Almost there...
Discussion in 'UK Motorcycles' started by Andy Bonwick, Sep 13, 2008.
  1. Andy Bonwick
    On Sat, 13 Sep 2008 12:45:39 -0700 (PDT), boxerboy
    snip>
    I also need to remember not to ride up onto a paved area in the garden
    with my left foot on the floor because the sidecar bracket hits you on
    the back of the leg if you clip the edge of the slabs with your toes.
    It wouldn't have been too bad if I'd had a front brake that works but
    the momentum of the bike bent my left foot into a position it really
    shouldn't be capable of before I hit the back brake.
    Andy Bonwick, Sep 14, 2008
  2. Andy Bonwick
    One cannot but admire a chap with such a forthright approach to the products
    of digestion.
    platypus, Sep 14, 2008
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    I think it's just a man accepting the inevitable consequences of
    accepting a lift in Bomber Bonwick's chair.
    The one in San Quentin is less scary, but you do have to have your head
    shaved first.
    Wicked Uncle Nigel, Sep 14, 2008
  4. Andy Bonwick
    I refuse to believe that there's anything remotely worrying about being a
    passenger in a competently-piloted outfit.
    <thinks> Although you may have a point nonetheless.
    platypus, Sep 15, 2008
  5. Andy Bonwick
    At least the chair I've fitted has got a nice scratched screen so you
    don't have to look at the road.
    You're right - I'll clean the screen.
    Andy Bonwick, Sep 15, 2008
  6. Andy Bonwick
    I've got the lead and lean sorted out but I think the toe in still
    needs adjusting. I need a couple of decent length bits of wood to use
    as straight edges otherwise I'll be putting chalk marks on the drive
    and moving the outfit backwards and forwards over them to check the
    alignment.
  7. Andy Bonwick
    deadmail Guest
    Don't much rate your idea of chalk marks. Really won't be easy.
    From a Sidecar Federation guide line I've got:
    Sidecar lead is the distance between the rear axle of the bike and the
    wheel spindle of the sidecar. The value can be anything from zero on
    some vintage outfits to as much as 50cm. As lead is increased the
    weight distribution improves until a point is reached where the steering
    becomes too heavy and tyre wear becomes excessive. A good compromise
    will usually be found between 15 and 35cm. It is not critical and may
    in any cas be dictated by where the fittings can be located.
    When fully laden it is important that the bike should not lean towards
    the sidecar; if it does the steering will be heay particularly when
    turning away from the sidecar. The amount of lean-out is measured at
    the steering head of the unladen mororcycle and is usually less than
    3cm. Outfits with car tyres, particularly wide, low profile ones should
    be set up with zero lean out.
    Toe-in is defined as the amount by which the track width at the front
    wheel is narrower than at the rear. It is measured using a pair of
    straight edges, one along the motorcycle wheels and one along the
    sidecar wheel extending forward to the front wheel. If the front and
    rear wheels differ in width this should be allowed for. Too much toe-in
    will scrub the tyres on turns towards the sidecar and let the outfit
    drift towards the middle of the road under neutral steering. Too lttlle
    toe-in and the outfit will favour the gutter. In practise it is usually
    found that a well set up outfit will move slightly towards the kerb
    under acceleration and slightly away on braking. A typpical value would
    be 10 to 20mm, rately as much as 35mm. This measurement can be critical
    to the steering bias of the combination and the more lead you have the
    less toe-in you need."
    So there you go. Lead and lean out affect steering, toe in pulling.
    In my experience it's hard to adjust lean out without impacting toe in
    and vice-versa. Maybe I just need to tidy up my mountings so they're
    free and not under any 'static stress'. It's also felt like lean out
    affected pulling towards the kerb/middle of the road under neutral
    steering.
    deadmail, Sep 15, 2008
  8. Andy Bonwick
    CT, Sep 15, 2008
  9. Andy Bonwick
    On Mon, 15 Sep 2008 07:49:57 +0100, wrote:
    snip>
    Not under any static stress? I had to batter the fittings on mine to
    get them to move but I put that down to the thick layer of paint
    gobbed everywhere.
    I'll try and find two straight bits of wood when I'm next home so I
    can check the toe in but when I said use chalk marks I meant mark the
    centre line of the chair on the drive as one straight line then mark
    the centre line of the bike and measure it then put a series of
    calibration marks down so I can check where I'm moving the bike
    relative to the chair as I adjust it.
    Maybe my engineering background is making me overcomplicate this but
    I'm used to marking things out so I've got a visual aid to where
    things are. A plumb line tied off on the centre off the chassis front
    and back is an instant indication of what's happening and having an
    axle stand under each side at the front of the subframe means the bike
    should stay still.
    I'm going to have a look at how easy it is to lift the body of the
    chair off the chassis to lighten things up a bit and make sure I don't
    punch holes through the bodywork when I resort to the 7lb sledge
    hammer...
  10. Andy Bonwick
    heh - just what I was thinking.
    Champ, Sep 15, 2008
  11. Andy Bonwick
    Lady Nina Guest
    You not going to do any more this year?
    Lady Nina, Sep 15, 2008
  12. Andy Bonwick
    SD Guest
    Is the correct answer.
    The full answer is long, complicated, and not particularly
    interesting/exciting.
    SD, Sep 15, 2008
  13. Andy Bonwick
    you're going on a 6 month Saga cruise?
    wessie, Sep 15, 2008
  14. Did that a couple of times on a trailie, catching toe on a rock
    with footpeg pushing into the Achilles' tendon. Even managed to take a
    chip out of a slab of basalt that way, but I think it was already cracked.
    Bloody _hurt_ thobut!
    Dr Ivan D. Reid, Sep 15, 2008
  15. Andy Bonwick
    Lady Nina Guest
    Penis extension?
    Maintaining structural integrity and all that.
    Oh. <twiddles thumbs>
    Couldn't you do some made up reports with dinosaurs and jet planes?
    Lady Nina, Sep 16, 2008
  16. Andy Bonwick
    zymurgy Guest
    You youngsters have got it easy. We had to learn castor, camber and
    KPI when I was an apprentice (not just toe-in and toe-out), and it was
    an absolute **** to set up on a car until the advent of the new
    fangled optical alignment gauge. [1]
    P.
    [1] Lasers being part of science fiction at this stage.
    zymurgy, Sep 16, 2008
  17. Andy Bonwick
    You did all this with spanners didn't you?
    Andy Bonwick, Sep 16, 2008
  18. Andy Bonwick
    zymurgy Guest
    Yep, blood, sweat, tears (usually of the Mechanic mentoring me)
    We were a main Ford dealer, and had a bodyshop where all the locally
    pranged Fords went to. We had to re-set up the steering geometry on
    the alignment jig before it went to the panel beating monkeys.
    The 'new' optical guage used incandescent lamps on to a graduated
    screen to re set the geometry up. It's all (or was) adjustable in
    several planes.
    P.
