Am I dreaming or what? (Soviet iron con't)
Discussion in 'UK Motorcycles' started by Sean_Q_, Jan 7, 2010.
  1. Sean_Q_
    S'mee Guest
    damn you REALLY shouldn't be mixing your medications (legal and
    shopped) with that cheap ass OE800 you drink krusty.
    S'mee, Jan 9, 2010
    #61
  2. Sean_Q_
    frag Guest
    took a blunt brush and painted...
    I'm impressed that you could sit on a bed, and then sit down, again, whilst
    sat.
    And has this particular stalker got a foot fetish?
    frag, Jan 9, 2010
    #62
  3. Sean_Q_
    S'mee Guest
    well, damn. I kinda thought you were, was ask to borrow few thou' for
    my charity. We're trying to raise up out of poverty artists who paint
    elvis on velvet and live with hookers...it's a very hands on charity.
    S'mee, Jan 9, 2010
    #63
  4. Sean_Q_
    Snag Guest
    Well , not really all that conversant with which frames and all that ... but
    carbide precipitation can be a problem with some alloys , and most stainless
    steels . And localized hardening from the heat of the welding process can be
    a real problem ...
    More just general knowledge of metals , rather than specifics of any
    particular application .
    Snag, Jan 9, 2010
    #64
  5. Sean_Q_
    DR Guest
    The Older Gentleman posted:
    Your days on bass with Whitesnake were pretty good though.
    DR, Jan 9, 2010
    #65
  6. Sean_Q_
    S'mee Guest
    Believe it or not that makes sense...never been fanatical enough to
    soften a weld back to the same hardness as the rest of the frame. I've
    seen the results of that a couple of times.
    S'mee, Jan 9, 2010
    #66
  7. Sean_Q_
    Gaidheal Guest
    You never saw "The French Connection"?
    Gaidheal, Jan 9, 2010
    #67
  8. Sean_Q_
    S'mee Guest
    watched the first 15 thought it was poorly done and poped out the tape
    and put in a GOOD movie..Chisum.
    S'mee, Jan 9, 2010
    #68
  9. Sean_Q_
    Hmm, I built a perfectly useable (1) outfit for under £2k.
    (1) In the right hands.
    Andy Bonwick, Jan 11, 2010
    #69
  10. Sean_Q_
    Are you talking about the farmer or the butcher? Two people built
    outfits from scratch and both did the trip but one was a bit more
    stable than the other.
    The information's out there but putting it into practice isn't all
    that simple because so many different things end up having an effect
    on the handling.
    #70
  11. Sean_Q_
    Gaidheal Guest
    Did the pope enjoy The French Connection?
    Gaidheal, Jan 11, 2010
    #71
  12. Sean_Q_
    Gaidheal Guest
    There is probably a published formula somewhere that establishes the
    optimum
    side car wheel location forward of the motorcycle's rear axle in
    relation to track width.
    But a good start would be 10 to 12 inches lead with a 48 inch track.
    And 1 inch of toe-in will help the rig go straighter down the road.
    Adjustability allowing an inch of positive camber on the hack wheel is
    desirable too.
    An old machinist in the same industrial park where Side Strider is
    still located after all these years used to cleverly machine upper
    triple clamps in such a way as to reduce trail so that the side hack
    owner didn't need to buy an expensive Earles fork...
    #72
  13. Yes, but you know what you're doing, and it still wasn't an overnight
    job.
    The Older Gentleman, Jan 12, 2010
    #73
  14. Clue: people didn't and don't necessarily fit outfits with Earles forks
    simply to change the trail.
    #74
  15. Sean_Q_
    The man's an idiot who's obviously never put an outfit together and
    anyone that can't see through him needs their head banging against a
    wall.
    Andy Bonwick, Jan 12, 2010
    #75
  16. Sean_Q_
    It took a total of about 4 weekends to get it somewhere near right
    then numerous changes to tyre pressures and suspension settings but
    it's still an ongoing project (if I could be arsed) if I want it to be
    dead right.
    I still think that changes to the suspension make as much difference
    as changes to the geometry of the outfit and if you leave a bike with
    stock suspension then hang a lot of weight off the side of it you're
    looking for trouble.
    Mine still misbehaves when it's fully loaded but I'm confident that
    it'll be ok when I change the shock on the chair for something with a
    bit of damping in it. If I wasn't using the Tenere for the Elefant I'd
    have sorted it out but lack of time and medical issues meant I just
    couldn't do the work this winter.
    #76
  17. Sean_Q_
    Gaidheal Guest
    No shit, Shylock.
    Gaidheal, Jan 12, 2010
    #77
  18. Sean_Q_
    Gaidheal Guest
    Wrong. My usage was *calculated*.
    Four-eyed Juicy Fruit studied to become a lawyer (shylock), but wound
    up shagging and now works as a hack reporter on trade magazines when
    he's not selling Honda side reflectors on ebay.
    And he certainly looks like a Jew, doesn't he?
    #78
  19. Sean_Q_
    Pete Fisher Guest
    It is amazing what difference tyre pressures make even on an otherwise
    pretty well set up outfit.
    The chair suspension is pretty important. It needs to have a
    surprisingly stiff spring as well as good damping on even a light chair.
    As I found when my old mate and I first built the G80/Watsonian trials
    outfit.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 12, 2010
    #79
  20. Sean_Q_
    S'mee Guest
    Oh you noticed did you? fancy that...
    S'mee, Jan 13, 2010
    #80
