Air filter
Discussion in 'Motorbike Technical Discussion' started by andras nolsøe, Jun 3, 2005.
  1. When you change air filter is it then normal to apply a bit of motor oil on
    it??
    is that good?
    andras
  2. andras nolsøe
    The Family Guest
    I don't think so. Not unless it's a filter designed for it, like K&N.
    Gary
    The Family, Jun 3, 2005
  3. For a foam air filter, yes. For a folded paper type, no.
    The Older Gentleman, Jun 3, 2005
  4. Never oil a paper filter, that ruins paper filters...
    Wash a cloth and wire mesh K&N filters in kerosene and they will last a
    long time. I have some that are 20 years old. Lightly oil them and set
    them aside for a day or two to drip off any excess oil before using
    them. The replacement K&N filter that goes inside the original airbox
    is the best kind of air filter to use, the separate filters that clamp
    onto the carburetors require rejetting for best performance and the
    engine loses some mid range power without the air box...
    Wash a green foam rubber air filter in kerosene and lightly oil it,
    then squeeze the excess oil out of it before reinstalling it in the air
    box. Oil will eventually rot a foam rubber air filter and you'll need
    another one after 3 or 4 years...
    krusty kritter, Jun 3, 2005
  5. andras nolsøe
    OH- Guest
    On a paper element it is bad, it clogs it up real bad.
    On any other filter it is the wrong kind of oil. You would
    never guess it but what you want is Air Filter Oil, thin
    stuff that sets and gets tacky and viscous.
    OH-, Jun 3, 2005
