alternator went out goldwing.
Discussion in 'Motorbike Technical Discussion' started by Guest, Oct 19, 2005.
  1. Guest
    Guest Guest
    hello. i was on a ride and stopped on the road for a break, pushed the
    button and click.
    proceeded to the next town, found a Napa store, they had THE BATTERY for my
    bike {smiles followed}.
    when i pulled the old batt out 2 of the cells were REALLY hot, shorted out i
    suppose.
    checked the alt output no go. checked into motel had steak and rum.
    ran home next day after pulling all the fuses except ign and starter.
    ok now i have replaced the brushes on the alternator, it wont put out
    anything.
    what happens to these alternators when they are tasked with charging a
    shorted batt?
    do the diodes go out? is the rectifier bad?
    i tested the stator, slip rings, armature and rotor. all check ok with
    ohmmeter.
    how do i test the rectifier/diodes. the goldwing bible doesn't specify how
    to check all components.
    i am low on the fundage and can get a new alt from a bud at Honda for 200$
    but if its just a component i would rather do that.
    BTW bike has 31k on it and no extra load on the electrical system{i.e. rings
    of fire, lights }
    thanks in advance for your time to respond.
    Matt {hotwng1}
    Guest, Oct 19, 2005
  2. Guest
    Guest Guest
    BTW you can e m ail me at {skidflap) at hotmail.
    thanks Matt
    Guest, Oct 19, 2005
