Angle grinder?
Discussion in 'UK Motorcycles' started by Harry Bloomfield, Mar 8, 2006.
  1. I've just got hold of a replacement seat for my VFR to see if I could
    lower the bikes seat height a little and thought you might be
    interested in how it turned out....
    I removed all the staples holding the cover to the plastic base frame,
    then set about it first with a sharpened up bread knife. This worked,
    but it was rather inclined to take out uncontrolled chunks of the foam.
    I then thought I would see if a small angle grinder might be more
    successful, possibly giving better control of the operation. It worked
    much better. Drawing the grinders disk backwards from the sponge
    produced a perfectly smooth surface and took the material off in a very
    controlled way.
  2. In uk.rec.motorcycles, Harry Bloomfield belched forth and ejected the
    following:
    Now all you need to do is "cut it off about here"(tm)
    Before:
    www.whingingcourier.dsl.pipex.com/05Whinging_Courier.JPG
    After:
    www.whingingcourier.dsl.pipex.com/mybike-ratbikereview2004.jpg
    Welcome to the dark side.
    Whinging Courier, Mar 8, 2006
  3. Harry Bloomfield
    Catman Guest
    Leccy carving knife works well too.
    Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 OMF#22
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 156 TS S2
    www.cuore-sportivo.co.uk
    Catman, Mar 8, 2006
  4. Harry Bloomfield
    Molly Guest
    An angle grinder is the modern day equivalent of the Swiss Army pen knife.
    Molly, Mar 8, 2006
  5. Harry Bloomfield
    zymurgy Guest
    zymurgy, Mar 9, 2006
  6. In uk.rec.motorcycles, belched forth and ejected the following:
    I did have a laugh to myself when I clicked the links to test if they
    worked.
    Whinging Courier, Mar 9, 2006
