alloy corrosion
Discussion in 'Australian Motorcycles' started by isaac_the_blind, Aug 10, 2006.
  1. Any one have any thoughts as to how best clean up an alloy
    motor thats been sitting out in the sun N rain for months ?
    Itz got that whitish corrosion on it. ( Itz a K100 ).
    Thankx, Isaac the visually challenged.
  2. isaac_the_blind
    atec77## Guest
    Only thing I found that has a chance of working without busting your
    foofoo valve is from the same guys who make truck wash , a pink fluid
    that brushes on and with some light scrubbing will chemically clean the
    crap off , why was it left out side ? ( mines under cover alongside the
    Buel)
    atec77##, Aug 10, 2006
  3. The "Buell"! Oh you name dropper you :)
    Seriously though the bike is/was owned by a woman :-(
    Who knows the ways of women ?.
    Isaac.
    isaac_the_blind, Aug 11, 2006
  4. CT12 ? wot, look in the Cheeepa Autoparts places etc ?
    Isaac.
  5. Photoshop )or Gimp(.
    Pisshead Pete, Aug 11, 2006
  6. isaac_the_blind
    JM Guest
    If its shiny alloy... lots of hard work....
    If its sandcast stuff, go the Phosphoric acid - but be careful - any
    magnesium castings tend to ignite.
    Degrease beforehand anyways.
    Cheers,
    Jeffles
    JM, Aug 11, 2006
  7. I think itz sandcast :-(
    Isaac.
    isaac_the_blind, Aug 12, 2006
  8. Yep, CT12 is the stuff. Clean the engine first of any oil/grease, spray the
    engine with a dilute mixture of CT12 and water, then let it froth up(if it
    doesnt froth up on the alloy it's too dilute) give it a scrub then hose it
    off to remove the stuff, maybe even sponge it off at the same time to avoid
    streaks. Oil/grease will block the CT12 from working on the alloy.
    Al
    Alan Pennykid, Aug 12, 2006
