
    shadowrider34@hotmail,com
    Red-Shad,
    as I get it finished, I'm calling the Discovery Channel... brian)
    Yeah, they might invite you on the show as a guest niggerRigger. (oops)
    B. Jay Kana--
    NETexas
    03Valk-&-98 Magna
    Have a Dandy Day--
  15. Bill Walker
    Brian Walker Guest
    I don't know about anyone else, but I don't appreciate your racial
    remarks into a discussion.
  16. Bill Walker
    Brian Walker Guest
    I seem to recall giving the shaft to you...I believe you still have it
    too.
  17. Bill Walker
    BJayKana Guest
    (Brian Walker)
    Red-Shad,
    B. Jay Kana--
    NETexas
    03Valk-&-98 Magna
    Have a Dandy Day--
    Bjay:I don't know about anyone else, but I don't appreciate your racial
    remarks into a discussion.(brian)
    That shows what you know. My phrase was a redNeck Country boy remark.
    However Brian, I dont even use it any more, to be honest, I been saying:
    ‘‘whiteRiggin'’’, or redneck engineering, for a whole dern
    lotta years.
    Take it anyway you wanna, good buddy.
    B. Jay Kana--
    NETexas
    03Valk-&-98 Magna
    Have a Dandy Day--
    BJayKana, Jan 28, 2007
  18. Bill Walker
    Thunder Guest
    Even African Americans use the term!! Besides, you have no room to talk.
    Using vulgarity like "****" is worse IMHO. I don't appreciate that and I'm
    sure there are others that feel the same!
    Thunder, Jan 29, 2007
  19. Bill Walker
    Bill Walker Guest
    Kinda sensitive, aren't you sport ?
    Bill Walker, Jan 29, 2007
  20. Bill Walker
    Brian Walker Guest
    BWAHAHAHAHAHA!!!!!
    I don't recall asking your opinion about anything....
    Brian Walker, Jan 29, 2007
