And 23 thousand bucks doesn't sound expensive
Discussion in 'UK Motorcycles' started by TOG, Jan 12, 2007.
  1. TOG
    It's a long time since I was working on the that sort of stuff so you
    could well be right. I'd be very surprised if the RAF ever resorted to
    it though.
    I think it might even need to be a worse situation than that.
    Andy Bonwick, Jan 14, 2007
    #81
  2. TOG
    Cab Guest
    Because of course we'd know you're wrong. ;-)
    Cab, Jan 14, 2007
    #82
  3. TOG
    I did.
    Pip Luscher, Jan 14, 2007
    #83
  4. TOG
    Cab Guest
    Heh heh. No, no. I don't think I could go through all of that again.
    Cab, Jan 14, 2007
    #84
  5. TOG
    I was over at Oracle SJ wen Larry E. bouight the 2 Migs (1 for spares).
    IIRC the FAA never allowed him to use them there.
    Hog, Jan 14, 2007
    #85
  6. TOG
    Cab Guest
    Hog wrote:
    1. CAA != FAA
    2. US != UK (well at the moment, at least)
    Cab, Jan 14, 2007
    #86
  7. TOG
    Oh look I'm cold, you know what I meant!
    Hog, Jan 14, 2007
    #87
  8. TOG
    antonye Guest
    That'd be the Colville Road works (known locally as "The Pit")
    then I guess? Don't know what the company was called but
    I know they used to make Spitfire replicas down there.
    So you were probably visiting MotorMec ?
    antonye, Jan 14, 2007
    #88
  9. TOG
    antonye says...
    I honestly can't remember who I was there to see, it was when I was
    managing a car accessories and sunroof firm based in Norwich, so that
    would make it about 1991 ish.
    Lozzo, Jan 14, 2007
    #89
  10. TOG
    Mauro Floriani ?
    ogden, Jan 15, 2007
    #90
  11. TOG
    andrew_wegg Guest
    About 55 airworthy Spits at the last count, about 200-250 existing.
    More Hurricanes flying each year, though still only a handful as
    they're hard to rebuild
    More German stuff than you might imagine especially since the end of
    the cold war, but little of it airworthy. Most the Ju52s aren't JU
    built but Spanish or French.... Jap stuff is very rare and only a very
    few flyers.
    Surprisingly many. 1 flyer and the one at Duxford flew in c.1980.
    Enola Gay and the other atom bomber both still exist and there's 10-20
    others.
    andrew_wegg, Jan 15, 2007
    #91
  12. TOG
    andrew_wegg Guest
    The authorities don't like military jets flying in civil hands dur to
    the complexity and potential for disaster if it all goes tits up. In
    mil service they tended to need an enormous amount of maintenance to
    flying time - something like a Lightning the ratio is something of the
    order of 40:1. The only Lightnings flying are in S Africa as the UK
    CAA won't authorise them. There's been less worry in the US, but a
    couple of high profile crashes recently has begun to change things.
    #92
  13. TOG
    andrew_wegg Guest
    Maybe. The Czech airforce put a whole bunch of Mig21 up for auction
    end last year. Looks like these are some of them.
    #93
  14. TOG
    andrew_wegg Guest
    Correct, but a couple of possibilities for the mid term future...
    #94
  15. TOG
    andrew_wegg Guest
    Mostly Spanish built versions of German types
    #95
  16. TOG
    And not even a 'heh'. Bastard.
    ogden, Jan 15, 2007
    #96
  17. TOG
    andrew_wegg Guest
    Dan L wrote:
    Indeed, then taken indoors, sold off to private restorers and replaced
    with plakky reps.
    Which one? They had two over the years...
    Most recently there was a Mk XVI on the gate, from 1970 until 1989,
    which is now in Florida and airworthy, before that they had a 22 which
    is now at Duxford in bits.
    #97
  18. TOG
    andrew_wegg Guest
    Ain't no Tornados flying in private hands, not nowhere. There's a
    couple of stripped out ones that have been sold off but no flyers.
    #98
  19. TOG
    andrew_wegg Guest
    I was hiding the hangar, flicking V's at you all. Or maybe it was
    after I'd left.
    #99
  20. TOG
    andrew_wegg Guest
    No Hawks, but quite a few JPs, Gnats, Hunters, Canberras. You can fly
    the Hunter on a normal PPL, which is one of the reasons for the doubts
    about it all. Effectively you could jump out of a Cessna 152 with 40
    hours behind you, and if you had the cash, jump straight into a Hunter
    and bore holes in the sky. A few pilots have done something similar,
    with a bit more experience and there's been a number of deaths.
    The CAA in the UK allows "simple" jets to fly on the provate register,
    the most complex so far is the Sea Vixen. The LIghtnings never got
    near and there was an attempt to get an ex RAF Phantom flying but the
    cost and complexity of the attempt foiled it. There is a Buccaneer
    that should be flying in the UK soon, but it's being operated by a
    civilian owned firm that works for the military. Then there's that
    Vulcan...
