Alternator machining work
Discussion in 'Bay Area Bikers' started by r_kleinschmidt, Aug 28, 2003.
  1. Howdy
    I've got an alternator that could probably use some machining
    of its slip rings. Has anybody had similar work done locally ?
    The windings are still OK but one ring is badly grooved.
    I'm in the south bay, and the rotor is from a BMW airhead
    (mounts onto a taper on the front of the crank).
    Thanks for any thoughts
    Rob Kleinschmidt
  2. r_kleinschmidt
    bob prohaska Guest
    A lathe is certainly better, but if the rotor mounts the way I
    think it does there's very little to grab in a chuck or on centers.
    Unless somebody has an accurate mandrel of the right dimensions
    the file trick might be a reasonable first try.
    bob
    bob prohaska, Aug 29, 2003
