Aldi charger heads up
Discussion in 'UK Motorcycles' started by Doki, Dec 26, 2007.
  1. Doki
    Doki Guest
    Doki, Dec 26, 2007
  2. Doki
    Molly Guest
    And jolly decent it is too.
    The best buy was a box of 382 assorted "O" rings ranging from 3.1 - 49.5mm
    for about £3.
    A close second was those little gel pack type warming things, two for a
    pound.
    Molly, Dec 27, 2007
  3. Doki
    Eiron Guest
    It does exactly what it says on the tin.
    800mA (or 4A for a car battery) until charged then it switches to 75mA.
    It's not as good as a real Optimate as it doesn't kill the battery if
    you leave it connected without mains power. :)
    The instructions tell you to disconnect the battery from the vehicle
    before charging, which is a nuisance so I'll ignore it.
    Eiron, Dec 29, 2007
  4. Doki
    T i m Guest
    I bought a couple on Thursday (thanks for the heads up Doki) and have
    only tried them on fairly well charged batteries so far and they seem
    to drop back charge wise as you say.
    And not as good as the Optimate as you have to press the mode button
    to get it going (whereas the Optimate starts doing it's thing
    automatically, handy if the Optimate on the inside of the house and
    you just hook up the bike on the front and forget to press the
    button?). In the Aldi one's instructions they mention that is to
    prevent sparks so it could be a good idea I guess.
    Hmm, until I read the instructions a couple of times I wasn't sure
    what was indicated or what did what. Are the legends on the top very
    dark / undistinguishable on all of them (or is it just my eyes getting
    worse)? :-(
    One thing I'm not sure about is it sounds like there is a relay in
    there and when I connected it to the old CB250 battery (it had been
    left flat for a good year) it starts to charge it then I can just hear
    the relay cycling. Not sure if that's part of it's battery
    'regeneration' process or that it's just caught in a loop but I didn't
    like to leave it on to find out? The Optimate tries to charge it (and
    does to a point) but marks it as 'weak'.
    I found out later on Thursday a biker mate was looking for something
    similar but when he went to the Hoddesdon (Herts) Aldi this morning
    they had all gone, as with the Stevenage branch. Luckily the one at
    the bottom of my sisters road in Upminister had some so she got him a
    couple for me (if anyone is still looking for one). ;-)
    All the best ..
    T i m
    T i m, Dec 29, 2007
  5. Doki
    Bill Guest
    Went into my local Aldi, couldn't find them, so asked the assistant. She
    had no idea what I was talking about, and neither did the manager. This was
    at 0910 on Thursday morning. Guess we got left out in Sudbury.
    Bill
    Bill, Dec 29, 2007
  6. Doki
    T i m Guest
    If this is any consolation, nor did the manager of the store I bought
    them from the previous day (Hoddesdon).
    Apparently the manager of the Stevenage branch knew he had had them
    and they there were none left.
    Upminister had some as per this afternoon if you fancied a ride out!
    All the best ..
    T i m
    T i m, Dec 29, 2007
  7. Doki
    Danny Guest
    Same here. I've never disconnected the vehicle battery before, but is
    there any special reason to do so? Vehicle in question is an Isuzu
    diesel, with not much in the way of electronics.
    Danny, Dec 30, 2007
  8. Doki
    Danny Guest
    Ok, thanks. Left charging anyway...
    Danny, Dec 30, 2007
  9. Doki
    Danny Guest
    <fx> sound of front door opening as he goes to check charger
    Look OK...
    Danny, Dec 30, 2007
  10. Its not unkown for the regulating components in chargers to fail ,
    bunging an unregulated voltage into modern car electronics is not good
    , screws the ecu , thier way of covering arse
    If you are going to charge on vehicle then the negative charger cable
    should be connected to the car body or engine structure not the battery
    steve robinson, Dec 30, 2007
  11. Often stated yet rarely supported with even the weakest of anecdotal
    evidence from the a mate of a bloke someone met down the pub.
    I am not familiar with that one, why?
    steve auvache, Dec 30, 2007
  12. Strangly enough in my local van dealer beginning of december , one
    brand new 20k van having all the electronics changed because the owner
    let the battery go flat , just stuck on his charger and fried everything
    for the sake of 2 minutes with a spanner it just isnt worth the effort
    Havent a clue some advisse i was given by a mechanic 20 plus years ago
    same if your jump starting from a slave battery
    Knowing the cost of a replacement ecu is it really worth it
    steve robinson, Dec 31, 2007
  13. I have fond memories of when Hog got a jump-start for his ShiteOldBMW,
    not realising that the friendly trucker who gave him the boost had 24v
    electrics....
    The Older Gentleman, Dec 31, 2007
  14. Er, as negative is earth (on virtually all vehicles these days), why
    should this make any difference????
  15. It's to stop you creating sparks near to the battery.
    Battery, hydrogen, sparks, BOOM, face full of acid.
    Connect positive to positive first make the negative connection or last
    of the negative connection, if jump starting away, from the battery.
    Mick Whittingham, Dec 31, 2007
  16. Oh yes, but the poster seems to imply it won't fritz electronic stuff
    that way.
  17. Doki
    Danny Guest
    I thought It was to move any possible spark location away from the top
    of the battery, where there may be volatile gases.
    Danny, Dec 31, 2007
  18. The only thing I can think of and I haven't thought this through, is to
    do with the common rail positive supply and remote switching and control
    units used on some modern vehicles. But that doesn't really figure.
  19. IIRC, the only casualty afterwards was the quartz clock. Lucky b'stard.
  20. So the final connection, if sparky, isn't anywhere near the hydrogen gas
    from the battery.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Dec 31, 2007
