amazing, almost on topic
Discussion in 'UK Motorcycles' started by darsy, Apr 17, 2006.
  1. darsy
    if one were considering building a purpose-built bike garage,
    including some sort of "hitching post" built into the walls, what
    material would suit?
    darsy, Apr 17, 2006
  2. darsy
    BGN Guest
    <raises eyebrow> Mauve crushed velvet?
    BGN, Apr 17, 2006
  3. darsy
    Eiron Guest
    Wouldn't you fit the device into the floor? You can take a few bricks
    out of a wall in moments as mortar isn't that soft.
    Also consider fitting a drain in the floor. It will save hours in the
    long run searching for circlips and small screws.
    Eiron, Apr 17, 2006
  4. darsy
    Eiron Guest
    Oops, I meant not that hard, at least not the lime mortar that real walls use.
    Eiron, Apr 17, 2006
  5. darsy
    deadmail Guest
    Breeze blocks I'd suggest. You could build the hitching post into the
    pillars (you'd need one or so in the long wall) or, failing that just
    sink it in the concrete floor when you laid it.
    deadmail, Apr 17, 2006
  6. darsy
    Dan L Guest
    I bought and adapted a standard 8 x 6 shed as follows:
    Laid a hard concrete base with ground anchor.
    Specified no windows in shed, and door at one end only.
    Converted blank end of shed to have double doors.
    Bolted shed directly to concrete base (i.e threw away the wooden floor).
    Laid on power.
    Painted floor.
    Installed alarm.
    2 bikes fit in quite snugly, plus other assorted crap.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Apr 17, 2006
  7. darsy
    believe me, I've considered it - however, in this case it wouldn't
    fit.
    darsy, Apr 17, 2006
  8. darsy
    you could be right - I still want to DIY it rather than buy a purpose
    built ground anchor, because I'll be building the structure almost
    from scratch, and it'll be a purpose built bike-storage space rather
    than a general purpose garage.
    you seem to be implying that I'd be doing some sort of maintenance
    work on my bikes myself - how odd.
    darsy, Apr 17, 2006
  9. darsy
    you misunderstand - what sort of material for the actual attachment
    point for a chain i.e. steel/titanium/cheese etc.
    darsy, Apr 17, 2006
  10. darsy
    this is in connection with one of the two properties I'm considering
    buying[1]. It's already got a mains-equipped 10x16 shed at the bottom
    of the back garden, but I don't really want to have to put a sloped
    path the whole way to the front of the house.
    The house has an fairly wide gap (around 2.5m) between the side of the
    property and the building line. There's currently a brick wall at the
    front with inset wrought-iron gate, and a 6 foot wooden fence running
    right along side the house to the shed at the bottom of the garden.
    What I want to do is, build up a brick wall along the building line
    for 3 metres or so, build a back wall to the bike storage area (with a
    lockable door in it), replace the wrought iron gate with another
    lockable door (maybe double doors, but in any case wide enough for a
    bike), then roof this over with sloped corrugated clear plastic (and a
    bit of guttering, natch). I don't need electricity (at least
    initially).
    In the building of the above, I'd set in some ground anchors, made out
    of some kind of metal. My original question is: what sort of metal.
    [1] I know the "right" answer is to buy a house with a garage, but the
    one I'm considering with a garage doesn't have enough room/an ensuite
    (see other post)
    darsy, Apr 17, 2006
  11. darsy
    Dan L Guest
    This is similar to where mine is situated, i.e gap between my house an next
    door, otherwise a pretty useless piece of garden.
    I did consider a similar approach, i.e building a "lean to" effort off the
    side of the house. However, my brick work skills are dubious, and I really
    didn't want the hassle of finding out if such a structure required planning
    permission. A shed, to me, seemed far more innocuous, and less likely to
    incur any objections from neighbours. Also, dicking about with wood is a
    whole lot easier. [1]
    Don't forget, electricity is a good thing for optimates, theft deterrents
    lighting and heating (I have an electric tube heater in mine to keep the
    chill off the bike in winter). My prime aim was to make the "Bike House" as
    hassle free as possible in use (and a useful little bolt hole when
    necessary).
    I bought a purpose made item from M&P, and sunk it into the concrete base so
    that it wasn't protruding (less of a trip hazard). It's a fairly sturdy
    steel ring, with lateral bars which extend under the concrete base.
    If there is an alternative, not having a garage is not really reason enough
    to reject an otherwise suitable house.
    If you like, I can send pics of my set up, to give you some idea of what
    it's like.
    [1] Feedlines R us.
    Dan L (Oldbloke)
    Dan L, Apr 17, 2006
  12. Wot! No fitted carpet? (OK someone gave me a load that just fitted.)
    I was going to fit a heavy duty ring on a plate into the floor between
    the bike and the wall (for difficult access) with expanding bolts in to
    the concrete. Then weld the bolt heads to the plate.
    Mick Whittingham, Apr 17, 2006
  13. darsy
    For ease of sourcing it I'd say stainless angle section. You should be
    able to buy some large section stuff and actually build it into the
    wall. Stainless is horrible to hacksaw through, takes longer to grind
    through and can't be cut with an oxy-acetylene set. Not many bike
    thieves have plasma cutters so you should be safe.
    If you go down this route and have the garage built to your own specs
    then get the electrician to wire in a hidden isolator so nobody can
    plug a grinder into your supply and cut through chains.
    Andy Bonwick, Apr 17, 2006
  14. This describes what I have done, with the front half bike shed the rear
    half garden shed.
    It's behind double 2 meter gates to the front of the house.
  15. A friend who lives out near Hampton came home one evening and found one
    of those airliner containers in his front garden, rather to his
    bemusement. It was all in one piece, so hadn't fallen out of a jumbo or
    anything.
    He uses it as a shed.
    The Older Gentleman, Apr 17, 2006
  16. Concrete block or mass concrete. If the scrotes are going to demolish a
    wall to get something detached from it, even concrete isn't going to
    stop them. All you can do is make it so noisy or difficult they won't
    bother.
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
    Grimly Curmudgeon, Apr 17, 2006
  17. You might want to have an anonymous word with your friendly local
    council planning officer first. I can spot a couple of problems with your
    scheme that might run foul of planning permission/building regs (e.g.
    having a garage attached to a residence is a big no-no these days, there
    are rules about how high the door-sill must be to prevent petrol spills
    escaping, and burn resistance of the door, etc -- possibly only of
    relevance if the door is between the garage and the residence, but it
    might be safest to check first).
    Dr Ivan D. Reid, Apr 17, 2006
  18. darsy
    Beav Guest
    If I was considering such a construction, I'd be very much drawn to one of
    those "Bike safe" things where the bike "just" fits inside and sits locked
    onto on a loading rail with built in locks which engage when the bike's
    pushed home. The outside also (obviously) locks so it's a locked bike,
    locked onto a rail which is locked inside a pretty hardy steel box which is
    locked inside a (hopefully) well locked garage.
    Anyone looking to nick that bike won't be doing it easily and they'll
    certainly need to make a fucking lot of noise trying.
    Beav
    OMF#19
    VN 750
    Zed Thou
    mail is beavis dot original at ntlworld dot com (with the obvious changes)
    Beav, Apr 17, 2006
  19. Hmm... I should have read the following posts.
    Stainless, as Andy says, and make it inaccessible once the bike's in
    place.
    GS850x2 XS650 SE6a
  20. darsy
    He should know Darsy. While you are putting in the isolater get the
    bracket wired into a separate mains supply. Great idea until *you*
    forget :eek:)
    I didn't know you couldn't cut SS with an OA Torch??
    Hog, Apr 17, 2006
