Another fettling fail
Discussion in 'UK Motorcycles' started by TMack, Oct 24, 2010.
  1. TMack
    TMack Guest
    On the Sunday before last I went to fit new chain and sprockets on the ST3
    only to find that I had been sent the wrong rear sprocket. Today I
    successfully fitted the correct-sized replacement rear sprocket only to find
    that I had also been sent the wrong length chain (1 link too short). So I
    wheeled the ST3 back into its Bike Barn and set about fiddling with the VSO
    LS650, which has some obscure ignition timing problem (probably due to being
    assembled from spare parts resulting in a mismatched pulse generator in the
    stator/outer case ). Then its started raining despite the forecast
    repeatedly promising a sunny afternoon so that had to go back under its
    cover too,
    Arse!
    TMack, Oct 24, 2010
