Aldi ultrasonic cleaner
Discussion in 'UK Motorcycles' started by Ivan D. Reid, Jan 7, 2011.
  1. Ivan D. Reid
    Ivan D. Reid Guest
    Available again as next Thursday's special, GBP20
    http://www.aldi.co.uk/uk/html/offers/special_buys3_17130.htm
  2. Ivan D. Reid
    Malc Guest
    Malc, Jan 7, 2011
  3. Ivan D. Reid
    Depends what you want to achieve.
    I've used 30% nitric acid in a lab for instance. Some processes use hot
    nitric acid (beware!). S/O is going to get really fecked off with that in
    her kitchen. Probably.
    You can also get things like this:
    www.coleparmer.co.uk/catalog/product_view.asp?sku=0880121&pfx
    where you can also read
    www.coleparmer.co.uk/techinfo/techinfo.asp?htmlfile=ultrasoniccleaner_faq.htm&ID=792#anchor6
    Hog, Jan 7, 2011
  4. Frank Erskine, Jan 7, 2011
  5. Ivan D. Reid
    Jeweller Guest
    Coca Cola works too, but mostly I use washing up liquid in my workshop.
    Special fluid is used here, I believe.
    Jeweller, Jan 7, 2011
  6. Ivan D. Reid
    Simon Wilson Guest
    "You have item(s) in your shopping cart which are considered hazardous
    materials. These item(s) cannot be shipped to residential addresses or
    sold to private individuals."
    Bugger
    Simon Wilson, Jan 7, 2011
  7. Ivan D. Reid
    Ah. Yes.
    Obviously I don't run into that barrier.
    Hog, Jan 7, 2011
  8. Ivan D. Reid
    Skipweasel Guest
    says...
    Either.
    Skipweasel, Jan 7, 2011
  9. Ivan D. Reid
    Ivan D. Reid Guest
    It does rather, except for the brand-name.
    "Damn clever, these Chinese!"
    -- Major Dennis Bloodnok, Retd, MT, MT, MT
  10. Ivan D. Reid
    Rusty Hinge Guest
    Deterrent may help - article has to be wetted for best results.
    Beware ultrasonic bubbles...
    Rusty Hinge, Jan 7, 2011
  11. Ivan D. Reid
    Rusty Hinge Guest
    Coca Cola should not be used for stressed metallic articles, as it *can*
    (especially with small components molished of high-carbon steel -
    springs, f'rinstance) cause some hydrogen embrittlement.
  12. Ivan D. Reid
    Rusty Hinge Guest
    Drop me an emu (remove 'foobar') and I'll aim you at somewhere where you
    can get quantities they will send.
    Large quantities must be collected innit.
  13. Ivan D. Reid
    Graham. Guest
    That may explain some of the more unpleasant gaseous effects when it's taken internally
    Graham., Jan 7, 2011
  14. Ivan D. Reid
    Rusty Hinge Guest
    Contains phosphoric acid amongst other chemicals, though I'd suspect
    it's the carbonic acid content which produces the gut-retching emanations.
  15. The twats. You've probably got more dodgy stuff under your sink.
    Grimly Curmudgeon, Jan 8, 2011
  16. Ivan D. Reid
    bobharvey Guest
    That's right. Have you seen what happens to kid who swallows an
    enamel bucket?
    bobharvey, Jan 8, 2011
  17. Ivan D. Reid
    malc Guest
    Only things like glasses and jewellery.
    malc, Jan 8, 2011
  18. Ivan D. Reid
    Sn!pe Guest
    ISTR reading that there's a risk of damaging lens coatings if you
    use them on your specs. I may well have dreamed this.
    Sn!pe, Jan 8, 2011
  19. Ivan D. Reid
    Sunny Bard Guest
    careful, I managed to strip the antireflective coating from my lenses,
    using only water + a drop of washing up liquid (as recommended by the
    optiquack) and not allowing lens to touch the chamber.
    Sunny Bard, Jan 8, 2011
  20. Ivan D. Reid
    Skipweasel Guest
    Cor - they're expensive! Seen the price of their plastic carboys?
    Skipweasel, Jan 8, 2011
