<thick mode on> Let's say I bought a red anodised swing arm and I wanted it black (anodised). Would this be possible and more importantly: is it expensive? <thick mode stays on> -- Spete www.gimmemoney.mine.nu www.spete.homeip.net Occasionally, I'll be consistent
Spete expressed the following: IIRC the dye inside is trapped inside during the sealing process and you'll need to strip the anodising and start again. I could be wrong of course as in my line of business anodising is used for corrosion protection, not cosmetic finish.
Using the patented Mavis Beacon "Hunt&Peck" Technique, Spete It's very, very cheap. Just leave it outside Pixie Central and it'll end up black. It might be some of "Pip's special anodizing" but, so long as you don't get it DNA tested, then job's a good 'un. -- Nigel - Manufacturer of the "Champion-104" range of rearsets WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20 BOTAFOT#150 HYPO#0(KoTL) ZZR1100, Enfield 500 Curry House Racer "The Basmati Rice Burner", Honda GL1000K2 Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
