Angle grinder disc removal
Discussion in 'UK Motorcycles' started by flash, May 31, 2005.
  1. flash
    flash Guest
    I have a cheapo angle grinder that requires a special tool, basically a
    strip of metal with a couple of prongs, to change the discs. Obviously I
    have long since lost the special tool and it now resides with all my chuck
    keys and other vital bits of kit.
    Does any one have a clue how I can remove the disc without the tool?
    flash, May 31, 2005
  2. flash
    duh.
    use an Angle grinder.
    darsy, May 31, 2005
  3. flash
    "Angle Grinder."
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, May 31, 2005
  4. flash
    JackH Guest
    Nope, any angle grinder will do.
    A disc cutter would be more effective though.
    JackH, May 31, 2005
  5. flash
    flash Guest
    Well duh uh, but I need to put a new disc on the angle grinder first.
    flash, May 31, 2005
  6. flash
    Dr Zoidberg Guest
    Buy a new one from B&Q then take it back because there is no key in the box
    [1]
    [1] This is *not* a serious suggestion. [2]
    [2] Gong to B&Q and asking to buy a spare *is* a serious suggestion
    Alex
    www.drzoidberg.co.uk
    www.sffh.co.uk
    www.ebayfaq.co.uk
    Dr Zoidberg, May 31, 2005
  7. flash
    flash Guest
    < ponders raid on Flash Junior's meccano set>
    flash, May 31, 2005
  8. Centre punch and hammer... knock the centre retainer round in an
    anticlockwise direction using the two holes.
    Grimly Curmudgeon, May 31, 2005
  9. flash
    simonk Guest
    A fork?
    simonk, May 31, 2005
  10. flash
    tallbloke Guest
    Push in the little button thing at the back which locks the spindle, then
    with your hand safely inside an old bike glove, get hold of the disc and
    twist anticlockwise.
    Works for me.
    Infact I don't even bother with the glove 'cos I'm that hard.
    tallbloke, May 31, 2005
  11. flash
    Fleagle Guest
    You can buy replacement tools for a quid. Well you can according to the
    Warehouse Direct catalogue that dropped throughh my door this morning.
    Regards, Dave
    Fleagle, May 31, 2005
  12. flash
    Reet'ard.
    _______
    Ace, May 31, 2005
  13. flash
    flash Guest
    <Showing ignorance>
    Theres a lock button?
    </si>
    That may ease matters somewhat. Cheers.
    flash, May 31, 2005
  14. flash
    Dr Zoidberg Guest
    That *might* work :0)
    Alex
    www.sffh.co.uk
    www.ebayfaq.co.uk
  15. There's one of those in this house too.
    only he was wearing gloves. what he had done was to run out of 4 inch
    disks so removed the safety guard and fitted a five inch one.
    he now has a huge gash in his finger.
    Adie
    Triumph 955iSS / GSF1200 bandit / CG125
    Adrienne M Bonwick, May 31, 2005
  16. Angle grinder. HTH. HAND.
    Soylent Green, May 31, 2005
  17. flash
    MattG Guest
    Adrienne M Bonwick said...
    Sounds like a perfectly good idea to me.
    Just cos it didn't go quite according to plan, doesn't mean it wasn't a
    good idea.
    MattG, May 31, 2005
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, Adrienne M
    Oh dear, silly boy.
    Still, it's nice to think that he could return to the arms of his
    beloved for sympathy and 24/7 nursing.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, May 31, 2005
  19. flash
    zymurgy Guest
    Ow. I would hav LOL!'d but he could so easily have lost a finger :-(
    I cut corners, grind without gloves or goggles and do take guards off
    stuff, but not on an AG !
    Cheers
    Paul.
    zymurgy, May 31, 2005
  20. flash
    Biffa @ Work Guest
    Better than having his finger in a huge gash .....
    Biffa @ Work, May 31, 2005
