amazing, almost on topic
Discussion in 'UK Motorcycles' started by darsy, Apr 17, 2006.
  1. darsy
    Every day brings more knowledge.
    Andy Bonwick, Apr 17, 2006
  2. darsy
    mb Guest
    IANAE but... Some alloys maybe (duplex), but stainless doesn't support
    the burning needed for normal flame cutting - you need carbon in it.
    You could prolly reduce it to a lump of molten metal.
    mb, Apr 17, 2006
  3. darsy
    That's about all you can do to it. You can melt through it but not
    cut it.
  4. darsy
    good, good - this was exactly my plan.
    Joe 90.
    you're generally a useless ****, but in this area you manage to shine,
    and I'm vaguely glad I know you.
    Cheers, fella.
    darsy, Apr 17, 2006
  5. darsy
    [snip]
    but it clearly won't be a /garage/ as a car won't fit in it. It's a
    brick shed.
    darsy, Apr 17, 2006
  6. darsy
    yup. The house already has a combined PIR/ultrasound alarm system, and
    I'd look at extending this into the new structure.
    darsy, Apr 17, 2006
  7. darsy
    I haven't got the time nor the enthusiasm to explain the difference
    between randomly melting steel and cutting it with an oxy-acetylene
    set. Just accept that there is a difference.
  8. darsy
    snip>
    I'm welling up.
  9. darsy
    mb Guest
    mb, Apr 17, 2006
  10. darsy
    Not sure of the exact chemistry but essentially curtting relies on the
    steel actually burning away as opposed to melting away. It requires
    excess oxygen from the cutting torch.
    AIUI the acetylene is simply used to pre-heat the steel.
    With a simple welding torch you can turn off the fuel gas and cut
    steel for a while with just oxygen, once you've got it hot enough to
    burn.
    Pip Luscher, Apr 17, 2006
  11. darsy
    Fails miserably on the "is the vehicle stored overnight in a brick-built
    garage" question though, I'd have thought.
    ogden, Apr 17, 2006
  12. darsy
    DR-Z 400.
    ogden, Apr 17, 2006
  13. darsy
    It'll take a **** of a lot longer to melt through stainless than it
    would to cut through normal steel of a similar thickness. You can't
    just apply a cutting torch to a piece of 10mm thick stainless angle
    and melt it.
    If you can't accept that this is true then go and buy a set of bottles
    and have a go for yourself.
    Get rid of this fucking shit as well in future.
    Andy Bonwick, Apr 18, 2006
  14. darsy
    On Mon, 17 Apr 2006 21:31:38 GMT, Pip Luscher
    snip>
    That's about it.
    Also known as lancing. Good for blowing things like safes apart
    apparently.
  15. darsy
    Dan L Guest
    I don't declare it as such, and haven't had any problems to date.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Apr 18, 2006
  16. darsy
    I wasn't really thinking about putting electric in at all, but the
    various replies in this thread have made me possibly reconsider.
    heh.
    darsy, Apr 18, 2006
  17. darsy
    you don't live in London - having the bikes garaged makes a pretty
    significant difference to the insurance quote.
    darsy, Apr 18, 2006
  18. darsy
    well, yes, but less applicable to Z1000.
    darsy, Apr 18, 2006
  19. darsy
    Dan L Guest
    Good point, although it does also have a bearing out here in rural
    Oxfordshire too. What usually happens is that when the garaging question
    comes up I have to explain the set up, which normally results as it being
    classed as "kept in a locked outbuilding". My current policy excludes theft
    from my property unless it is locked away in the shed, so when it's parked
    out front [1], technically it's not insured.
    [1] Normally when I've just got it out pre-bimble, or arrived home
    post-bimble.
    Dan L (Oldbloke)
    Dan L, Apr 18, 2006
  20. darsy
    Dan L Guest
    Unfortunately, nowadays you'll need a Part P electrician to do this for you.<snip>
    Dan L (Oldbloke)
    Dan L, Apr 18, 2006
