ANN: LED Luminosity Breakthrough
Discussion in 'Australian Motorcycles' started by Peter Lowrie, Nov 15, 2003.
  1. Peter Lowrie
    Peter Lowrie Guest
    15 November 2003.
    Announcement:
    Light Emitting Diode (LED) Intensification Breakthrough in New Zealand
    laboratory.
    Using ultra-small electronic componentry to intensify (make brighter)the
    ubiquitous LED, the LED output can be increased by up to four times without
    blowing them up as would be expected when you shove too much voltage into
    them. The Free Electron laboratory technicians in Lower Hutt, North Island,
    New Zealand have developed a device to intensify LED's by overpowering and
    cooling LED's to make an otherwise mediocre LED shine furiously bright.
    Given the headlong rush to more Lumens per Watt and the wide range of
    applications that LED's lend themselves to, it is surprising that such
    an add-on component has not, before today, been developed. The LED
    Accelerator brings a solution to bear upon the problem of otherwise poor LED
    luminosity performance. At an increasing rate LED's are being used in
    industry, transport, home and personal lighting, security, communications,
    toys and consumer electronics, the future is bright then, for a company
    that will manufacture and distribute the LED Accelerator.
    In the next few days it is expected that rights to the device will be
    auctioned by eBay and at other auction sites in Europe, and Australasia.
    http://www.geocities.com/ledaccelerator
    This press release was provided by:
    Peter E. Lowrie.
    Chairman,
    Free Electron.
    High St,
    Lower Hutt, 6009.
    New Zealand.
    ++64-4-9766712
  2. Peter Lowrie
    conehead Guest
    Wasn't there a song called The Free Electron Band?
    conehead, Nov 16, 2003
  3. Peter Lowrie
    Peter Lowrie Guest
    Time to update information for detractors, supporters and other souls kind
    enough to provide feedback herein:
    The circuit does not change the colour of the LED.
    Most LEDs do not operate at 100% duty - brake lights for example, life
    reduction expectancy therefore UP TO 30%.
    The circuit does not directly influence the efficiency of the LED, it just
    allows a higher voltage to be safely applied to the LED.
    In this incantation the circuit is designed for arrays of LED's, such as
    traffic lights, indicators and tail lights. It's use will be more
    applicable, therefore, to interior lighting, automotive, traffic and
    industrial applications.
    The low power version sinks 1 Amp, and the power device <4 Amps - which is a
    huge output so far as LED applications are involved. At the four Amp rating
    8 devices could easily power aircraft runway lights.
    A typo on the website has been fixed.
    Thankyou for suggestions insofar as Lumileds and Luxeon are concerned.
    Do please post on-topic communiques to this NG rather than posting emails as
    is the want in NG culture.
    An announcement will be issued shortly as to auctioning the rights to
    use/manufacture the device.
    Yours faithfully
    Peter E. Lowrie.
    Chairman,
    Free Electron.
    High St,
    Lower Hutt, 6009.
    New Zealand.
    ++64-4-9766712
    Peter Lowrie, Nov 18, 2003
  4. Peter Lowrie
    Damien Guest
    It's always fun putting higher voltages through LED's - they make a rather
    satisfying noise when they finally blow up, and you get to go looking to see
    where the top bit landed. ahh, the joys of an LED, and a variable power
    supply! oh, and an absent lab supervisor helps too. :)
    Damien (oh, so there WAS meant to be a resistor in that circuit!)
    GPX250 (stolen) -> CBR600
    Damien, Nov 18, 2003
  5. Peter Lowrie
    Peter Lowrie Guest
    Peter Lowrie, Nov 19, 2003
  6. Peter Lowrie
    Damien Guest
    Damien, Nov 19, 2003
  7. Peter Lowrie
    Peter Lowrie Guest
    And then Damian suggested:
    Only real wankers and double adapters need apply. ;-)
    :peter
  8. Peter Lowrie
    conehead Guest
    Me! Me!
    conehead, Nov 20, 2003
  9. Peter Lowrie
    John Littler Guest
    Peter, why the hell do you think a bunch of bikers care about LED accelerators ?
    JL
    (this has to be the weirdest spam I've seen)
    John Littler, Nov 22, 2003
  10. Peter Lowrie
    conehead Guest
    Perhaps he thinks we're easily led?
    conehead, Nov 22, 2003
  11. Peter Lowrie
    Peter Lowrie Guest
    accelerators ?
    Perhaps because led's will be used more often by manufacturers and
    constructors and MC's is where you will see them.
    Gee, thanks. I thought it was more of an ad than a spam though.
    Best wishes
    Peter Lowrie
    Peter Lowrie, Nov 22, 2003
  12. Peter Lowrie
    Damien Guest
    You don't get out much, do you? Put the sheep back in the paddock, open the
    curtains, and go out into the real world for a bit - you'd be amazed at what
    you'll see out there!
    Damien
    Damien, Nov 22, 2003
  13. Peter Lowrie
    John Littler Guest
    <boggle !!>
    **** off spammer bitch.
    JL
    John Littler, Nov 23, 2003
