alternator output
Discussion in 'Motorbike Technical Discussion' started by Sean J Kelly, Jan 5, 2005.
  1. Sean J Kelly
    Sean J Kelly Guest
    hi, all -
    I'm working on a project... I've taken a '73 Honda CB350 and built a bit
    of a cafe racer. I'd like to fit it with a modern headlight, with a
    modern bulb... However, the alternator is only rated to output 100W max,
    which I don't think will do it.
    I'll want to ride with the headlight on all the time. And I'm not using a
    battery.... kick or bump start only, using a "Bat-pac" which is basically
    another regulator to give a nice steady voltage output.
    So, here's the question: Is there any way I can get more power out of
    this alternator? Could I rewind the stator? Replace the rotor with a
    stronger magnet? Run a modern, external alternator off the front of the
    engine where the starter was originally mounted?
    Thanks for the ideas.
    -Sean
  2. Sean J Kelly
    bob prohaska Guest
    I think Krusty alreay made the most fundamental point; you'll work hard
    and pay dearly for any gains :cool:
    The power obtainable from an electromagnetic machine is proportional
    (roughly) to the amount of iron in the magnetic circuit and the freqency
    of operation. Of course, it depends heavily on _how_well_ the iron and
    speed are used, but they're the essential limits.
    The first thing to do is look at the stator; if it's a multipole
    ring like the one illustrated here:
    http://www.electrexusa.com/electrex_stators.html
    there won't be a huge amount of room for improvement.
    If on the other hand the stator looks like the _lower_
    illustration on this page:
    http://www.electrexusa.com/electrex_LC_ENTER.html
    you have considerable room for improvement.
    To get more power out of an existing (well-designed) stator the steps
    would be:
    1. replace the windings with fewer turns of heavier wire. That will
    give you more current, but require higher rpm to get usable voltage.
    Tricks like using rectangular wire the packs tight in the stator
    slots are helpful.
    2. Increase the strength of the magnets. That will bring the rpm for
    minimum usable voltage back down. There's only so much headroom here,
    iron saturates. On a bike that old modern magnets might be an improvement,
    however.
    The notion of mounting a small automotive alternator (Nippondenso
    makes a nice one) is appealing, but the mechanical problems look
    intractable; the starter geartrain is not sized for continuous
    operation, and you'll likely want the alternator to run at close
    to crankshaft speed, not several times higher as the starer does.
    It's a serious mechanical engineering project.
    You're up against a tough problem.
    If you're getting 100 watts out of a two-phase stator putting the
    headlight on the AC side will help some, with a shut RR downstream
    for regulation and battery charging. That will avoid some diode losses.
    Good luck!
    bob prohaska
    bob prohaska, Jan 6, 2005
