Aldi Ultrasonic cleaner
Discussion in 'UK Motorcycles' started by Dr Ivan D. Reid, Jan 8, 2010.
  1. On offer again next Thursday for GBP17:
    http://www.aldi.co.uk/uk/html/offers/offers_week02Thursday10.htm
  2. Dr Ivan D. Reid
    Buzby Guest
    Buzby, Jan 8, 2010
  3. Dr Ivan D. Reid
    Catman Guest
    SteveH rates his AIUI
    www.cuore-sportivo.co.uk
    Catman, Jan 8, 2010
  4. Dr Ivan D. Reid
    SteveH Guest
    Cleans watch straps / cases, jewellery, windscreen washer jets, CDs and
    my glasses.
    I think it's a great bit of kit, but YMMV.
    (My usual solution is warm water with a little drop of washing up
    liquid)
    SteveH, Jan 8, 2010
  5. Dr Ivan D. Reid
    Guest Guest
    You have to be extra careful not to get water on the switches. Mine failed,
    but was revived after having a rest in the airing cupboard.
    Guest, Jan 8, 2010
  6. Dr Ivan D. Reid
    Roger Hunt Guest
    Mine is pretty good - so good it eventually dislodged the coating from
    my spec lenses.
    Roger Hunt, Jan 8, 2010
  7. Dr Ivan D. Reid
    Does it remove the whole coating, cos mine have patches where it's worn
    through and I want to get the fucking lot off so I can see properly
    again.
    Lozzo, Jan 9, 2010
  8. Dr Ivan D. Reid
    Roger Hunt Guest
    Mine came off in patches as well, so I continued with the ultrasound
    treatment intensively until it was all loose enough for me to scrape
    gently with a fingernail to get the whole lot off.
    This was pretty successful but the plastic underneath was so soft it
    left faint scratches that made the specs not really up to what I need.
    As the lenses were already several years old it was not as if I had
    damaged a shiny new toy so it did not hurt too much to get them
    replaced.
    Roger Hunt, Jan 9, 2010
  9. Dr Ivan D. Reid
    Sunny Bard Guest
    Opticians strip the coatings using hydrofluoric acid
    http://optochemicals.com/products/info_ar_stripper.htm
    Sunny Bard, Jan 9, 2010
  10. Ouch.
    The Older Gentleman, Jan 9, 2010
  11. Dr Ivan D. Reid
    Lozzo, Jan 9, 2010
  12. Dr Ivan D. Reid
    Catman Guest
    <quote>
    polycarbonates or their coatings may get damaged
    </quote>
    Catman, Jan 9, 2010
  13. Dr Ivan D. Reid
    Sunny Bard Guest
    Yes, my optician does the de-coating in-house, if you want them
    re-coating you'll need a spare pare of bins 'cos they have to send them
    off to be done in a lab.
  14. Dr Ivan D. Reid
    Roger Hunt Guest
    Would it be normal to give the lenses a little polish before they
    re-coat them, or would minor scratches doom them to the bin?
  15. Dr Ivan D. Reid
    Sunny Bard Guest
    I'll tell you next week ...
  16. Dr Ivan D. Reid
    Roger Hunt Guest
    OK - thanks.
  17. That's what I use and it is very efficient.
    When doing the maintenance on our SCUBA regs I put hot clear pickling
    vinegar in the cleaner and put the stripped bits in to it. Works a
    treat.
    Mick Whittingham, Jan 9, 2010
  18. Dr Ivan D. Reid
    Hi Gid, and the same to you and Suzie :)
    Lozzo, Jan 9, 2010
  19. Dr Ivan D. Reid
    Rusty Hinge Guest
    Ah, when I jbexrq at Murex we hfrq that stuff in 30%, 60%, 90% solutions
    and, anhydrous. Used mostly for dissolving tantalum and niobium out of
    the crushed ore.
    You really, really didn't want to get splashed with it, you xabj.
    A splosh from a mixer hit my visor, ran down it and soaked into my overall.
    The stinging prompted a look, and a rapid irrigation on the irritation,
    down to Nursie, who undemined it with several hypodermic jabs, and
    raised the skin on a bubble of sodium glutamo glutamate. (Or potassium -
    can't unforget now, forty years on.)
    Don't go there innit.
    Rusty Hinge, Jan 10, 2010
  20. Dr Ivan D. Reid
    Rusty Hinge Guest
    I expect they an reform them - but I dunno if it's cost-effective.
