And still it clicks and ticks.
Discussion in 'UK Motorcycles' started by gazzafield, Mar 31, 2005.
  1. gazzafield
    gazzafield Guest
    And we're not talking clocks. My bike is still making a clicking, ticking
    sound when I start it up despite having just done the shims on the fucker
    last night. This noise would appear to be coming from the right hand side
    of the bike and in the area of the cylinder head. This was the side I found
    two shims that the gap was slightly over spec. Yipee, thought I.
    It clicks and ticks away from cold for anywhere between thirty seconds and a
    couple of minutes. It then becomes barely discernible in amongst the usual
    valve and camchain rustle and exhaust noise or disappears completely.
    I was beginning to think that I had possibly a bent valve or a broken valve
    spring, but this would make a noise all the time surely?
    Is it possibly the camchain tensioner that I should investigate next?
    Any thoughts on this would be appreciated as it is doing my head in. It has
    sat in my garden for three months and been turned over at least once a week
    for about ten minutes a time and had three (44 very cold miles) journeys to
    work.
    It's pissing me off because I should be out there riding it but want to
    track this problem down before it gets worse.
  2. gazzafield
    Vass Guest
    My CBR600f did the same, cam chain tensioner was the culprit
    dunno if the XJ is similar
    Vass, Mar 31, 2005
  3. gazzafield
    TOG Guest
    Quite a lot of engines produce a ticking sound when cold, and then it
    goes away when warm. It's harmless. It could be a slightly sticking
    camchain tensioner, in this instance.
    TOG, Mar 31, 2005
  4. gazzafield
    Statto Guest
    Ear plugs in, lid on and JRTFT[1]. Works for me.
    [1] Just ride the fucking thing.
    Statto, Mar 31, 2005
  5. gazzafield
    Maybe a slightly sticking valve? Run some redex type stuff and see if
    that helps?
    Strip, clean and lube. That's what I did with my Bandit one which seemed
    to get stuck once or twoce. I ended up swapping it out for a manual
    version.
    Of course..
    Muck, Mar 31, 2005
  6. gazzafield
    gazzafield Guest
    It didn't for the first 6,000 miles I had it.
  7. gazzafield
    BORG Guest
    is it a click or a phut phut type of noise but very like a click ?
    Could be a lose plug or a small blow in the head gasket
    <--ROT13 it
    Spam Trap in Header
    Freedom isn't FREE
    GHPOTHUF #69
    http://borg.no-ip.com
    BORG, Mar 31, 2005
  8. gazzafield
    gazzafield Guest
    I have considered this possibility. I had an old GSX250 that did this with
    a very slight blow in the exhaust gasket. I don't think it is, but it's
    such a bastard to track down exactly where it is that I haven't ruled it out
    yet.
  9. gazzafield wrote
    Loud cans rock.
    Especially if your bike is looking to go through 60k soon.
    steve auvache, Mar 31, 2005
  10. gazzafield
    Bear says...
    It's just you and Petrolcan
    Lozzo, Mar 31, 2005
  11. gazzafield
    SteveH Guest
    What he said.
    ISTR it goes away when you pull in the clutch.
    SteveH, Mar 31, 2005
  12. gazzafield
    Martin Guest
    It could be a gubbed gasket at the carb rubber/engine block face, with
    the engine running from cold, get a rag soaked in petrol and squeeze it
    over each gasket, if the revs increase then you have a dodgy gasket
    which is sucking in air, if not then try something else.
    Martin:
    VTR1000 Firestorm
    Martin, Mar 31, 2005
  13. gazzafield
    Easier and greener - squirt WD40 at the carb rubbers.
    Pip, Apr 1, 2005
  14. gazzafield
    petrolcan Guest
    the cont known as Lozzo says...
    What did I do wrong?
    petrolcan, Apr 1, 2005
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    Umm...
    Err...
    Umm...
    <thinks>
    Ooh! Oh no...
    Umm...
    <thinks harder>
    What about? No, no...
    Err...
    <thinks really quite hard>
    No. No, it's no good.
    Let's stick with the original plan.
    Wicked Uncle Nigel, Apr 1, 2005
  16. gazzafield
    petrolcan Guest
    the cont known as Wicked Uncle Nigel says...
    You know what both of you can do?
