Allen key for zzr11D4 F.Wheel
Discussion in 'UK Motorcycles' started by Jim Ingram, Aug 4, 2004.
  1. Jim Ingram
    Jim Ingram Guest
    Hi,
    Does anyone know what size allen key I need (the larger of the two)
    to fit a zzr4110d4 front axel nut. I measured it as 23mm which is a
    bit of a odd size so I though I'd ask here first. Suggestions for
    possible suppliers also appreciated.
    Thanks
    Jim
  2. Jim Ingram
    Jim Ingram says...
    It's the same size as the head of a large 3/8 drive spark plug socket,
    so I chopped the end off the socket and used that. You can get away with
    using the whole socket with a few long extensions through the wheel
    spindle, that's what I did til I got pissed off with doing it that way.
    Lozzo, Aug 4, 2004
  3. Jim Ingram
    Jim Ingram Guest
    Thanks for the tip Lozzo. I think I have a couple of possible spark
    plug sockets in a draw somewhere. Seems that to buy an allen socket
    (I now think its actually 22mm) would be around £20. Any opinion on
    what tyre (front) to fit? I was just going to get a BT 020 which
    seems to be bridgestoines current recomendation (preference for
    mileage over performance).
    Cheers
    Jim
    Jim Ingram, Aug 5, 2004
  4. Jim Ingram
    AndrewR Guest
    If you're anywhere near Northumberland then you can borrow mine.
    If you want to buy one then your local, friendly Kawasaki dealer will be
    happy to rip you off.
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1
    BotToS#5,SBS#25,IbW#34, TEAR#3 (and KotL), DS#5, COSOC#9, KotTFSTR#
    The speccy Geordie twat.
    AndrewR, Aug 5, 2004
  5. Jim Ingram
    Jim Ingram says...
    Avon Azaro 3 AV 45/46 ST are the best I found for a good compromise of
    grip and longevity. Plenty of other ukrmers will say the same. Far beter
    in the wet than Bridgestones too. Try www.fwr.co.uk for the best prices.
    Fit a pair, cos they're cheap enough and will be matched to each other.
    They last forever, so you won't really miss the life you had left in the
    old rear tyre.
    Lozzo, Aug 5, 2004
  6. Jim Ingram
    Ginge Guest
    7000 miles to a rear compared to 4500 on an 020, but still the Avons are
    grippier.
    Ginge, Aug 5, 2004
