Another one...
Discussion in 'Classic Motorbikes' started by mark, Jul 22, 2010.
  1. Soften it with some boiling water before trying to winkle it out.
    The Older Gentleman, Jul 24, 2010
  2. That's not necessarily good news. Are you sure it's the right size? The
    standard bolt is a tiny 8mm thing. If someone's jammed a larger diameter
    bolt in, the thread's probably fucked. If it's just an 8mm bolt but
    longer than stock, then you're probably OK.
    That is very good news indeed. Suggests someone knew what they were
    doing. If the 12mm heads on the stock filter bolts get nadgered, as they
    do, welding a socket head onto them is often the only way to get the
    bastard things out.
  3. Heh. Told you ;-)
    Dave Silver does new ones for £35 plus VAT plus P&P. If you want me to
    halt the auction before it starts, I'll let you have a good used one for
    £25 inc. P&P. Even got the fuses still in it!
    http://www.neil_murray.fastmail.fm/400Ffusepanel.jpg
  4. mark
    mark Guest
    Haven't actually measured it but it looks exactly the same as the one on
    the other bike here.
    /Crosses fingers.
    mark, Jul 24, 2010
  5. mark
    mark Guest
    Send it me with that painted tank and panel set for £170 and I'll
    promise to think the best of you?
    mark, Jul 24, 2010
  6. Ah, so both bikes have been bodged then ;)
  7. mark
    mark Guest
    /Thinks
    Maybe I should buy a third (1) for comparison purposes?
    1. Technically a 5th if you count the registered frames I now have lying
    about................
    mark, Jul 24, 2010
  8. That sounds do-able. I assume you're going to collect or UR the
    tank/panel set? I hate posting fuel tanks because they need an arseload
    of packing. Whereabouts are you, anyway?
    If you are sure you want the tank and panels and the fusebox, I can kill
    he impending auctions, no problem.
  9. mark
    mark Guest
    North Wales :)
    I think possibly the UR might be best.
    Don't post it, it is; as you say.
    Yes please.
    mark, Jul 24, 2010
  10. Well, Steve H is close-ish to you and comes to the Smoke quite
    frequently. And there are others. Put a UR call on ukrm.
    OK. Chuck £170 at my PayPal (address is the one in the sig, not this
    posting address) and I'll do that. Remember I won't be back in the
    country until 7 August, so I can't do anything until then. Anyway, gives
    you plenty of time to sort out the UR.
    Should the worst happen to your loom, I also have a really good nick
    wiring loom.
    The only broken connector is on the white wire to the headlight.
    http://www.neil_murray.fastmail.fm/400Floom.jpg
  11. mark
    mark Guest
    Had another little shed 'escape' earlier.
    The bolt is the right size albeit longer.
    Unfortunately the thread in the alloy is fecked.
    I know everyone says you shouldn't but I reckon it wouldn't be so
    difficult to cut some sort of new thread in there.
    It's only alloy.
    Hand drill it out carefully so I don't catch the tension rod.
    Tap it using a tap with a cunning extension piece attached so the tap
    vice clears the frame.
    Do all this with the hole full of grease so I can catch any swarf.
    Finish off the hole with a bolt of the right thread all sharpened up at
    the end....
    Comments?
    mark, Jul 24, 2010
  12. Thought so.
    Yes, this is necessary because (as you've seen) the bolt is very close
    to the front of the engine and the frame. There's not much room to do
    anything.
    This would work. However, you have the additional possibility that
    whoever butchered the thread in the first place may also have driven the
    replacement bolt in hard enough to bend and jam the tensioner rod.
    Before you do anything, do the old 'screwdriver down the tensioner rod
    tunnel' trick to see if the camchain quietens when you push down on the
    screwdriver.
    You may need to give the end of the driver a light tap with a hammer -
    those rods do seize. Well, actuallym the 'horseshoe' under the crank
    does, too.
    If this works - if you can hear the engine quieten when you press down
    on the screwdriver - then go ahead.
    If it doesn't, then you've got a big problem which it may take a
    complete engine strip to sort.
  13. mark
    mark Guest
    Hadn't considered that. Quite possible...
    Had considered this; because of this:
    The engine is lacking cam chain noise.
    I suppose I should consider the possibility that it's nice and tight
    because the rod is nicley stuck due to being bent.....
    Is it wrong to think that this might be an interesting thing to do?
    mark, Jul 24, 2010
  14. It would definitely not be the first time it's happened.
    If you equate 'interesting' with 'expensive', then no :)
    Seriously, engine work on a 400 Four is expensive. Once you've got the
    thing apart, you'll need to replace all seals and gaskets as a matter of
    course, and certainly the camchain and tensioner blades.
    Pistons and rings, probably not, as they're surprisingly durable. But
    even a fairly basic strip and rebuild will easily set you back £250.
    Like I said, do the screwdriver blade test (obviously, you need the
    locking bolt removed for this). If it's noisy and then quietens when you
    press, fine, it's not seized. Do the thread repair.
    Sometimes, like I said, the 'horseshoe' sticks. It was stuck on mine
    when I first got it. You can actually get at it through the sump. You'll
    need a broad bladed screwdriver and a hook fashioned from a bent
    coat-hanger.
    Remove the locking bolt, as ever. Remove the sump. It's easiest if you
    lay the bike now on its side, but with a torch and little
    mirror-onna-stick you don't have to.
    On the bottom of the pivoting horseshoe you'll see a sort of lug.
    Here:
    http://www.cmsnl.com/honda-cb400f2-england_model14647/partslist/E01.html
    Part number 50
    Push up on that lug with the end of the screwdriver. Pull down with the
    hook. Repeat until it frees up.
  15. mark
    two fucking shit four cylinder Hondas is my guess.
    sweller, Jul 25, 2010
  16. mark
  17. mark
    mark Guest
    Not keen on them then? :)
    mark, Jul 25, 2010
  18. mark
    mark Guest
    You actually checked they *were* shit 4 cylinder hondas?
    Then got annoyed because you were right?
    :D
    mark, Jul 25, 2010
  19. mark
    mark Guest
    I guess it is expensive if you actually consider what the thing is worth
    as a bike you might use to ride about.
    I quite like the bloody things for different/nostalgic reasons and
    fiddling about with them is quite pleasant for some weird reason.
    I guess I should decide whether the above (1) is worth the time and
    money it takes before going mad with spanners and hylomar.
    Thanks for the financial heads up.<Snip useful stuff about seized tensioner>
    Cheers for that.
    1.different/nostalgic reasons and fiddling about
    mark, Jul 25, 2010
  20. mark
    Salad Dodger Guest
    Inadequately cylindered for my liking.
    Salad Dodger, Jul 25, 2010
