another f-ing cd200 question
Discussion in 'UK Motorcycles' started by darsy, Nov 10, 2003.
  1. darsy
    good point
    "it's a fucking benly, for fucks sake" or some such.
    sweller, Nov 11, 2003
  2. darsy
    Yes, Carole Nash bundled recovery covers all my ancient piles of shit.
    For some machines a hearty push into some bushes and selective amnesia is
    an acceptable response.
  3. darsy
    I'm with Motorcycle Direct, mind. Who do Carole Nash use for their
    recovery?
    You really don't like my CD, do you?
    darsy, Nov 11, 2003
  4. darsy
    mups Guest
    I phoned the AA[1] up about taking the RS200 to germany and they just
    laughed at me. They will cover it in the UK mind.
    [1] Who I'm with at the mo
    mups, Nov 11, 2003
  5. darsy
    They seem to use independents. So, no, I don't know.
    Not especially, I'm sure you'll be very happy with it. But it is brown.
  6. darsy
    it's not fucking brown - it's burgundy. And it's much prettier and
    less 2-strokey than any MZ bag of shite.
    darsy, Nov 11, 2003
  7. darsy
    I've never had a burgundy pair of shoes, but I've had a pair of NHS ones
    the same colour as your Benly.
    Duh, that was never in question [1].
    Except perhaps "brown/darsyburgundy" and "prettier" may be mutually
    exclusive.
    [1] Although, all my MZ's are either red (fast) or black (hard).
  8. darsy
    PeterT Guest
    darsy
    Did I glimpse a little bit of a rattle there?
    PeterT, Nov 11, 2003
  9. darsy
    err, no. I'm afraid you've been whoooshed.
    darsy, Nov 11, 2003
  10. darsy
    I think the CD200 looks much more like a "real motorcycle" than MZs.
    I'm sure you know, but they're unredeemably ugly.
    darsy, Nov 11, 2003
  11. darsy
    darsy was seen penning the following ode to ... whatever:
    Mondial.
    Timo Geusch, Nov 11, 2003
  12. darsy
    Salad Dodger Guest
    About 15 years ago, when I shared a flat on the Wester Avenue (A40),
    my flatmate was fettling his Renault 5 in the lay-by out front.
    Someone at work had suggested using Redex, so the bright lad put a
    capful down each plug hole.
    Needless to say, when it eventually started, the whole of Western
    London disappeared from view, and traffic was reduced to a standstill.
    Being a socially minded chap, he just revved away until the smoke
    cleared. :)
    | ___ Salad Dodger
    |_\_____/_| ..61132../..14035.../..3157./.19406
    \|^|/ ANORAK#17
    Salad Dodger, Nov 11, 2003
  13. darsy
    Gingerposer Guest
    My brother once had a shite old ford escort, 1.1l, which had the unusual
    addition of a second screenwash reservoir. This was connected to the carb,
    and wired via a switch array from an old helicopter (I kid you not) hidden
    in the central console.
    Much fun was had experimenting to find the mix of fluids to generate the
    desired smoke cloud. 50/50 redex and used engine oil did the trick - masses
    of sweet-smelling smoke on demand!
    Gingerposer, Nov 11, 2003
  14. darsy
    Platypus Guest
    The instructions say to turn the engine over with a rag held over the
    spark plug hole, so that the Redex is blown out before the engine is
    started.
    When I had a car with an SU-type carb, I would use Redex in the
    dashpots.
    Platypus - Faster Than Champ
    VN800 Drifter, R80RT
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Nov 11, 2003
  15. darsy
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, darsy
    "irredeemably", Shirley?
    Nigel Eaton, Nov 12, 2003
  16. darsy
    Platypus Guest
    "irremediably"
    Platypus, Nov 12, 2003
  17. darsy
    response the first:
    <fx:looks at Nigel's .sig>; funny, I thought you had better things to
    gripe about than other people's spelling...
    response the second:
    both unredeemable and irredeemable are valid words, though the later
    is admitedly by the more common of the two (5.5K hits -v- 17k hits on
    Google, as a simple barometer).
    There's a subtle difference in meaning too. "Unredeemable" refers to
    something that is "not redeemable", where "irredeemable" is usually
    used to mean "beyond redemption", which is not quite the same thing
    i.e. "irredeemable" basically says "game over", where "unredeemable"
    allows a small chink of hope that the object in question may be
    capable of being redeemed in a particular circumstance or if this or
    that modification are performed to it.
    "Unredeemable" also has a secondary meaning: "having no redemption
    value" i.e. "this plastic bottle is unredeemable" - in this context
    "irredeemable" is not valid.
    HTH, fatty.
    darsy, Nov 12, 2003
  18. darsy
    flashgorman Guest
    You're incorrigible.
    flashgorman, Nov 12, 2003
  19. darsy
    Nigel Eaton Guest
    I know, but curiously that leaves me largely unmoved[1], allowing *lots*
    of time to worry about your spelling.
    Are you implying that there are some circumstances in which an MZ could
    be held to be "not ugly"? Irredeemably it is, then.
    [1] As does most of the collection detailed in the .sig, obviously.
  20. darsy
    it'd make a fairly attractive cube of crushed scrap.
    if it makes you happy.
    darsy, Nov 12, 2003
