Alternator output?
Discussion in 'Motorbike Technical Discussion' started by Scott, Oct 20, 2006.
  1. Scott
    Scott Guest
    With the changing season I'm thinking about some heated riding gear. But I
    don't know if my bike's charging system has the extra capacity for it. I've
    tried to work it out on my own, but my Google-fu is not strong enough, and I
    must now beg for help. Does anyone have a good read on the rated alternator
    output on a 1982 Honda CB900F?
    Thanks,
    -Scott
    Scott, Oct 20, 2006
  2. Scott
    Scott Guest
    Thanks. 50-75W seems reasonable, and I'll keep an eye on the voltage. I've
    been considering converting my running lights to LEDs for visibility and
    reliability. Converting the tail and marker lights would only save around
    20 watts, but even that much might be useful.
    -Scott
    Scott, Oct 21, 2006
  3. Scott
    MadDogR75 Guest
    I don't know the figure for your bike, but thats OK, it will be in your
    manual.
    Figure your running load, (all the lamps are in the manual too),
    add 40W. for ignition, subtract from alternator rating, and you have
    the
    'headroom` for heated gear, which is also marked with its wattage.
    Most of the time you don't have too much power to spare, but you can
    use
    the heat intermittantly, and let the battery recharge in the 'off`
    cycles.
    (Some gear is on a thermostat which does this anyway.)
    It's not a good idea to run the alternator too close to max all the
    time.
    Just make sure you shut down the heat about 10-15 Min. before you park
    so you can get a start in the morning.
    MadDogR75, Oct 22, 2006
  4. Scott
    Scott Guest
    Yes, if only I had the manual. See, I put it in a folder in my filing
    cabinet, so it'd be safe and I'd know where it was. Even now, I could reach
    into the cabinet and grab the manual without even looking.
    But then I moved house, and now I can't find my filing cabinet.
    -Scott
    Scott, Oct 22, 2006
