This site rates the '91 Dnepr MT-11 top speed at 77.7 mph: http://www.bikez.com/motorcycles/dnepr_mt_11_with_sidecar_1991.php Mine is almost exactly the same and I'm lucky to attain 50 mph. Even then it feels like a Soviet tractor about to shake itself to pieces. Where do the reviewers get these specs, anyway? Or, what changed at the Kiev Motor Works so much between 1985 and 1991? I'd like to be able to cruise at highway speeds of at least 65mph and I found a web site about replacing the motor with a BMW R100 power plant -- at the obvious risk of straining the Soviet drive train. Maybe an R75 motor would be enough. Or, could I replace the whole works, motor to rear wheel with BMW stuff... shoot, for all the hassle that would be I may as well just BUY an R100, bolt the sidecar onto it and sell the Ukrainian bike... or (simplest of all), trade the thing in on a Ural. But I still haven't figured out if a modern Ural will reach 65 mph...(?) SQ '06 Zuk S40 / '85 Dnepr MT-11 / various derelict odds and sods
I was too busy concentrating on not dying to look at the speedo so ask these guys: http://www.sovietsteeds.com/forums/ Steve
OK, so dump the Diaper and get yourself a 10 year old Suzuki Bandit 1200 or a Suzuki GSX1100G for about $2500 and make up some brackets and a frame out of steel tubing and bolt a fiberglass sidecar body on it. You could do the whole rig for less than $5K USD and you'd wind up with something that *would* cruise the highways at 80 mph all day without straining the engine. If I was going to spend, say $10K USD, I would spring for the ESZ conversion with car rims and tires and the leading ling fork. http://www.three-wheels.com/rx4.htm
I must ask, what is the hurry? Go slow, enjoy the ride. If you feel the need for speed, stop by my house and scare the hell out of yourself on my 100hp / 14k rpm sportbike.
If you're ever riding the slab on a bike that can barely do the legal minimum speed and all you can see in your rearview is a semi's grill then the answer will come to you in one of those Zen "aha" moments. Be careful who you invite, I might just take you up on that! SQ '06 Zuk S40 / '85 Dnepr MT-11 / various derelicts the cat dragged in
Something isn't right then. I'm convinced they pluck specially marked feathers from the wings of pigeons sometimes. Nowt. I took one for a test spin when the UK importer was Neval. It was quite brisk up to 50ish. The representative then took the controls. That was scary. He said they'll top out at 75ish when they're fully run in, but aim to cruise at 60-65. Do you still have the vile pissfuel lumps of crap carbs and are the timing and valve clearances spot on. Also, look for a plate at the base of the barrels. Used to drop the compression to allow the bike to run on a mix of vodka and weasel piss, and if you have the rubber inlet trunk, make sure it isn't kinked. Neval used to do a conversion to the R80 motor. I may still have the copy of Bike mag with the write up of it somewhere. Yebbut where is the fun in that? http://www.f2motorcycles.ltd.uk/uralcombo.html Lists the estimated max at 65, with a cruising speed of 55. I really do need to stop hankering after one...
With the right tools , it wouldn't be all that hard . Friend of mine built a wheelchair-accessible sidecar for his '70 Triumph so his handicapped (now ex) wife could ride with him .
EZ for me, difficult for you, because I'm a practical engineer and you're just a panty-prancing Morris dancer.
If I was going to custom build a rig, I would start by contacting Doug Bingham at Side Strider to see if he had any clamp on brackets for sale. http://sidestrider.com/
Liar...you aren't any kind of engnineer. For that matter you are incompetant for even the most simple task such as staying continent...oops, now you gotta go change them soaked diapers you wear 24x7
One does not have to own a motorcycle, ride a motorcycle, or have ever ridden a motorcycle as a prerequisite to talking about motorcycles. The above statement is not intended to indicate that I do not own or ride a motorcycle, or multiple motorcycles. The first person who ever actually built a motorcycle had never owned a motorcycle and had never ridden a motorcycle. But when he had completed his creation, he was a motorcycle builder/ owner and may have regarded himself as the most qualified person in the world to talk about custom building and owning motorcycles. OTOH, when the first motorcycle builder/owner attempted to *ride* his creation, some busybody like you was probably there to criticize the attempt.
I've actually seen one of those with the controls moved over to the sidecar... *way* cool. Here's one: http://www.advrider.com/forums/showthread.php?t=172487 __ Steve ..
So you admit you don't actually ride motorcycles nor have you EVER ridden a motorcycle (except as bitch) and that you only go to places where motorcyclists gather in hopes of finding yourself a man for a little man love. (your own words) Nice, using the truth to twist a lie. Interesting that you'd use Goebbles failed tactis and opertating procedures for further your failure at life...you pathtetic failure.
That would be the smart thing to do...but that is Krusty you are commenting about. You know the non-riding failure.
Voltaire's Neapolitan eunuch complained of his own condition but remarked upon the success of Farinelli...
ah, another drug and alcohol induced non sequiter from the fruitcake. How unamusing...<turns back to watching christmas trees turned into rockets>
